Page 11 of 20
FirstFirst ... 9 10 11 12 13 ... LastLast
Results 301 to 330 of 581
  1. Things have changed at france.tv...
    My quick and dirty temporary fix was to update the get_all_js_dicts method like this in services\france_tv.py
        @staticmethod
        def get_all_js_dicts(source_text):
            pattern = r'"video_factory_id\\*" *: *\\*"([\da-f]{8}-[\da-f]{4}-[\da-f]{4}-[\da-f]{4}-[\da-f]{12})\\*"'
            match = re.search(pattern, source_text)
            if match:
                return [{"videoId": f"{match.group(1)}"}]
            return []
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Thanks for identifying and fixing the issue. Makes things easier.
  3. Hi,
    Widefrog doesn't work to download m6, i'm always need to use N_m3u8DL-RE but before Widefrog worked perfectly,
    I live in France so i don't use vpn cause no need.
    Like said my friend the reason should be :
    the m6-fr.py script was modified in post #239 due to the name change from 6play to m6.fr so I think that it would be necessary to at least update the existing zips with also the modification of the france-tv where it need to change line 54 to post #256
    Testez le nouveau système multiplateforme PowerShell https://aka.ms/pscore6
    PS C:\Users\Domy> cd desktop
    PS C:\Users\Domy\desktop> cd widefrog
    PS C:\Users\Domy\desktop\widefrog> py widefrog.py "https://www.m6.fr/1941-1945-au-coeur-de-la-guerre-du-pacifique-p_19495/episode-3-c_12852591"
    [INFO] Current app version: 2.10.0
    [INFO] Running on: windows/64bit/python 3.13.1
    [INFO] Starting the service initialization stage.
    [USER_ERROR] Failed to download: from the m6_fr service. Reason: Can't access the video content because the session info expired. Solution: Delete the app_files\services_cache\m6_fr.json cache manually or add the parameter --fresh to your command.
    [INFO] Current progress: [1/1]
    [INFO] Starting the collections extraction stage.
    [INFO] Starting the media data extraction stage.
    [INFO] Finished generating the download commands.
    [WARNING] Saved the failed URLs to app_files\cmds_failed.txt
    [WARNING] No download commands have been generated.
    PS C:\Users\Domy\desktop\widefrog> py widefrog.py "https://www.m6.fr/1941-1945-au-coeur-de-la-guerre-du-pacifique-p_19495/episode-3-c_12852591"--debug
    File "C:\Users\Domy\desktop\widefrog\widefrog.py", line 113, in <module>
    main_service.run_service(response)
    File "C:\Users\Domy\desktop\widefrog\utils\main_service .py", line 400, in run_service
    dwn_cmds, failed_cmds = main_service.get_download_commands_parallel(demo_u rls)
    File "C:\Users\Domy\desktop\widefrog\utils\main_service .py", line 335, in get_download_commands_parallel
    source_urls, failures = main_service.initialize_services(source_urls)
    File "C:\Users\Domy\desktop\widefrog\utils\main_service .py", line 322, in initialize_services
    if service_tools.get_service(source_url) is not None:
    File "C:\Users\Domy\desktop\widefrog\utils\tools\servic e.py", line 66, in get_service
    raise e
    File "C:\Users\Domy\desktop\widefrog\utils\tools\servic e.py", line 54, in get_service
    service = service.initialize_service()
    File "C:\Users\Domy\desktop\widefrog\services\m6_fr.py" , line 201, in initialize_service
    m6_fr.BEARER_TOKEN = m6_fr.get_bearer_token()
    File "C:\Users\Domy\desktop\widefrog\services\m6_fr.py" , line 182, in get_bearer_token
    raise CustomException(ERR_MSG.format(
    ...<4 lines>...
    utils.structs.CustomException: [USER_ERROR] Failed to download: from the m6_fr service. Reason: Can't access the video content because the session info expired. Solution: Delete the app_files\services_cache\m6_fr.json cache manually or add the parameter --fresh to your command.
    PS C:\Users\Domy\desktop\widefrog> py widefrog.py "https://www.m6.fr/1941-1945-au-coeur-de-la-guerre-du-pacifique-p_19495/episode-3-c_12852591" --fresh
    [USER_ERROR] Failed to download: https://www.m6.fr/1941-1945-au-coeur-de-la-guerre-du-pacifique-p_19495/episode-3-c_12852591. Reason: The content isn't available. Solution: Do not attempt to download it.
    PS C:\Users\Domy\desktop\widefrog> --fresh
    Au caractère Ligne:1 : 3
    + --fresh
    Expression manquante après l’opérateur unaire «*--*».
    + --fresh
    Jeton inattendu «*fresh*» dans l’expression ou l’instruction.
    + CategoryInfo : ParserError: ( : ) [], ParentContainsErrorRecordException
    + FullyQualifiedErrorId : MissingExpressionAfterOperator
    PS C:\Users\Domy\desktop\widefrog> py widefrog.py "https://www.m6.fr/1941-1945-au-coeur-de-la-guerre-du-pacifique-p_19495/episode-3-c_12852591"--fresh
    I'D like Widefrog work like before, i win time to download m6 with Widefrog process
    I really want it could be fxied..
