I'm trying to download from rakuten.tv
I dumped a CDM from Google Pixel as suggested, got everything installed right, followed every step and read everything more than twice...
but when I try to download, I'm getting this error:
I know the tool is working because I succeed to downloaded from other sites...Code:[USER_ERROR] Failed to download: from rakuten_tv. Reason: Bad device id. Solution: Change the device id in the service script file.
As suggested in the error message, I went to the rakuten_tv.py and changed the device id to all the options listed there... none of it worked...
What should I do now?
Results 421 to 450 of 581
i'm using widefrog for a couples of months and it's very usefull
now i have a problem with tf1.fr download series
i have paid residentiel proxy and it's work fine
but with series that have many episodes i have errors at " collections extraction stage" like this
i'm about to download saison of tf1/ici-tout-commence/videos/saison-5raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='www.tf1.fr', port=443): Max retries exceeded with url: /tf1/ici-tout-commence/videos/saison-5/187 (Caused by SSLError(SSLError(1, '[SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1145)')))
and it's stuck on episode 187 i think
also i don't progress like before exp [3/250] ....[INFO] Starting the service initialization stage.
[INFO] Current progress: [1/1]
[INFO] Starting the collections extraction stage.
urllib3.exceptions.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1145)
The above exception was the direct cause of the following exception:
what is the solution please -
Hi,
It seems goplay.be has changed some things. I can download the first 5 episodes of "de mol" just fine but from episode 6 and on it doesnt seem to work anymore.
[Attachment 86932 - Click to enlarge]Last edited by vorathan; 11th May 2025 at 07:50.
Thank you very much for those scripts 2nHxWW6GkN1l916N3ayz8HQoi , thanks to you I've been learning python and scripting. It works like a charm!
One question regarding the --query= parameter. Neither me nor any LLM has been able to pierce its secrets. I've tried on tf1.fr and m6.fr without any success. What should be --query= if I want the first x videos of the first line of the first rail on a show page such as this one: https://www.tf1.fr/tmc/quotidien-avec-yann-barthes/videos/replay or this one https://www.m6.fr/cauchemar-en-cuisine-avec-philippe-etchebest-p_841
I've performed a ton of tests and the best I can get is the first 2 videos or all/100 videos of the page.
Thank you again for sharing your excellent work with us! -
Hello,
Downloading from VRT seems not to work anymore?
For instance, the following download (logged in, content plays fine in Firefox):
Anyone else experiencing issues with VRT?Code:> python widefrog.py "https://www.vrt.be/vrtmax/a-z/campus-cup/6/de-campus-cup-s6a1/" [WARNING] The service veeps.com cannot be used because it is not properly implemented, has package errors or has syntax errors. After fixing the issue delete the app_files folder. [INFO] Current app version: 3.2.0 [INFO] Running on: windows/64bit/python 3.10.11 [INFO] Starting the service initialization stage. [INFO] Current progress: [1/1] [INFO] Starting the collections extraction stage. [INFO] Current progress: [1/1] [INFO] Starting the media data extraction stage. [USER_ERROR]/[APP_ERROR] Failed to download: https://www.vrt.be/vrtmax/a-z/campus-cup/6/de-campus-cup-s6a1. Reason: Failed to extract content data. Solution: Make sure you can play the content. If you can, then debug the vrt_be service. [INFO] Finished generating the download commands. [WARNING] Saved the failed URLs to app_files\cmds_failed.txt [WARNING] No download commands have been generated.
widevineproxy2 work fine
Code:N_m3u8DL-RE "https://remix.vrtcdn.be/content/vod/pl-7fd9dd84-82f6-484c-af62-1347ae503b24/pl-7fd9dd84-82f6-484c-af62-1347ae503b24_drm_5e352487-e8df-4aa0-b2d2-9c52050cd1f8.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/136.0.0.0 Safari/537.36" -H "Accept: */*" -H "Origin: https://www.vrt.be" -H "Referer: https://www.vrt.be/" --key 0bfb25d0f450e4b7c290fbf3b0ef5053:ec8d52126cd726a410bc1c796e30aafc --use-shaka-packager -M format=mkv
[Attachment 87071 - Click to enlarge] -
Did not yet know about widevindeproxy2, what an eye-opener.
