Page 14 of 19
FirstFirst ... 4 12 13 14 15 16 ... LastLast
Results 391 to 420 of 546
  1. app_files/config.json
  2. How can I assign N_m3u8DL-RE to a system environment variable?
  3. Thank you.
    I finally understood.
    It should be written like this C:\Users\ %User name% \Desktop\N_m3u8DL-RE_v0.3.0-beta_win-x64_20241203 not like this C:\Users\%User name% \Desktop\N_m3u8DL-RE_v0.3.0-beta_win-x64_20241203\N_m3u8DL-RE.exe
    You also need to go to the folder with the cd command and run it in that location. Otherwise it gives the error “terminal is missing”.
  4. Hello everyone,
    I've recently been getting this error on plus.rtl.de:
    heiko@Worf:~/Downloads/Widefrog v3.2.0$ python3 widefrog.py https://plus.rtl.de/video-tv/serien/unter-uns-41137/2025-3-1023007/episode-7591-streit...-preis-1002250
    [INFO] Linux detected. Chosen terminal: gnome-terminal. Chosen shell: bash.
    [WARNING] Terminal script can't be executed: terminal/mkvmerge.sh. Insufficient privileges. Download commands won't be launched properly.
    [INFO] Current app version: 3.2.0
    [INFO] Running on: linux/64bit/python 3.10.12
    [INFO] Starting the service initialization stage.
    [INFO] Current progress: [1/1]
    [INFO] Starting the collections extraction stage.
    [INFO] Starting the media data extraction stage.
    [USER_ERROR]/[APP_ERROR] Failed to download: https://plus.rtl.de/video-tv/serien/unter-uns-41137/2025-3-1023007/episode-7591-streit...-preis-1002250. Reason: Failed to extract content data. Solution: Make sure you can play the content. If you can, then debug the plus_rtl_de service.
    [INFO] Finished generating the download commands.
    [WARNING] Saved the failed URLs to app_files/cmds_failed.txt
    [WARNING] No download commands have been generated.
    What can I do?
    Best regards
    Heiko
  5. RTL changed the API to a new one.
  6. Hello everyone,
    What can I do?
    Best regards
    Heiko
  7. Wait until @2nHxWW6GkN1l916N3ayz8HQoi can fix the issue. It's a simple change on RTL's side - they changed the URL from where they serve mpd and license urls.
  8. They also changed the API Answer itself it now has no "data" part anymore but should be a quick fix.
    Also now its a lot simpler to make the API request because no hash anymore.
  9. Jep. However, I think it's better not to remove the old graphql query yet, since the browser uses both requests. Overall a simple fix, but @2nHxWW6GkN1l916N3ayz8HQoi has to refactor part of the service script.
  10. Guys i can't download from shahid vip contanant only free contanant , netflix too doesn't work !! anymore
  11. I have a direct link from the FIFA+ website
    https://www.plus.fifa.com/en/player/8ff49a0b-1ba1-4ab1-965e-c37da2602c15?catalogId=690679f3-08c5-4d5b-a138-5aabc3caea6e
    and when I put it this in (Widefrog) to convert it to command it will be like this
    N_m3u8DL-RE "http://d33tkx2907c8gi.cloudfront.net/s/vod/main_102/FIM102241-M00_v05.1c824598_SDR_20230630-1708/FIM102241-M00_v05.1c824598_SDR.eng_mul.h264_SDHDP.cenc_subs.mpd" --key 794ec4ff1c27797c83ab0d9ee5d95e81:e08aa648a8d021299ff28731ca52a4c4 --tmp-dir "media\tmp\NgIokiz" --save-dir "media\plus_fifa_com\Brazil_v_Netherlands_Semi-finals_1998_FIFA_World_Cup_Francetm_Highlights" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv:muxer=mkvmerge & "terminal\mkvmerge.bat" "media\plus_fifa_com\Brazil_v_Netherlands_Semi-finals_1998_FIFA_World_Cup_Francetm_Highlights.mkv" "media\plus_fifa_com\Brazil_v_Netherlands_Semi-finals_1998_FIFA_World_Cup_Francetm_Highlights" true & rd /s /q "media\tmp\NgIokiz"
    Thus, when I download the command through (N_m3u8DL-RE), it create a folder and inside the video file, and what I want is that the video file is outside the folder, and It does not create folder.
    [Attachment 86534 - Click to enlarge]
    Can anyone give me the correct config.json code to do that?
    ** and this is the code what I used in (Widefrog)
    FOR /F %A in (text.txt) DO widefrog.exe %A
  12. If you use .bat or .cmd
    FOR /F %%A in (text.txt) DO widefrog.exe %%A
    Double %
  13. Originally Posted by Lostion View Post
    Double %
    It didn't work for me
    [Attachment 86540 - Click to enlarge]
  14. In a .bat/.cmd file not directly in command line.
    What are you even want to try?