  4. The video you're trying to download needs a subscription
  5. I Subscribed i've forget to mentioned it
  6. Hi,
    Thanks for all the work!
    Is it possible to add Goplay.be ?
    Some tv shows have DRM now.
    Grtz
  7. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    paid videos aren't supported by this tool and won't be
    Originally Posted by Dafalgan View Post
    Hi,
    Grtz
    No problem. I've been interested in adding goplay in the past, but I couldn't figure out a reliable way to query all the episodes so I won't add it.
    Oct 2023
    Afghanistan
    Had your script for ages but only just starting fiddling about with it. Got a couple of NBA videos I've been after for a while.
    @2nHxWW6GkN1l916N3ayz8HQoi thanks mate !
  9. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    No problem @bill. Glad to hear it's put to good use
  10. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    Hi,
    Grtz
    And would it maybe be possible to add it for single episodes?
  11. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Uh sure, but I don't see the point since the whole advantage of tools like this is batch download. If you want only individual videos, you might as well use other tools that are meant to be more general
  12. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    I don't think there is a tool for this. Goplay splits its videos into 3 parts, I think it's not that easy. That's why I ask your help
    Feb 2006
    can you not use FFmpeg ?? - Joining Downloaded Video Parts
    To join a video that has been downloaded into three parts using FFmpeg, you can use the concat demuxer or the concat filter method. Here are the steps for each method:
    Using the Concat Demuxer
    Prepare a Text File: Create a text file listing the paths to the video parts. For example, if your video parts are named part1.mp4, part2.mp4, and part3.mp4, the text file (videoList.txt) should look like this:
    file '/path/to/part1.mp4'
    file '/path/to/part2.mp4'
    file '/path/to/part3.mp4'
    Run the FFmpeg Command: Use the following command to concatenate the videos:
    ffmpeg -f concat -safe 0 -i videoList.txt -c copy final_output.mp4
    -f concat: Specifies the concat demuxer.
    -safe 0: Disables the safety check for paths, allowing the use of files with special characters.
    -i videoList.txt: Specifies the input file list.
    -c copy: Ensures no re-encoding takes place, resulting in a faster and lossless process.
    Using the Concat Filter
    ffmpeg -i part1.mp4 -i part2.mp4 -i part3.mp4 -filter_complex "[0:v][0:a][1:v][1:a][2:v][2:a]concat=n=3:v=1:a=1[outv][outa]" -map "[outv]" -map "[outa]" final_output.mp4
    -i part1.mp4 -i part2.mp4 -i part3.mp4: Specifies the input video files.
    -filter_complex "[0:v][0:a][1:v][1:a][2:v][2:a]concat=n=3:v=1:a=1[outv][outa]": Specifies the filter to concatenate the video and audio streams.
    -map "[outv]" -map "[outa]": Maps the output video and audio streams to the final output file.
    final_output.mp4: The name of the final output file.
    Both methods will join the three video parts into a single video file without re-encoding, ensuring a lossless process.
  14. Originally Posted by october262 View Post
    Sorry, I think I explained it wrong. During the download I get a choice of 3 different videos. If I select 1 of the 3, I get a much too short video. If I select all 3, I get a slightly larger video, but it is still not good. Also my knowledge is not that great yet. I am still learning.
  15. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    I remember that problem now. It was already discussed and solved here
    https://forum.videohelp.com/threads/412813-Download-from-goplay-be-using-yt-dlp
    Search forum function can help a lot
  16. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    This topic is about downloading non drm. What I mean is for videos with drm.
  17. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Not relevant. What matters is how to download through their broken manifest once you have the keys. Read that entire thread, not just the title. Keys can be easily obtained with tools like widevineproxy etc.
  18. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    v2.11.0:
    => + mtv.fi
    => + rtve.es (only the section /play/)
    => - cbs.com : Removed the service cause browser flow is now useless due to API changes
    Minor changes:
    => fixed some bugs for vtmgo.be and zee5.com
    => france.tv: removed livestream support and fixed some other bugs (thanks @gibolin for the quick fix)
  19. hello I would like to download season 3 and 4 of this series how to do it
    https://www.france.tv/enfants/six-huit-ans/au-galop/
    Best Regards
  20. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Hello.
    python widefrog.py "https://www.france.tv/enfants/six-huit-ans/au-galop/" --query=3::4:
    Will download all 100 episodes including bonus videos for both seasons. In this case there are no bonus extras
  21. Thanks for this awesome script! Is it possible to add nbc.com? i would like to download from this list: https://www.nbc.com/shows/telemundo/a-z
  22. Member
    Jan 2025
    VT 0.1.2
    Got error : [WARNING] External tool is not installed: shaka-packager. Download commands may not be launched properly.
    How i can fix them ?
