Page 18 of 19
FirstFirst ... 8 16 17 18 19 LastLast
Results 511 to 540 of 560
  1. I too am having the same problem, waiting for the widefrog developer to help us.
  2. Comment implanter le service hbo max car j'aimerais telecharger dessus
  3. Hi, how can I fix this?
    Thank you very much in advance.
    [Attachment 89055 - Click to enlarge]
    EDIT: FIX
  4. Originally Posted by esamax2000 View Post
    Don't know if developer has time to spend with this issue, maybe our problem with mediaset can be solved changing widefrog config file so i think that also an experienced user can help us. Still waiting
  5. Image
    [Attachment 89059 - Click to enlarge]
    I think the file to modify is in the services folder this should be the file but I don't know what to modify mediasetinfinity_mediaset_it
    We are waiting for the developer to give us a hand
  6. rmcbfmplay_com update attached.
  7. still no help for Mediaset Infinity
    Dec 2021
    england
    N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2025/09/2334090_19989fed6a1d01/dashrcenc/hd_wv_mpl.mpd" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/140.0.0.0 Safari/537.36" -H "Accept: */*" -H "Origin: https://mediasetinfinity.mediaset.it" -H "Referer: https://mediasetinfinity.mediaset.it/" --key 9a33769dc69d37f399b8ead3635e42ac:4e9b8fb3b043474b2891e0db83630191 --use-shaka-packager -M format=mkv --save-name "La notte nel cuore Episodio 58"
  9. Originally Posted by iamghost View Post
    Hi, thanks for your interest! The problem we need to resolve is with widefrog.exe. Let me explain. Before a month ago, using:
    widefrog https://mediasetinfinity.mediaset.it/video/drittoerovescio/puntata-del-9-ottobre_F314087201000501
    was enough to download the video correctly. Now, Mediaset's settings have changed, and widefrog no longer works. Any solutions?
    Dec 2021
    england
    i never using widefrog. widevineproxy2 is easy get dl mediaset links
  11. Originally Posted by iamghost View Post
    Thanks for the support but we had a much simpler and more immediate approach to download videos from Mediaset and only with Widefrog this is possible... or rather IT WAS possible until a month ago, when Mediaset changed some parameters on its site and Widefrog no longer worked. Any (widefrog) solutions?
  12. We're waiting for the developer to help us. Widefrog could download an entire series in a single link, which was convenient. Widevine Proxy2 would be a great alternative if it could do that.
  13. Hey,
    Great tool. For zee5, I needed to remove the global in the base url to make it work. Zee5 no longer has the "global" word in the base url.
    The movie and tv series urls change as below, for example:
    https://www.zee5.com/global/tv-shows/details/pavitra-rishta/0-6-133 -> https://www.zee5.com/tv-shows/details/pavitra-rishta/0-6-133
    I made the changes to services/zee5_com.py as detailed in zee5_diff.txt (for all the searches we do in the movie/tv series url)
    Please let me know if you agree with the changes and how I can include them in the code.
  14. Please solve the problem with mediasetinfinity.mediaset.it
    Example: get the all commands from https://mediasetinfinity.mediaset.it/browse/ultimi-arrivi_e5db70a16a6f547001c47ac69
    Oct 2025
    Canda
    You can try: github.com/Arrowar/StreamingCommunity but even for this project the developer is always very busy
  16. We should know the changes made by Mediaset Infinity and then go and correct them on Widefrog
  17. Originally Posted by esamax2000 View Post
    Exactly, for example using N_m3u8DL-RE.exe manually, the download of https://mediasetinfinity.mediaset.it/video/4diseraweekend/domenica-19-ottobre_F313765001008901 is successful, so in theory it would be enough to modify the widefrog.exe configuration file so that it continues to work with mediaset.it
    N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2025/10/2354020_199fdf23494d01/dashrcenc/hr_wv_mpl.mpd" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36" -H "Accept: */*" -H "Origin: https://mediasetinfinity.mediaset.it" -H "Referer: https://mediasetinfinity.mediaset.it/" --key 90734092e33d7059da75dda6862f9652:ad7cf55f31d583e37c8f0560dd56834b  -M format=mkv
    any solution?