Thanks for your quick help! -
First of all, thank you so much for this project!
I have been using this for a week now and I'm amazed! Today I tried downloading an episode from GoPlay and I got the following error:
python widefrog.py "https://www.goplay.be/video/achter-de-schermen/achter-de-schermen-s5/achter-de-schermen-s5-aflevering-17"
[INFO] Running on: windows/64bit/python 3.12.3
[APP_ERROR] Failed to download: https://www.goplay.be/video/achter-de-schermen/achter-de-schermen-s5/achter-de-scherme...-aflevering-17. Reason: Manifest format not supported: https://dai.google.com/ondemand/dash/content/2615619/vid/10153867490198527/GRQ/streams...6/manifest.mpd. Solution: Extend the goplay_be service.
(venv) D:\XXX\XXX\Widefrog>
Is there something obvious I'm doing wrong? When I try downloading the complete series, most seem to work, example:
[INFO] Current progress: [95/144]
[INFO] Current progress: [96/144]
[APP_ERROR] Failed to download: https://www.goplay.be/video/achter-de-schermen/achter-de-schermen-s5/achter-de-scherme...2-aflevering-1. Reason: Manifest format not supported: https://dai.google.com/ondemand/dash/content/2615619/vid/10153867526682527/GRQ/streams...d/manifest.mpd. Solution: Extend the goplay_be service.
[INFO] Current progress: [97/144]
Hopefully this is clear, thank you! -
Change goplay_be.py file @line 186-193 and paste:
No support on this code. There is always a better way. For me it works fine.Code:try: segment_timeline = representation["SegmentTemplate"]["SegmentTimeline"] if loop == 0: goplay_be.extend_dict( segment_dict, segment_key, segment_timeline ) else: representation["SegmentTemplate"]["SegmentTimeline"] = segment_dict[segment_key] except KeyError: print("SegmentTimeline or SegmentTemplate not found (using try-except).") -
I am currently having problems using the tool with plus.rtl.de, it used to work fine.
Getting the error:
Does anybody know what has changed?Code:❯ python widefrog.py https://plus.rtl.de/video-tv/serien/pokemon-horizonte-die-serie-988360/ --debug [INFO] Current app version: 3.2.0 [INFO] Running on: linux/64bit/python 3.13.3 [INFO] Starting the service initialization stage. [INFO] Current progress: [1/1] [INFO] Starting the collections extraction stage. [INFO] Current progress: [1/1] [INFO] Starting the media data extraction stage. Traceback (most recent call last): File "/home/user/Widefrog-3.2/widefrog.py", line 124, in <module> main_service.run_service(response) ~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^ File "/home/user/Widefrog-3.2/utils/main_service.py", line 442, in run_service dwn_cmds, failed_cmds, proc_cmds = main_service.get_download_commands_parallel(demo_urls) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^ File "/home/user/Widefrog-3.2/utils/main_service.py", line 395, in get_download_commands_parallel success, fail, proc = future.result() ~~~~~~~~~~~~~^^ File "/usr/lib/python3.13/concurrent/futures/_base.py", line 449, in result return self.__get_result() ~~~~~~~~~~~~~~~~~^^ File "/usr/lib/python3.13/concurrent/futures/_base.py", line 401, in __get_result raise self._exception File "/usr/lib/python3.13/concurrent/futures/thread.py", line 59, in run result = self.fn(*self.args, **self.kwargs) File "/home/user/Widefrog-3.2/utils/main_service.py", line 281, in get_download_commands raise e File "/home/user/Widefrog-3.2/utils/main_service.py", line 266, in get_download_commands dl_cmds, pr_cmds = main_service.get_download_command(service, source_element) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/user/Widefrog-3.2/utils/main_service.py", line 89, in get_download_command raise e File "/home/user/Widefrog-3.2/utils/main_service.py", line 63, in get_download_command manifest, pssh, additional = service.get_video_data(source_element) ~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^ File "/home/user/Widefrog-3.2/services/plus_rtl_de.py", line 490, in get_video_data video_contents = sorted( ~~~~~~~ video_contents, key=lambda vc: plus_rtl_de.RES_PRIORITY[vc[2]], reverse=True ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ )[0] ~^^^ IndexError: list index out of range -
It didn't for me...