  23. Member
    Jan 2025
    VT 0.1.2
    Best Regards
    Season 3
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzV+YWNsPSUyZip+aG1hYz02YzQwNzIwMTFjZDg4OTg5NzkxOGUxYWQ4NmMyOGI3NmRkZTIwZDc2OTBjM2VmNzY0ZjZlZmYyNWRmYTk5MDY2/a4bdcb2383e36/f172433d-964e-41ec-a202-2cbc345b4096-1675855380_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819535~acl=%2f*~hmac=8561ce10336ba5f0d326bb486f17d3d6433e42dfb4cab4bf2589e54724c04eb2"  --tmp-dir "media\tmp\O7dFmj6" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E1_S3_E1_-_Cest_la_rentree_" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E1_S3_E1_-_Cest_la_rentree_.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E1_S3_E1_-_Cest_la_rentree_" true & rd /s /q "media\tmp\O7dFmj6"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzZ+YWNsPSUyZip+aG1hYz1kNjMxMTk4MmQzYmFiNWNmYzM4NTI4ZmE5N2ZjMTUwZTk3ZGVjNzFiOGIyYzg5YTgwOTMzYjgzYzI2NWY4MzEx/2ec2c05383e36/e37e2d21-65ac-41d7-b8a8-08fef14f2efa-1675855380_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819536~acl=%2f*~hmac=38dd333f91a39634c9009cbd17fe6bbad3de7bb05054af1d881f73345c653cdc"  --tmp-dir "media\tmp\EBHlcHg" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E2_S3_E2_-_Les_jeux_Firfolympiques" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E2_S3_E2_-_Les_jeux_Firfolympiques.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E2_S3_E2_-_Les_jeux_Firfolympiques" true & rd /s /q "media\tmp\EBHlcHg"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzZ+YWNsPSUyZip+aG1hYz1kNjMxMTk4MmQzYmFiNWNmYzM4NTI4ZmE5N2ZjMTUwZTk3ZGVjNzFiOGIyYzg5YTgwOTMzYjgzYzI2NWY4MzEx/ebd6876383e36/2976aa93-7230-425b-9388-b501d2abf22d-1675855370_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819536~acl=%2f*~hmac=38dd333f91a39634c9009cbd17fe6bbad3de7bb05054af1d881f73345c653cdc"  --tmp-dir "media\tmp\eDzZLOZ" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E3_S3_E3_-_Le_soleil_la_plage_et_les_chevaux" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E3_S3_E3_-_Le_soleil_la_plage_et_les_chevaux.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E3_S3_E3_-_Le_soleil_la_plage_et_les_chevaux" true & rd /s /q "media\tmp\eDzZLOZ"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzd+YWNsPSUyZip+aG1hYz0wYWI5ZjM4Yzc3MzhmZTk5ODQwMTY3ZTA2YTg3Y2Q1OTEzZThiMzJjOTY1MTk5MjVlNzgzZGEyOTk0ZTA4NWY0/b849797383e36/0fc9f85e-2de2-43e4-9863-67c6feb41d84-1675855440_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819537~acl=%2f*~hmac=8df532e5485efb07de30a65a20454cfb125f9b8a7d2d340b0153192b64c22cff"  --tmp-dir "media\tmp\pkzUSut" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E4_S3_E4_-_Des_champions_en_herbe" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E4_S3_E4_-_Des_champions_en_herbe.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E4_S3_E4_-_Des_champions_en_herbe" true & rd /s /q "media\tmp\pkzUSut"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzd+YWNsPSUyZip+aG1hYz0wYWI5ZjM4Yzc3MzhmZTk5ODQwMTY3ZTA2YTg3Y2Q1OTEzZThiMzJjOTY1MTk5MjVlNzgzZGEyOTk0ZTA4NWY0/79bd7af4dce36/ddc41c5d-fa5b-49ca-b9b0-94b4a574141f-1676465747_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819537~acl=%2f*~hmac=8df532e5485efb07de30a65a20454cfb125f9b8a7d2d340b0153192b64c22cff"  --tmp-dir "media\tmp\XqY7357" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E5_S3_E5_-_Du_POLO_au_CSO" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E5_S3_E5_-_Du_POLO_au_CSO.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E5_S3_E5_-_Du_POLO_au_CSO" true & rd /s /q "media\tmp\XqY7357"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzh+YWNsPSUyZip+aG1hYz00MmQwZWU3ZmJiNDkwZDhmZmRjYjdmYjJlNGNhMzQ3ZDdkNzQzZDNkNzc1NTViZWU5NTJhZjY1MjAwMDgxMmE0/61e03f65dce36/c1e23b0a-45a9-40bc-974b-b64859a4d9d9-1676465946_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819538~acl=%2f*~hmac=d409c8cecfe6777a78b974eebd0591eaaa49b12a91a406289620bb8b7d0d2c9f"  --tmp-dir "media\tmp\Rd7MLYm" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E6_S3_E6_-_De_lattelage_a_Firfol" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E6_S3_E6_-_De_lattelage_a_Firfol.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E6_S3_E6_-_De_lattelage_a_Firfol" true & rd /s /q "media\tmp\Rd7MLYm"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzh+YWNsPSUyZip+aG1hYz00MmQwZWU3ZmJiNDkwZDhmZmRjYjdmYjJlNGNhMzQ3ZDdkNzQzZDNkNzc1NTViZWU5NTJhZjY1MjAwMDgxMmE0/74738e56dce36/8c032d6e-a160-4a0c-bcba-12cc70b07ed9-1676466175_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819538~acl=%2f*~hmac=d409c8cecfe6777a78b974eebd0591eaaa49b12a91a406289620bb8b7d0d2c9f"  --tmp-dir "media\tmp\YhDMO6E" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E7_S3_E7_-_Claude_et_les_nouvelles" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E7_S3_E7_-_Claude_et_les_nouvelles.