  18. In my opinion the problem is in the services directory and the file to check is mediasetinfinity_mediaset_it, I think our problem is in there,
    I just don't have a backup of how it worked before and I don't understand what changed Mediaset why it doesn't work anymore,
    we would need some help from the developer or even from the developer of widevineproxy2 which is already great
  19. (Edit - Please disregard - I was going to ask about Mediaset Infinity, but my question's been covered above.)
  20. Hi, thanks for the tool.
    I'm having a trouble... every time i execute python widefrog.py "url", the py edit config.json so change this
    "DOWNLOAD_COMMANDS": {
    "OUTPUT_MEDIA_PATH": "F:\XX", (example) --> change to "media", the folder by default
    "WAIT_BEFORE_DOWNLOADING": false,
    "ADDITIONAL_SUBS": true,
    "TOOL_PARAMETERS": {
    "VOD": "-sv best -sa best -da id=audio_div -ss all --sub-format srt -mt --check-segments-count false --no-log", --> i add --sub-format srt because is downloaded in wvtt and i want to convert to srt
    How i do that config.json not change this data?
    Thanks again.
  21. I tired 2 services and both fail even though i can play them with browser. here is debug out
    TG4
    python widefrog.py "https://www.tg4.ie/ga/player/catagoir/dramaiocht/seinn/?pid=5833836741001&title=F%C3%ADorghael&series=Oscailt&genre=Drama" --debug
    [INFO] Linux detected. Chosen terminal: xterm. Chosen shell: bash.
    [INFO] Current app version: 3.2.0
    [INFO] Running on: linux/64bit/python 3.12.12
    [INFO] Starting the service initialization stage.
      File "/app/widefrog.py", line 124, in <module>
        main_service.run_service(response)
      File "/app/utils/main_service.py", line 442, in run_service
        dwn_cmds, failed_cmds, proc_cmds = main_service.get_download_commands_parallel(demo_urls)
      File "/app/utils/main_service.py", line 374, in get_download_commands_parallel
        source_urls, failures = main_service.initialize_services(source_urls)
      File "/app/utils/main_service.py", line 361, in initialize_services
        if service_tools.get_service(source_url) is not None:
      File "/app/utils/tools/service.py", line 70, in get_service
        raise e
      File "/app/utils/tools/service.py", line 54, in get_service
        service = service.initialize_service()
      File "/app/services/tg4_ie.py", line 76, in initialize_service
        tg4_ie.API_DICT = tg4_ie.get_api_dict()
      File "/app/services/tg4_ie.py", line 51, in get_api_dict
        response = re.findall(r'src="([^"]*index\.min\.js)"', response)[0]
    IndexError: list index out of range
    VirginMediaPlayer
    python widefrog.py "https://play.virginmediatelevision.ie/shows/44082036-3212-11ef-bd6d-020f80c0527e/coronation-street" --query=65:11409:65:11410 --debug
    [INFO] Current progress: [1/1]
    [INFO] Starting the collections extraction stage.
    [INFO] Starting the media data extraction stage.
    [INFO] Finished generating the download commands.