And I did try your fix:Code:(venv) erik@piholeNASLXC:~/schrapen/widefrog$ python widefrog.py "https://www.goplay.be/video/achter-de-schermen/achter-de-schermen-s5/achter-de-schermen-s5-aflevering-17" --debug [INFO] Linux detected. Chosen terminal: gnome-terminal. Chosen shell: bash. [INFO] Current app version: 3.2.0 [INFO] Running on: linux/64bit/python 3.11.2 [INFO] Starting the service initialization stage. [INFO] Current progress: [1/1] [INFO] Starting the collections extraction stage. [INFO] Current progress: [1/1] [INFO] Starting the media data extraction stage. Traceback (most recent call last): File "/home/erik/schrapen/widefrog/services/goplay_be.py", line 347, in get_video_data manifest = goplay_be.generate_master_mpd(source_element, mpd_content) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/erik/schrapen/widefrog/services/goplay_be.py", line 189, in generate_master_mpd segment_dict, segment_key, ^^^^^^^^^^^ NameError: name 'segment_key' is not defined. Did you mean: 'segment_dict'? During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/home/erik/schrapen/widefrog/widefrog.py", line 124, in <module> main_service.run_service(response) File "/home/erik/schrapen/widefrog/utils/main_service.py", line 442, in run_service dwn_cmds, failed_cmds, proc_cmds = main_service.get_download_commands_parallel(demo_urls) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/erik/schrapen/widefrog/utils/main_service.py", line 395, in get_download_commands_parallel success, fail, proc = future.result() ^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/_base.py", line 449, in result return self.__get_result() ^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/_base.py", line 401, in __get_result raise self._exception File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/erik/schrapen/widefrog/utils/main_service.py", line 281, in get_download_commands raise e File "/home/erik/schrapen/widefrog/utils/main_service.py", line 266, in get_download_commands dl_cmds, pr_cmds = main_service.get_download_command(service, source_element) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/erik/schrapen/widefrog/utils/main_service.py", line 84, in get_download_command raise e File "/home/erik/schrapen/widefrog/utils/main_service.py", line 63, in get_download_command manifest, pssh, additional = service.get_video_data(source_element) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/erik/schrapen/widefrog/services/goplay_be.py", line 349, in get_video_data raise CustomException(ERR_MSG.format( utils.structs.CustomException: [APP_ERROR] Failed to download: https://www.goplay.be/video/achter-de-schermen/achter-de-schermen-s5/achter-de-schermen-s5-aflevering-17. Reason: Manifest format not supported: https://dai.google.com/ondemand/dash/content/2615619/vid/10153867490198527/GRQ/streams/1c8dda8a-0154-4c96-8652-fdeef46b2664/manifest.mpd. Solution: Extend the goplay_be service.
I made sure I was able to see the video in Firefox, so the cookies seem okay as well...?Code:(venv) erik@piholeNASLXC:~/schrapen/widefrog$ cat services/goplay_be.py import base64 import builtins import json import os import re from os.path import join import browser_cookie3 import requests import xmltodict from utils.constants.macros import USER_ERROR, ERR_MSG, APP_ERROR from utils.main_service import main_service from utils.structs import BaseElement, CustomException, BaseService from utils.tools.args import check_range from utils.tools.cdm import get_pssh_from_cenc_pssh from utils.tools.common import get_valid_filename, clean_url class goplay_be(BaseService): DEMO_URLS = [ "https://www.goplay.be/video/nonkels/de", "https://www.goplay.be/video/maxine/maxine/maxine-s1-aflevering-2", "https://www.goplay.be/video/left-for-dead-the-ashley-reeves-story", "https://www.goplay.be/video/jodi-arias-dirty-little-secret-1", "https://www.goplay.be/vermist", "https://www.goplay.be/de-spor", "https://www.goplay.be/de-expeditie", ] CONTENT_URL = "https://api.goplay.be/web/v1/videos/{content_type}/{uuid}" STREAM_URL = 'https://dai.google.com/ondemand/dash/content/{content_id}/vid/{video_id}/streams' LICENSE_URL = "https://widevine.keyos.com/api/v4/getLicense" BASE_URL = "https://www.goplay.be" BEARER_TOKEN = None AMZ_JSON = 'application/x-amz-json-1.1' @staticmethod def test_service(): main_service.run_service(goplay_be) @staticmethod def get_additional_params(additional): additional_params = BaseService.get_additional_params(additional) manifest_url = additional.get("manifest_url", None) if manifest_url is not None: manifest_url = clean_url(manifest_url) additional_params = [( "BASE_URL", lambda s: s.format(value=manifest_url) )] + additional_params return additional_params @staticmethod def credentials_needed(): return {"FIREFOX_COOKIES": True} @staticmethod def get_bearer(): cookie_dict = {} check_cookies = {} check_list = ["accesstoken", "refreshtoken"] for c in browser_cookie3.firefox(domain_name='goplay.be'): cookie_dict[c.name] = c.value cookie_name = c.name.lower() for f in check_list: if f in cookie_name: check_cookies[f] = True if len(cookie_dict.keys()) == 0 or len(check_cookies.keys()) != len(check_list): return None refresh_token = None client_id = None refresh_url = None for c, v in cookie_dict.items(): c_name = c.lower() if "accesstoken" in c_name: refresh_url = json.loads(base64.b64decode(v.split(".")[1] + "==").decode())["iss"] refresh_url = "/".join(refresh_url.split("/")[:-1]) + "/" if "refreshtoken" in c_name: refresh_token = v client_id = c.split(".")[1] if refresh_url is not None and refresh_token is not None: break assert len(refresh_token) > 0 assert len(client_id) > 0 assert len(refresh_url) > 0 response = requests.post( refresh_url, headers={ 'content-type': goplay_be.AMZ_JSON, 'x-amz-target': 'AWSCognitoIdentityProviderService.InitiateAuth' }, data=json.dumps({ "ClientId": client_id, "AuthFlow": "REFRESH_TOKEN_AUTH", "AuthParameters": {"REFRESH_TOKEN": refresh_token} }) ) response = response.content.decode() response = json.loads(response) return response["AuthenticationResult"]["AccessToken"] @staticmethod def initialize_service(): if goplay_be.BEARER_TOKEN is None: goplay_be.BEARER_TOKEN = goplay_be.get_bearer() if goplay_be.BEARER_TOKEN is None: raise CustomException(ERR_MSG.format( type=USER_ERROR, url=f'from {goplay_be.__name__}', reason='Need account for this service', solution='Sign into your account using Firefox' )) return goplay_be @staticmethod def get_keys(challenge, additional): licence = requests.post( goplay_be.LICENSE_URL, data=challenge, headers={"customdata": additional["drm_token"]} ) licence.raise_for_status() return licence.content @staticmethod def extend_dict(input_dict, input_key, input_value): old_value = input_dict.get(input_key, None) if old_value is None: input_dict[input_key] = input_value return input_dict for k1, v1 in input_value.items(): if v1 is None: continue if type(v1) is not list: v1 = [v1] v2 = old_value.get(k1, None) if v2 is None: old_value[k1] = v1 continue if type(v2) is not list: v2 = [v2] v2.extend(v1) old_value[k1] = v2 input_dict[input_key] = old_value @staticmethod def generate_master_mpd(source_element, mpd_content): xml_dict = xmltodict.parse(mpd_content) xml_node = xml_dict["MPD"] new_nodes = [] xml_periods = xml_node["Period"] if type(xml_periods) is not list: xml_periods = [xml_periods] for period in xml_periods: if "-ad-" in period["@id"]: continue new_nodes.append(period) segment_dict = {} assert len(new_nodes) >= 1 for loop in range(0, 2): if loop == 1: new_nodes = [new_nodes[0]] for node in new_nodes: adaptations = node["AdaptationSet"] if type(adaptations) is not list: adaptations = [adaptations] for adaptation in adaptations: representations = adaptation["Representation"] if type(representations) is not list: representations = [representations] for representation in representations: try: segment_timeline = representation["SegmentTemplate"]["SegmentTimeline"] if loop == 0: goplay_be.extend_dict( segment_dict, segment_key, segment_timeline ) else: representation["SegmentTemplate"]["SegmentTimeline"] = segment_dict[segment_key] except KeyError: print("SegmentTimeline or SegmentTemplate not found (using try-except).") xml_dict["MPD"]["Period"] = new_nodes mpd_content = xmltodict.unparse(xml_dict, pretty=True) output_path = join(source_element.collection, source_element.element) if not os.path.exists(output_path): os.makedirs(output_path) output_path = join(str(output_path), "master.mpd") with open(output_path, "w") as f: f.write(mpd_content) return output_path @staticmethod def get_video_data(source_element): response = requests.get(source_element.url, headers={'Accept': 'application/json'}) response = json.loads(response.content.decode()) if response.get("uuid", None) in ["", None]: raise CustomException(ERR_MSG.format( type=f'{USER_ERROR}', url=source_element.url, reason="The content isn't available", solution="Do not attempt to download it" )) content_type = response["contentType"] content_type = re.sub(r'([a-z])([A-Z])', r'\1-\2', content_type).lower() response = requests.get( goplay_be.CONTENT_URL.format(content_type=content_type, uuid=response["uuid"]), headers={'Authorization': f'Bearer {goplay_be.BEARER_TOKEN}'}, ) status_code = response.status_code response = json.loads(response.content.decode()) message = response.get("message", "").lower() if 400 <= status_code < 500 and "locked" in message: raise CustomException(ERR_MSG.format( type=f'{USER_ERROR}', url=source_element.url, reason="Need Belgian IP to access content", solution="Use a VPN" )) if source_element.element is None: try: program = response["tracking"]["cimName"] assert len(program) > 0 except: program = "" if program == "": try: program = response["tracking"]["piano"]["program"] assert len(program) > 0 except: program = "" else: program = "" try: title = response["title"] except: title = "" if title.lower() == program.lower(): title = "" if source_element.element is None: source_element.element = "" for f in ["seasonNumber", "episodeNumber"]: try: title += " " + f[0].upper() + str(int(response[f])) except: pass source_element.element = get_valid_filename(source_element.element + " " + program + " " + title) if source_element.element in ["", None]: source_element.element = source_element.url.split("/video/")[-1] source_element.element = get_valid_filename(source_element.element) if source_element.collection is None: source_element.collection = join( str(builtins.CONFIG["DOWNLOAD_COMMANDS"]["OUTPUT_MEDIA_PATH"]), goplay_be.__name__ ) drm_token = None try: is_drm = response["flags"]["isDrm"] assert is_drm drm_token = response["drmXml"] assert len(drm_token) > 0 and type(drm_token) is str is_drm = True except: is_drm = False try: manifest = response["manifestUrls"]["dash"] assert len(manifest) > 0 except: manifest = None if manifest is None: response = response["ssai"] response = requests.post(goplay_be.STREAM_URL.format( content_id=response["contentSourceID"], video_id=response["videoID"] )) try: assert 200 <= response.status_code < 300 response = response.content.decode() response = json.loads(response) except: raise CustomException(ERR_MSG.format( type=f'{USER_ERROR}/{APP_ERROR}', url=source_element.url, reason=f"Dash manifest not found", solution=f"If you can watch the video in browser, then extend the {goplay_be.__name__} service" )) manifest = response["stream_manifest"] if response.get("manifest_format", "dash").lower() not in ["dash", "mpd"]: raise CustomException(ERR_MSG.format( type=APP_ERROR, url=source_element.url, reason=f"Manifest format not supported: {manifest}", solution=f"Extend the {goplay_be.__name__} service" )) pssh_value = None additional = {"drm_token": drm_token} mpd_content = None if is_drm or builtins.CONFIG.get("BASIC", False) is False: mpd_content = requests.get(manifest).content.decode() if is_drm: try: pssh_value = get_pssh_from_cenc_pssh(mpd_content) except: pssh_value = None if pssh_value is None: raise CustomException(ERR_MSG.format( type=APP_ERROR, url=source_element.url, reason=f"Manifest format not supported: {manifest}", solution=f"Extend the {goplay_be.__name__} service" )) if builtins.CONFIG.get("BASIC", False) is True: return manifest, pssh_value, additional additional["manifest_url"] = manifest try: manifest = goplay_be.generate_master_mpd(source_element, mpd_content) except: raise CustomException(ERR_MSG.format( type=APP_ERROR, url=source_element.url, reason=f"Manifest format not supported: {manifest}", solution=f"Extend the {goplay_be.