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E7_S3_E7_-_Claude_et_les_nouvelles" true & rd /s /q "media\tmp\YhDMO6E"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzh+YWNsPSUyZip+aG1hYz00MmQwZWU3ZmJiNDkwZDhmZmRjYjdmYjJlNGNhMzQ3ZDdkNzQzZDNkNzc1NTViZWU5NTJhZjY1MjAwMDgxMmE0/582d5ad6dce36/41144333-77da-4b3a-8405-89f3690d2cf2-1676466196_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819538~acl=%2f*~hmac=d409c8cecfe6777a78b974eebd0591eaaa49b12a91a406289620bb8b7d0d2c9f"  --tmp-dir "media\tmp\yK8xhYI" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E8_S3_E8_-_Les_poneys_grandissent" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E8_S3_E8_-_Les_poneys_grandissent.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E8_S3_E8_-_Les_poneys_grandissent" true & rd /s /q "media\tmp\yK8xhYI"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/1eb68010d8f36/3a788335-bfb7-46a8-9565-f5cb971ace62-1677250859_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\clmZiAM" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E9_S3_E9_-_Sauter_plus_haut" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E9_S3_E9_-_Sauter_plus_haut.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E9_S3_E9_-_Sauter_plus_haut" true & rd /s /q "media\tmp\clmZiAM"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/b6bcd070d8f36/064c927d-55ee-47a0-b4d1-b07442bc7b94-1677250980_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\P9oEtpy" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E10_S3_E10_-_Coiffeurs_pour_poulain" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E10_S3_E10_-_Coiffeurs_pour_poulain.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E10_S3_E10_-_Coiffeurs_pour_poulain" true & rd /s /q "media\tmp\P9oEtpy"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/8fa07562edf36/08c61652-8b35-4149-b976-7d9c8a5c3db6-1677583314_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\3iqAiDk" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E11_S3_E11_-_Un_nouveau_au_polo" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E11_S3_E11_-_Un_nouveau_au_polo.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E11_S3_E11_-_Un_nouveau_au_polo" true & rd /s /q "media\tmp\3iqAiDk"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/407f7972edf36/be6d0df9-3f6d-4308-a2be-c60a12b284cd-1677583354_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\721ySkn" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E12_S3_E12_-_Comme_les_grands" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E12_S3_E12_-_Comme_les_grands.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E12_S3_E12_-_Comme_les_grands" true & rd /s /q "media\tmp\721ySkn"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/5be02c18b8046/9829bf56-ece3-4ca3-adbe-7fb58df36405-1678293281_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\A5PwLjQ" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E13_S3_E13_-_Photos_souvenirs" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E13_S3_E13_-_Photos_souvenirs.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E13_S3_E13_-_Photos_souvenirs" true & rd /s /q "media\tmp\A5PwLjQ"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDF+YWNsPSUyZip+aG1hYz0wNDVlYjcwNDM2MTc3OTJjMzY1OGFkYTM2MDAzNjM3NjA4ZmI4NTc3MWI2ZWQ4OTI3ODVjN2FmZDhlZTdhZjA0/52ac23e7b8046/a0324c85-4ef4-485f-bada-e5be50a9cc72-1678293231_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819541~acl=%2f*~hmac=c0edbac1c4d7f7d7c203be24a7aaaa7a0ef354a99bb2c15817f2087a4a4c50a4"  --tmp-dir "media\tmp\igt5PBi" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E14_S3_E14_-_Lart_de_faire_le_clown_a_poney" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E14_S3_E14_-_Lart_de_faire_le_clown_a_poney.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E14_S3_E14_-_Lart_de_faire_le_clown_a_poney" true & rd /s /q "media\tmp\igt5PBi"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDF+YWNsPSUyZip+aG1hYz0wNDVlYjcwNDM2MTc3OTJjMzY1OGFkYTM2MDAzNjM3NjA4ZmI4NTc3MWI2ZWQ4OTI3ODVjN2FmZDhlZTdhZjA0/898f58a7b8046/32bfd12e-3751-4514-9167-756ac27e85ad-1678293191_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819541~acl=%2f*~hmac=c0edbac1c4d7f7d7c203be24a7aaaa7a0ef354a99bb2c15817f2087a4a4c50a4"  --tmp-dir "media\tmp\fcDBdF3" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E15_S3_E15_-_En_voiture_" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E15_S3_E15_-_En_voiture_.