    [WARNING] No download commands have been generated.
    python widefrog.py "https://play.virginmediatelevision.ie/watch/replay/19084759/irelands-education-crisis" --debug
      File "/app/utils/main_service.py", line 395, in get_download_commands_parallel
        success, fail, proc = future.result()
      File "/usr/local/lib/python3.12/concurrent/futures/_base.py", line 449, in result
        return self.__get_result()
      File "/usr/local/lib/python3.12/concurrent/futures/_base.py", line 401, in __get_result
        raise self._exception
      File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 59, in run
        result = self.fn(*self.args, **self.kwargs)
      File "/app/utils/main_service.py", line 281, in get_download_commands
        raise e
      File "/app/utils/main_service.py", line 266, in get_download_commands
        dl_cmds, pr_cmds = main_service.get_download_command(service, source_element)
      File "/app/utils/main_service.py", line 89, in get_download_command
        raise e
      File "/app/utils/main_service.py", line 63, in get_download_command
        manifest, pssh, additional = service.get_video_data(source_element)
      File "/app/services/play_virginmediatelevision_ie.py", line 72, in get_video_data
        response = json.loads(response)["response"]
    KeyError: 'response'
    I believe that virginmedia have made some changes recently which could be the cause of that failing.
  22. mtv.fi doesn't work does someone knows how to fix it
  23. Member
    Jan 2022
    France
    perfect, thanks a lot!
  24. When I download from WideFrog, it automatically downloads in the highest quality. I want to be able to choose the quality myself, not automatically.
  25. has anyone tried using the watch.globaltv.com service lately? I always get the following error when trying to download even the sample urls (first time user):
    python widefrog.py --debug "https://watch.globaltv.com/series/f7a04c78-c1ff-11ee-ac50-0242ac110005/collection/4f809a02-caa1-11ee-abe3-0242ac110004/"
    output:
    File "C:\widefrog\widefrog.py", line 124, in <module>
    File "C:\widefrog\utils\main_service.py", line 442, in run_service
    dwn_cmds, failed_cmds, proc_cmds = main_service.get_download_commands_parallel(demo_u rls)
    File "C:\widefrog\utils\main_service.py", line 374, in get_download_commands_parallel
    File "C:\widefrog\utils\main_service.py", line 361, in initialize_services
    File "C:\widefrog\utils\tools\service.py", line 70, in get_service
    raise e
    File "C:\widefrog\utils\tools\service.py", line 54, in get_service
    File "C:\widefrog\services\watch_globaltv_com.py", line 106, in initialize_service
    watch_globaltv_com.APP_ID = watch_globaltv_com.get_application_id()
    File "C:\widefrog\services\watch_globaltv_com.py", line 92, in get_application_id
    main_js = re.findall(
    the code on line 96 appears to grab the first element and it must not have been found:
    r'src="(/static/js/main.*?\.js)"',
    requests.get(watch_globaltv_com.BASE_URL).content. decode()
    )[0]
    Michael Brown
    360 Replays Ltd.
  26. Member
    Oct 2025
    Canda
    You can try: https://github.com/Arrowar/StreamingCommunity
  27. Thanks for the tool but it's a mega pain with the GLIBC_2.38 requirement. I'm on the latest, up to date Debian, which comes with GLIBC 2.36 so I can't use this tool.
    Env is of no use so the only way to use WF is to upgrade my GLIBC and risk/probably screw my entire system up.
  28. I don't understand: "widefrog" has no direct dependency on glibc (of course indirectly because of the Python requirement, but that does come with Debian). So which software are you talking about? If it is not "widefrog", you should consider creating a new thread...
    (And if there is a chance to update to glibc-2.38: you shouldn't experience any compatibility issues. If possible, create a backup before upgrade.)
    Or do you mean the the widefrog linux binary from the start post? But that's require glibc >= 2.14.
  29. Originally Posted by Obo View Post
    Yep the linux binary, I get
    ./widefrog
    [63429] Failed to load Python shared library '/tmp/_MEIYj3H0D/libpython3.12.so.1.0': dlopen: /lib/x86_64-linux-gnu/libm.so.6: version `GLIBC_2.38' not found (required by /tmp/_MEIYj3H0D/libpython3.12.so.1.0)
    Updating to 2.38 would surely mess up my system. The latest Debian uses 2.36
     ldd --version
    ldd (Debian GLIBC 2.36-9+deb12u13) 2.36