__name__} service" )) return manifest, pssh_value, additional @staticmethod def get_label_index(label, label_regex): if label is None or len(label) == 0: return None label = label.lower() label = re.sub(r'\s+', ' ', label) label = label.replace(' ', "_") for r in label_regex: try: return int(re.findall(r, label)[0]) except: pass return None @staticmethod def get_collection_elements(collection_url): collection_url = clean_url(collection_url) if "/live-kijken" in collection_url: return None if "/video/" in collection_url: return [BaseElement(url=collection_url)] response = requests.get(collection_url) response = response.content.decode() try: collection_title = re.findall(r'<title>([^<>]+)</title>', response)[0] collection_title = get_valid_filename(collection_title) assert len(collection_title) > 0 except: collection_title = collection_url.split("/")[-1] collection_title = join( join( str(builtins.CONFIG["DOWNLOAD_COMMANDS"]["OUTPUT_MEDIA_PATH"]), goplay_be.__name__ ), get_valid_filename(collection_title) ) videos = [] visited = [] for video in re.findall( fr'"([^"]*/video/{collection_url.split("/")[-1]}/[^\\"]+)[\\"]', response ): if not video.startswith("http"): video = goplay_be.BASE_URL + video if video in visited: continue visited.append(video) paths = video.split("/")[-2:] season_index = None episode_index = goplay_be.get_label_index( label=paths[-1], label_regex=["aflevering-(\\d+)"] ) if episode_index is not None: for i in [-1, -2]: season_index = goplay_be.get_label_index( label=paths[i], label_regex=["-s(\\d+)[-/]"] ) if season_index is not None: break if season_index is None: episode_index = None videos.append((video, season_index, episode_index)) extras = [v for v in videos if v[1] is None] videos = sorted([v for v in videos if v[1] is not None], key=lambda v: (v[1], v[2])) try: max_season = max(videos, key=lambda v: v[1])[1] + 1 except: max_season = 1 extras = [(v[0], max_season, i + 1) for i, v in enumerate(extras)] collection = [] for episode_url, season_index, episode_index in videos + extras: check = check_range(True, season_index, None) if check is True: continue elif check is False: return collection check = check_range(False, season_index, episode_index) if check is True: continue elif check is False: return collection season_title = "extras" if season_index == max_season else "" collection.append(BaseElement( url=episode_url, collection=join(collection_title, get_valid_filename(f'Season_{season_index} {season_title}')), element=f"Episode_{episode_index}" )) return collection
(I don't know whether it's possible to make these long code fields collapsable?)Last edited by ErikDB; 24th Jun 2025 at 10:16.
@ErikDB
I don't doubt you double checked and found out by yourself that you accidentally erased line 185 with the following code in the original file:
Code:segment_key = representation.get("@width", representation.get("@audioSamplingRate", None)) -
Thanks for the kind words.
Now the code doesn't break, but the result is still not satisfactory...
The last statement is rather misleading.Code:(venv) erik@piholeNASLXC:~/schrapen/widefrog$ python widefrog.py "https://www.goplay.be/video/achter-de-schermen/achter-de-schermen-s5/achter-de-schermen-s5-aflevering-17" --debug [INFO] Linux detected. Chosen terminal: gnome-terminal. Chosen shell: bash. [INFO] Current app version: 3.2.0 [INFO] Running on: linux/64bit/python 3.11.2 [INFO] Starting the service initialization stage. [INFO] Current progress: [1/1] [INFO] Starting the collections extraction stage. [INFO] Current progress: [1/1] [INFO] Starting the media data extraction stage. SegmentTimeline or SegmentTemplate not found (using try-except). SegmentTimeline or SegmentTemplate not found (using try-except). SegmentTimeline or SegmentTemplate not found (using try-except). SegmentTimeline or SegmentTemplate not found (using try-except). [INFO] Current progress: [1/1] [INFO] Finished generating the download commands. [INFO] Saved the generated download commands to app_files/cmds.txt [INFO] If you used a VPN, turn it off to avoid wasting data for the downloading stage. Also you may edit the app_files/cmds.txt file if necessary. Type yes when ready: yes [INFO] Starting the downloading stage. # Failed to parse arguments: Cannot open display: [INFO] SUCCESS! Finished downloading.