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E15_S3_E15_-_En_voiture_" true & rd /s /q "media\tmp\fcDBdF3"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDF+YWNsPSUyZip+aG1hYz0wNDVlYjcwNDM2MTc3OTJjMzY1OGFkYTM2MDAzNjM3NjA4ZmI4NTc3MWI2ZWQ4OTI3ODVjN2FmZDhlZTdhZjA0/53c86977b8046/8394585c-3804-43d1-a415-c7dfbc3c8430-1678293151_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819541~acl=%2f*~hmac=c0edbac1c4d7f7d7c203be24a7aaaa7a0ef354a99bb2c15817f2087a4a4c50a4"  --tmp-dir "media\tmp\lTfGLMY" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E16_S3_E16_-_Tip_Top_pas_au_top" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E16_S3_E16_-_Tip_Top_pas_au_top.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E16_S3_E16_-_Tip_Top_pas_au_top" true & rd /s /q "media\tmp\lTfGLMY"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/4af865b2c1846/e3db4cea-5478-470d-8632-598d836fc2fd-1686226041_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\Yo7nkJy" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E17_S3_E17_-_Kaya_est_de_retour" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E17_S3_E17_-_Kaya_est_de_retour.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E17_S3_E17_-_Kaya_est_de_retour" true & rd /s /q "media\tmp\Yo7nkJy"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/bf3d2fa2c1846/7b8278b5-c31f-42be-b733-c8466ce7b172-1686226170_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\CiGKtO2" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E18_S3_E18_-_Le_polo_nest_pas_comme_le_velo" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E18_S3_E18_-_Le_polo_nest_pas_comme_le_velo.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E18_S3_E18_-_Le_polo_nest_pas_comme_le_velo" true & rd /s /q "media\tmp\CiGKtO2"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/b74099a2c1846/b4f2c158-c792-4ce8-bac9-e3a09b110464-1686226110_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\Xg3uYkY" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E19_S3_E19_-_Premier_contact" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E19_S3_E19_-_Premier_contact.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E19_S3_E19_-_Premier_contact" true & rd /s /q "media\tmp\Xg3uYkY"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDN+YWNsPSUyZip+aG1hYz1jNzE2MGUxOGU1Zjc1ZTRlYzJiYjhiODViYTI1MzE3MTRjZDRhM2Y5ZGE2ZjI2NmI0OThhZGEzNWM1MTRmYjc5/d8f5e1a2c1846/a4b8fa11-5285-49e3-9f31-45120a78bd0a-1686226105_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819543~acl=%2f*~hmac=e1e36c3755addf3e17f6b18721e6ac4aca777a3cf6bb4fe3a9bd3a2534a9a5cc"  --tmp-dir "media\tmp\Kh9ETnz" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E20_S3_E20_-_Premiere_sortie_en_attelage" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E20_S3_E20_-_Premiere_sortie_en_attelage.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E20_S3_E20_-_Premiere_sortie_en_attelage" true & rd /s /q "media\tmp\Kh9ETnz"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzV+YWNsPSUyZip+aG1hYz02YzQwNzIwMTFjZDg4OTg5NzkxOGUxYWQ4NmMyOGI3NmRkZTIwZDc2OTBjM2VmNzY0ZjZlZmYyNWRmYTk5MDY2/283d13654d346/0970fa03-f4ad-48d4-b22b-6d60cee6d7f9-1681737390_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819535~acl=%2f*~hmac=8561ce10336ba5f0d326bb486f17d3d6433e42dfb4cab4bf2589e54724c04eb2"  --tmp-dir "media\tmp\Zqvxu3S" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E21_S3_E21_-_Un_choix_crucial" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E21_S3_E21_-_Un_choix_crucial.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E21_S3_E21_-_Un_choix_crucial" true & rd /s /q "media\tmp\Zqvxu3S"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzZ+YWNsPSUyZip+aG1hYz1kNjMxMTk4MmQzYmFiNWNmYzM4NTI4ZmE5N2ZjMTUwZTk3ZGVjNzFiOGIyYzg5YTgwOTMzYjgzYzI2NWY4MzEx/57f98a824d346/27e57a86-9f07-4902-9d29-e673b64eedb5-1681736656_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819536~acl=%2f*~hmac=38dd333f91a39634c9009cbd17fe6bbad3de7bb05054af1d881f73345c653cdc"  --tmp-dir "media\tmp\vJG9hMj" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E22_S3_E22_-_La_vocation_dHanae" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E22_S3_E22_-_La_vocation_dHanae.