  15. test
    Last edited by khaledgamil; 17th Apr 2025 at 04:14. Reason: delete this post please
  16. I would like to run the program on my headless Debian NAS, but that raises a challenge with cookies of course. I located Firefox's "cookies.sqlite" file on my Windows machine, but I can't figure out where to put it, so "browser_cookie3" finds it on the Debian machine... Any advice is welcome
  17. I'd thought I'd try emulating the Firefox profile folder, but I didn't get there yet:
    (venv) erik@piholeNASLXC:~/schrapen/widefrog$ sudo apt-get install firefox
    Reading package lists... Done
    Building dependency tree... Done
    Reading state information... Done
    firefox is already the newest version (137.0.1~build1).
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    (venv) erik@piholeNASLXC:~/schrapen/widefrog$ python widefrog.py
    [WARNING] Firefox browser is not installed. Services that require browser cookies won't work as intended.
    Firefox is installed, no?
    At first, I thought it could have something to do with this:
    (venv) erik@piholeNASLXC:~/schrapen/widefrog$ playwright install
    Playwright Host validation warning:
    ║ Host system is missing dependencies to run browsers. ║
    ║ Missing libraries:                                   ║
    ║     libgtk-4.so.1                                    ║
    ║     libwoff2dec.so.1.0.2                             ║
    ║     libgstcodecparsers-1.0.so.0                      ║
    ║     libwebpdemux.so.2                                ║
    ║     libharfbuzz-icu.so.0                             ║
    ║     libenchant-2.so.2                                ║
    ║     libsecret-1.so.0                                 ║
    ║     libhyphen.so.0                                   ║
    ║     libmanette-0.2.so.0                              ║
    ║     libGLESv2.so.2                                   ║
        at validateDependenciesLinux (/home/erik/schrapen/widefrog/venv/lib/python3.11/site-packages/playwright/driver/package/lib/server/registry/dependencies.js:216:9)
        at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
        at async Registry._validateHostRequirements (/home/erik/schrapen/widefrog/venv/lib/python3.11/site-packages/playwright/driver/package/lib/server/registry/index.js:859:52)
        at async Registry._validateHostRequirementsForExecutableIfNeeded (/home/erik/schrapen/widefrog/venv/lib/python3.11/site-packages/playwright/driver/package/lib/server/registry/index.js:957:7)
        at async Registry.validateHostRequirementsForExecutablesIfNeeded (/home/erik/schrapen/widefrog/venv/lib/python3.11/site-packages/playwright/driver/package/lib/server/registry/index.js:946:43)
        at async t.<anonymous> (/home/erik/schrapen/widefrog/venv/lib/python3.11/site-packages/playwright/driver/package/lib/cli/program.js:122:7)
    But then I ran `playwright install-deps`, after some googling, and now that problem is gone, but the earlier isn't:
  18. Test
    Last edited by khaledgamil; 18th Apr 2025 at 09:50. Reason: Delete this post please
  19. Hello,
    How to download the 15 episodes of the 2025 season from the RTLPlay website: https://www.rtlplay.be/rtlplay/enquetes~2ab5e679-ca29-4474-ae8c-433bf9995915
    best regards
    Feb 2022
    Search the forum first!
    @2nHxWW6GkN1l916N3ayz8HQoi Your software suite has been around a good while now. I'd seen it earlier, of course, but never had occasion to use it. Now I have; salutations for an excellent job. No other downloader has so many services. Widefrog must be regarded as supreme!
    Noob Starter Pack. Just download any Widevine media! Over 22,000 downloads for V6!.
  21. Originally Posted by ErikDB View Post
    [Something about complaints because allegedly, Firefox was not installed.]
    I went ahead and tried downloading anyway (using this URL: https://www.goplay.be/video/callboys/callboys-s2/callboys-s2-de-muur-als-symbool-van-wat-dan-is). It worked.
    BUT I had to fix `[venv]/lib/python3.11/site-packages/browser_cookie3/__init__.py`, as described here: https://github.com/borisbabic/browser_cookie3/issues/211.