Edit: I keep forgetting I have to disable Pi-Hole for Go Play... Now I did, but the script returns the same output. Maybe because it ran into Pi-Hole's wall a minute ago? -
Something with vtmgo.be also refuses to work. I made sure I was able to see the video of the link in Firefox...
Code:(venv) erik@piholeNASLXC:~/schrapen/widefrog$ python widefrog.py "https://www.vtmgo.be/vtmgo/afspelen/90f3dd6c-c68b-4a87-8f1b-0b7ce44d1b12" --debug [INFO] Linux detected. Chosen terminal: gnome-terminal. Chosen shell: bash. [INFO] Current app version: 3.2.0 [INFO] Running on: linux/64bit/python 3.11.2 [INFO] Starting the service initialization stage. [INFO] Current progress: [1/1] [INFO] Starting the collections extraction stage. [INFO] Current progress: [1/1] [INFO] Starting the media data extraction stage. Traceback (most recent call last): File "/home/erik/schrapen/widefrog/widefrog.py", line 124, in <module> main_service.run_service(response) File "/home/erik/schrapen/widefrog/utils/main_service.py", line 442, in run_service dwn_cmds, failed_cmds, proc_cmds = main_service.get_download_commands_parallel(demo_urls) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/erik/schrapen/widefrog/utils/main_service.py", line 395, in get_download_commands_parallel success, fail, proc = future.result() ^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/_base.py", line 449, in result return self.__get_result() ^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/_base.py", line 401, in __get_result raise self._exception File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/erik/schrapen/widefrog/utils/main_service.py", line 281, in get_download_commands raise e File "/home/erik/schrapen/widefrog/utils/main_service.py", line 266, in get_download_commands dl_cmds, pr_cmds = main_service.get_download_command(service, source_element) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/erik/schrapen/widefrog/utils/main_service.py", line 84, in get_download_command raise e File "/home/erik/schrapen/widefrog/utils/main_service.py", line 63, in get_download_command manifest, pssh, additional = service.get_video_data(source_element) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/erik/schrapen/widefrog/services/vtmgo_be.py", line 125, in get_video_data raise CustomException(ERR_MSG.format( utils.structs.CustomException: [USER_ERROR]/[APP_ERROR] Failed to download: https://www.vtmgo.be/vtmgo/afspelen/90f3dd6c-c68b-4a87-8f1b-0b7ce44d1b12. Reason: This content is no longer available or refresh the site cookies or VPN issues (Belgium). Solution: Do not attempt to download it or sign into your account using Firefox and play a random video or fix your VPN. If it persists then debug the service. -
Hi,
When trying to download from VRT, I get the following error, any suggestions what I could change in the script (I'm not a coder). Thanks!
python widefrog.py "https://www.vrt.be/vrtmax/a-z/terzake/2025/terzake-d20250701/"
[INFO] Running on: windows/64bit/python 3.13.3
[USER_ERROR]/[APP_ERROR] Failed to download: https://www.vrt.be/vrtmax/a-z/terzake/2025/terzake-d20250701. Reason: Failed to extract content data. Solution: Make sure you can play the content. If you can, then debug the vrt_be service.
[WARNING] No download commands have been generated. -
netflix tudum is only downloading as AV1 codec. The script has an issue that is only getting manifest for AV1. Please fix..
First of all thanks for the great Widefrog script!
After installation i started the vtmgo video in firefox and run the Widefroq script but get the following output:
What do i wrong?Code:C:\Program Files\DRMTools\WideFrog>python widefrog.py https://www.vtmgo.be/vtmgo/afspelen/8e1c8756-ef7e-49e0-9d2d-54d42114852e [WARNING] OS architecture is not supported for launching the download commands. Detected architecture: 32bit. Allowed architectures: ['64bit']. [WARNING] The service --canalplus.com cannot be used because it is not properly implemented, has package errors or has syntax errors. After fixing the issue delete the app_files folder. [WARNING] The service cda.pl cannot be used because it is not properly implemented, has package errors or has syntax errors. After fixing the issue delete the app_files folder. [INFO] Current app version: 3.2.0 [INFO] Running on: windows/32bit/python 3.11.6 [INFO] Starting the service initialization stage. [USER_ERROR] Failed to download: from vtmgo_be. Reason: Need account for this service. Solution: Sign into your account using Firefox. [INFO] Current progress: [1/1] [INFO] Starting the collections extraction stage. [INFO] Starting the media data extraction stage. [INFO] Finished generating the download commands. [WARNING] Saved the failed URLs to app_files\cmds_failed.txt [WARNING] No download commands have been generated.