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E22_S3_E22_-_La_vocation_dHanae" true & rd /s /q "media\tmp\vJG9hMj"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzZ+YWNsPSUyZip+aG1hYz1kNjMxMTk4MmQzYmFiNWNmYzM4NTI4ZmE5N2ZjMTUwZTk3ZGVjNzFiOGIyYzg5YTgwOTMzYjgzYzI2NWY4MzEx/b031bfe6cf246/6a0d3135-38c1-4a14-833a-a85a767caa28-1680853027_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819536~acl=%2f*~hmac=38dd333f91a39634c9009cbd17fe6bbad3de7bb05054af1d881f73345c653cdc"  --tmp-dir "media\tmp\WXJaDk8" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E23_S3_E23_-_Le_sans_faute_et_les_barrages" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E23_S3_E23_-_Le_sans_faute_et_les_barrages.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E23_S3_E23_-_Le_sans_faute_et_les_barrages" true & rd /s /q "media\tmp\WXJaDk8"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzd+YWNsPSUyZip+aG1hYz0wYWI5ZjM4Yzc3MzhmZTk5ODQwMTY3ZTA2YTg3Y2Q1OTEzZThiMzJjOTY1MTk5MjVlNzgzZGEyOTk0ZTA4NWY0/b59926e6cf246/de362dab-a0f1-49de-9219-1dd37a1761a2-1680852987_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819537~acl=%2f*~hmac=8df532e5485efb07de30a65a20454cfb125f9b8a7d2d340b0153192b64c22cff"  --tmp-dir "media\tmp\j8SQncw" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E24_S3_E24_-_Quand_Deauville_rencontre_Firfol" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E24_S3_E24_-_Quand_Deauville_rencontre_Firfol.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E24_S3_E24_-_Quand_Deauville_rencontre_Firfol" true & rd /s /q "media\tmp\j8SQncw"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzd+YWNsPSUyZip+aG1hYz0wYWI5ZjM4Yzc3MzhmZTk5ODQwMTY3ZTA2YTg3Y2Q1OTEzZThiMzJjOTY1MTk5MjVlNzgzZGEyOTk0ZTA4NWY0/de11004f20346/003e1275-4a09-45e9-ac8b-6bec1ea23501-1680879831_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819537~acl=%2f*~hmac=8df532e5485efb07de30a65a20454cfb125f9b8a7d2d340b0153192b64c22cff"  --tmp-dir "media\tmp\VYNdPCA" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E25_S3_E25_-_Chacun_son_entrainement" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E25_S3_E25_-_Chacun_son_entrainement.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E25_S3_E25_-_Chacun_son_entrainement" true & rd /s /q "media\tmp\VYNdPCA"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzh+YWNsPSUyZip+aG1hYz00MmQwZWU3ZmJiNDkwZDhmZmRjYjdmYjJlNGNhMzQ3ZDdkNzQzZDNkNzc1NTViZWU5NTJhZjY1MjAwMDgxMmE0/1157294f20346/cfacab35-7025-421c-b855-dd5011b5a9d5-1680879949_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819538~acl=%2f*~hmac=d409c8cecfe6777a78b974eebd0591eaaa49b12a91a406289620bb8b7d0d2c9f"  --tmp-dir "media\tmp\sf255di" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E26_S3_E26_-_Le_spectacle_du_poney_club" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E26_S3_E26_-_Le_spectacle_du_poney_club.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E26_S3_E26_-_Le_spectacle_du_poney_club" true & rd /s /q "media\tmp\sf255di"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzh+YWNsPSUyZip+aG1hYz00MmQwZWU3ZmJiNDkwZDhmZmRjYjdmYjJlNGNhMzQ3ZDdkNzQzZDNkNzc1NTViZWU5NTJhZjY1MjAwMDgxMmE0/9ac8788d11546/b661df42-0338-465d-ab8e-c73fcff97ee2-1683037951_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819538~acl=%2f*~hmac=d409c8cecfe6777a78b974eebd0591eaaa49b12a91a406289620bb8b7d0d2c9f"  --tmp-dir "media\tmp\WNR62Ap" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E27_S3_E27_-_Le_choix_de_Jeanne" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E27_S3_E27_-_Le_choix_de_Jeanne.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E27_S3_E27_-_Le_choix_de_Jeanne" true & rd /s /q "media\tmp\WNR62Ap"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzh+YWNsPSUyZip+aG1hYz00MmQwZWU3ZmJiNDkwZDhmZmRjYjdmYjJlNGNhMzQ3ZDdkNzQzZDNkNzc1NTViZWU5NTJhZjY1MjAwMDgxMmE0/7b6775ed11546/a7118930-0270-4da0-9c91-37ddfb5ee47b-1683038005_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819538~acl=%2f*~hmac=d409c8cecfe6777a78b974eebd0591eaaa49b12a91a406289620bb8b7d0d2c9f"  --tmp-dir "media\tmp\uyDtCuJ" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E28_S3_E28_-_Firfol_a_la_conquete_de_Deauville" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E28_S3_E28_-_Firfol_a_la_conquete_de_Deauville.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E28_S3_E28_-_Firfol_a_la_conquete_de_Deauville" true & rd /s /q "media\tmp\uyDtCuJ"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/6f773db10a546/c54c5bff-ace0-4ad0-baa2-c88a057b6b7b-1683620569_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\WjTAnNt" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E29_S3_E29_-_Petit_poney_deviendra_grand" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E29_S3_E29_-_Petit_poney_deviendra_grand.