  22. If I try to download https://www.vtmgo.be/vtmgo/afspelen/9ba7e6ce-a77b-46fb-ad3b-719881c603ec on my headless Debian (which succeeded in downloading from Go Play), I see this:
    (venv) erik@piholeNASLXC:~/schrapen/widefrog$ python widefrog.py --debug "https://www.vtmgo.be/vtmgo/afspelen/9ba7e6ce-a77b-46fb-ad3b-719881c603ec"
    [INFO] Running on: linux/64bit/python 3.11.2
      File "/home/erik/schrapen/widefrog/widefrog.py", line 124, in <module>
        main_service.run_service(response)
      File "/home/erik/schrapen/widefrog/utils/main_service.py", line 442, in run_service
        dwn_cmds, failed_cmds, proc_cmds = main_service.get_download_commands_parallel(demo_urls)
      File "/home/erik/schrapen/widefrog/utils/main_service.py", line 395, in get_download_commands_parallel
        success, fail, proc = future.result()
      File "/usr/lib/python3.11/concurrent/futures/_base.py", line 449, in result
        return self.__get_result()
      File "/usr/lib/python3.11/concurrent/futures/_base.py", line 401, in __get_result
        raise self._exception
      File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
        result = self.fn(*self.args, **self.kwargs)
      File "/home/erik/schrapen/widefrog/utils/main_service.py", line 281, in get_download_commands
        raise e
      File "/home/erik/schrapen/widefrog/utils/main_service.py", line 266, in get_download_commands
        dl_cmds, pr_cmds = main_service.get_download_command(service, source_element)
      File "/home/erik/schrapen/widefrog/utils/main_service.py", line 84, in get_download_command
        raise e
      File "/home/erik/schrapen/widefrog/utils/main_service.py", line 63, in get_download_command
        manifest, pssh, additional = service.get_video_data(source_element)
      File "/home/erik/schrapen/widefrog/services/vtmgo_be.py", line 125, in get_video_data
        raise CustomException(ERR_MSG.format(
    utils.structs.CustomException: [USER_ERROR]/[APP_ERROR] Failed to download: https://www.vtmgo.be/vtmgo/afspelen/9ba7e6ce-a77b-46fb-ad3b-719881c603ec. Reason: This content is no longer available or refresh the site cookies or VPN issues (Belgium). Solution: Do not attempt to download it or sign into your account using Firefox and play a random video or fix your VPN. If it persists then debug the service.
    I didn't alter anything to `app_files/config.json`:
    (venv) erik@piholeNASLXC:~/schrapen/widefrog$ cat app_files/config.json
        "CDM_WVD_FILE_PATH": "gift_from_karoolus.wvd",
        "USER_AGENT": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36 Edg/123.0.0.0",
        "NUMBER_OF_THREADS": {
            "DATA_SCRAPER": 5,
            "MEDIA_DOWNLOADER": 1
        "DOWNLOAD_COMMANDS": {
            "OUTPUT_MEDIA_PATH": "media",
            "WAIT_BEFORE_DOWNLOADING": true,
            "ADDITIONAL_SUBS": true,
            "TOOL_PARAMETERS": {
                "VOD": "-sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log",
                "LIVESTREAM": "--live-pipe-mux --live-record-limit 00:02:00"
        "SERVICE_CREDENTIALS": {
            [omitted]
        "WARN_EXTERNAL_TOOLS": false
    It also fails on my "head having" Ubuntu machine... I played a video on vtmgo.be on the Ubuntu machine and before copying the cookie file to the Debian machine, as I had done with the goplay.be download.
    Any idea what might cause this?
  23. Good evening.
    When will a new version be available when RTL+ is back on?
    Best regards
    Heiko
  24. @Data2006: here is a patch that should work:
    diff  a/services/plus_rtl_de.py b/services/plus_rtl_de.py
    --- a/services/plus_rtl_de.py
    +++ b/services/plus_rtl_de.py
    @@ -487,6 +487,34 @@ class plus_rtl_de(BaseService):
                 quality = variant["type"].lower().replace("dash", "")
                 video_contents.append((manifest, license_url, quality))
    +        if len(video_contents) == 0:
    +            response = json.loads(requests.get(
    +                f'https://stus.player.streamingtech.de/watch-playout-variants/{graphql_id}?platform=web',
    +                headers={'x-auth-token': plus_rtl_de.AUTH_TOKEN}).content.decode())
    +            for variant in response:
    +                license_url = None
    +                for licence in variant["licenses"]:
    +                    if "widevine" not in licence["type"].lower():
    +                        continue
    +                    license_url = licence["uri"]["href"]
    +                    break
    +                if license_url is None:
    +                    continue
    +                manifest = None
    +                for source in variant["sources"]:
    +                    if "main" not in source["priority"].lower():
    +                        continue
    +                    if ".mpd" not in source["url"]:
    +                        continue
    +                    manifest = source["url"]
    +                    break
    +                if manifest is None:
    +                    continue
    +                quality = variant["name"].lower().replace("dash", "")
    +                video_contents.append((manifest, license_url, quality))
             video_contents = sorted(
                 video_contents, key=lambda vc: plus_rtl_de.RES_PRIORITY[vc[2]], reverse=True
             )[0]
    The patched service file is attached as well
  25. Hello.
    Thanks, the new plus_rtl_de.py works again.
    Best regards
    Heiko
  26. "Is there a way to do this automatically instead of typing 'yes' every time?"
    [Attachment 86664 - Click to enlarge]
  27. Edit "app_files/config.json", set "WAIT_BEFORE_DOWNLOADING" to "false"
  28. Originally Posted by Obo View Post
    Thank you.
  29. Hi,
    When i try to download from VRT i keep getting the cookies error.
    Any possible fix?