How can i solve several warning messages?Last edited by RafiV; 11th Jul 2025 at 07:59.
Good evening,
I performed a release upgrade from Ubuntu 22.04 to 24.04.2 today. Now the Python script no longer works:
Best regardsCode:heiko@Worf:~/Downloads/Widefrog v3.2.0$ python3 widefrog.py https://plus.rtl.de/video-tv/serien/unter-uns-41137/2025-7-1034565/episode-7661-patrizias-neuer-feind-1002320 Traceback (most recent call last): File "/home/heiko/Downloads/Widefrog v3.2.0/widefrog.py", line 6, in <module> from utils.main_service import main_service File "/home/heiko/Downloads/Widefrog v3.2.0/utils/main_service.py", line 12, in <module> import utils.tools.common as common_tools File "/home/heiko/Downloads/Widefrog v3.2.0/utils/tools/common.py", line 9, in <module> import numpy as np ModuleNotFoundError: No module named 'numpy' heiko@Worf:~/Downloads/Widefrog v3.2.0$
Heiko -
Good day.
What do you mean by newly installed? Widefrog.py? I didn't change anything about it.
Best regards
Heiko -
Hello,
I have re-downloaded Widefrog v3.2.0 and the required files on a virtual Ubuntu 22.04. I can now download it from joyn.de.
I did everything without venv.
Numpy seems to be missing on 24.04:
heiko@Worf:~/Downloads/Widefrog v3.2.0.bak$ python3
Python 3.12.3 (main, Jun 18 2025, 17:59:45) [GCC 13.3.0] on Linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import numpy as np
File "<stdin>", line 1, in <module>
Best regards -
I tried the kijk.nl service but got the following error:
Code:(venv) C:\widefrog>python widefrog.py --debug "https://www.kijk.nl/programmas/de-volgers/wsRr1AM5FS5" [INFO] Current app version: 3.2.0 [INFO] Running on: windows/64bit/python 3.11.1 [INFO] Starting the service initialization stage. Traceback (most recent call last): File "C:\widefrog\widefrog.py", line 124, in <module> main_service.run_service(response) File "C:\widefrog\utils\main_service.py", line 442, in run_service dwn_cmds, failed_cmds, proc_cmds = main_service.get_download_commands_parallel(demo_urls) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\widefrog\utils\main_service.py", line 374, in get_download_commands_parallel source_urls, failures = main_service.initialize_services(source_urls) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\widefrog\utils\main_service.py", line 361, in initialize_services if service_tools.get_service(source_url) is not None: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\widefrog\utils\tools\service.py", line 70, in get_service raise e File "C:\widefrog\utils\tools\service.py", line 54, in get_service service = service.initialize_service() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\widefrog\services\kijk_nl.py", line 60, in initialize_service kijk_nl.GRAPHQL_URL, kijk_nl.DRM_TOKEN = kijk_nl.get_site_info() ^^^^^^^^^^^^^^^^^^^^^^^ File "C:\widefrog\services\kijk_nl.py", line 47, in get_site_info graphql_url = json.loads(re.findall( ^^^^^^^^^^^^^^^^^^^^^^ KeyError: 'props'
Batch IMDB Image Downloader
By Jay123210599 in forum ComputerReplies: 3Last Post: 11th Jan 2024, 12:02 -
Help downloading DRM protected content
By edenshapira in forum Video Streaming DownloadingReplies: 0Last Post: 28th Oct 2023, 14:59 -
Downloading DRM protected content from mewatch.sg
By notred in forum Video Streaming DownloadingReplies: 4Last Post: 25th Nov 2022, 04:34 -
Weird Behaviour Of DRM Protected Content
By portalie in forum Video Streaming DownloadingReplies: 1Last Post: 6th Feb 2022, 15:10