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E29_S3_E29_-_Petit_poney_deviendra_grand" true & rd /s /q "media\tmp\WjTAnNt"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/eb614b720a546/b254e4c1-f55a-4d29-80d1-a04d2cac7a94-1683620790_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\RqJxadR" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E30_S3_E30_-_Un_defi_audacieux" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E30_S3_E30_-_Un_defi_audacieux.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E30_S3_E30_-_Un_defi_audacieux" true & rd /s /q "media\tmp\RqJxadR"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/497c68640a546/856d26e1-b7a7-47fd-9257-4e062a01d8b5-1683621301_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\ybI4jDO" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E31_S3_E31_-_Un_match_sur_lhippodrome" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E31_S3_E31_-_Un_match_sur_lhippodrome.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E31_S3_E31_-_Un_match_sur_lhippodrome" true & rd /s /q "media\tmp\ybI4jDO"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/60d78b093a546/fa5fa4a1-b226-4d6d-97d6-51baa22400c7-1683634791_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\NFvbeeP" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E32_S3_E32_-_Des_poneys" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E32_S3_E32_-_Des_poneys.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E32_S3_E32_-_Des_poneys" true & rd /s /q "media\tmp\NFvbeeP"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/d516be3bac646/5370cd74-a433-4014-92a6-a0b35394b3f8-1684843920_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\qKrrtrO" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E33_S3_E33_-_Le_challenge_du_poney_club" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E33_S3_E33_-_Le_challenge_du_poney_club.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E33_S3_E33_-_Le_challenge_du_poney_club" true & rd /s /q "media\tmp\qKrrtrO"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDF+YWNsPSUyZip+aG1hYz0wNDVlYjcwNDM2MTc3OTJjMzY1OGFkYTM2MDAzNjM3NjA4ZmI4NTc3MWI2ZWQ4OTI3ODVjN2FmZDhlZTdhZjA0/5d9f243bac646/ce9d1ff3-6f08-4608-a5e5-37ca4ffe1e1a-1684843689_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819541~acl=%2f*~hmac=c0edbac1c4d7f7d7c203be24a7aaaa7a0ef354a99bb2c15817f2087a4a4c50a4"  --tmp-dir "media\tmp\hzqdQCX" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E34_S3_E34_-_Initiation_au_sulky" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E34_S3_E34_-_Initiation_au_sulky.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E34_S3_E34_-_Initiation_au_sulky" true & rd /s /q "media\tmp\hzqdQCX"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDF+YWNsPSUyZip+aG1hYz0wNDVlYjcwNDM2MTc3OTJjMzY1OGFkYTM2MDAzNjM3NjA4ZmI4NTc3MWI2ZWQ4OTI3ODVjN2FmZDhlZTdhZjA0/7280d60d58746/f7d8e73d-8de4-4766-9a66-1ca428d94025-1685610187_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819541~acl=%2f*~hmac=c0edbac1c4d7f7d7c203be24a7aaaa7a0ef354a99bb2c15817f2087a4a4c50a4"  --tmp-dir "media\tmp\NrUiBmk" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E35_S3_E35_-_Le_passage_du_galop_dattelage" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E35_S3_E35_-_Le_passage_du_galop_dattelage.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E35_S3_E35_-_Le_passage_du_galop_dattelage" true & rd /s /q "media\tmp\NrUiBmk"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/6eea233d58746/3536e922-20fd-4148-afd7-251bab3fd780-1685610237_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\9dqXMUM" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E36_S3_E36_-_Deauville_contre_Firfol" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E36_S3_E36_-_Deauville_contre_Firfol.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E36_S3_E36_-_Deauville_contre_Firfol" true & rd /s /q "media\tmp\9dqXMUM"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/f9d43245fd746/3ef9d3de-0dd4-4438-8073-3d1fdb64f375-1685977202_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\r6WAlrh" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E37_S3_E37_-_Le_spectacle_du_poney_club" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E37_S3_E37_-_Le_spectacle_du_poney_club.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E37_S3_E37_-_Le_spectacle_du_poney_club" true & rd /s /q "media\tmp\r6WAlrh"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/2b11eb45fd746/d507efeb-658d-460d-b90a-02ed583321e3-1685977192_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\SxWR9zZ" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E38_S3_E38_-_De_nouvelles_ecuries_dans_Au_galop_" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E38_S3_E38_-_De_nouvelles_ecuries_dans_Au_galop_.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E38_S3_E38_-_De_nouvelles_ecuries_dans_Au_galop_" true & rd /s /q "media\tmp\SxWR9zZ"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDN+YWNsPSUyZip+aG1hYz1jNzE2MGUxOGU1Zjc1ZTRlYzJiYjhiODViYTI1MzE3MTRjZDRhM2Y5ZGE2ZjI2NmI0OThhZGEzNWM1MTRmYjc5/8d23c40461946/e71d5ca5-5cf1-4f62-b3f9-51d89b05bdb6-1687250319_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819543~acl=%2f*~hmac=e1e36c3755addf3e17f6b18721e6ac4aca777a3cf6bb4fe3a9bd3a2534a9a5cc"  --tmp-dir "media\tmp\hlxSHyF" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E39_S3_E39_-_Les_fyrfolympiques" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E39_S3_E39_-_Les_fyrfolympiques.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E39_S3_E39_-_Les_fyrfolympiques" true & rd /s /q "media\tmp\hlxSHyF"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDN+YWNsPSUyZip+aG1hYz1jNzE2MGUxOGU1Zjc1ZTRlYzJiYjhiODViYTI1MzE3MTRjZDRhM2Y5ZGE2ZjI2NmI0OThhZGEzNWM1MTRmYjc5/1163718c69846/61e69a8c-4dac-469f-9761-83e9c5589762-1686728225_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819543~acl=%2f*~hmac=e1e36c3755addf3e17f6b18721e6ac4aca777a3cf6bb4fe3a9bd3a2534a9a5cc"  --tmp-dir "media\tmp\01i6ucQ" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E40_S3_E40_-_Qui_sautera_le_plus_haut_" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E40_S3_E40_-_Qui_sautera_le_plus_haut_.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E40_S3_E40_-_Qui_sautera_le_plus_haut_" true & rd /s /q "media\tmp\01i6ucQ"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzZ+YWNsPSUyZip+aG1hYz1kNjMxMTk4MmQzYmFiNWNmYzM4NTI4ZmE5N2ZjMTUwZTk3ZGVjNzFiOGIyYzg5YTgwOTMzYjgzYzI2NWY4MzEx/a4407e6210946/3f722c07-20f0-4cee-bf97-42e57e1cba6f-1687164093_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819536~acl=%2f*~hmac=38dd333f91a39634c9009cbd17fe6bbad3de7bb05054af1d881f73345c653cdc"  --tmp-dir "media\tmp\CwXNSxd" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E41_S3_E41_-_Le_podium_des_firfolympiques" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E41_S3_E41_-_Le_podium_des_firfolympiques.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E41_S3_E41_-_Le_podium_des_firfolympiques" true & rd /s /q "media\tmp\CwXNSxd"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzZ+YWNsPSUyZip+aG1hYz1kNjMxMTk4MmQzYmFiNWNmYzM4NTI4ZmE5N2ZjMTUwZTk3ZGVjNzFiOGIyYzg5YTgwOTMzYjgzYzI2NWY4MzEx/d08d9c9210946/4fb8574c-62f9-4328-a4f3-8aff4a19ca1f-1687163963_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819536~acl=%2f*~hmac=38dd333f91a39634c9009cbd17fe6bbad3de7bb05054af1d881f73345c653cdc"  --tmp-dir "media\tmp\uTUmIiK" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E42_S3_E42_-_Les_firfoliens_chez_les_camarguais" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E42_S3_E42_-_Les_firfoliens_chez_les_camarguais.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E42_S3_E42_-_Les_firfoliens_chez_les_camarguais" true & rd /s /q "media\tmp\uTUmIiK"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzd+YWNsPSUyZip+aG1hYz0wYWI5ZjM4Yzc3MzhmZTk5ODQwMTY3ZTA2YTg3Y2Q1OTEzZThiMzJjOTY1MTk5MjVlNzgzZGEyOTk0ZTA4NWY0/e0b863ec9a946/44c8e0b2-c1db-42d0-8c64-e6abaf808922-1687855057_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819537~acl=%2f*~hmac=8df532e5485efb07de30a65a20454cfb125f9b8a7d2d340b0153192b64c22cff"  --tmp-dir "media\tmp\db2ADvH" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E43_S3_E43_-_La_decouverte_de_lequitation_de_travail" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E43_S3_E43_-_La_decouverte_de_lequitation_de_travail.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E43_S3_E43_-_La_decouverte_de_lequitation_de_travail" true & rd /s /q "media\tmp\db2ADvH"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzd+YWNsPSUyZip+aG1hYz0wYWI5ZjM4Yzc3MzhmZTk5ODQwMTY3ZTA2YTg3Y2Q1OTEzZThiMzJjOTY1MTk5MjVlNzgzZGEyOTk0ZTA4NWY0/775855fc9a946/3fec22c8-acd8-4035-ae4c-0604921d3bb5-1687855067_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819537~acl=%2f*~hmac=8df532e5485efb07de30a65a20454cfb125f9b8a7d2d340b0153192b64c22cff"  --tmp-dir "media\tmp\IJuzjKA" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E44_S3_E44_-_Une_aire_de_jeux_pour_les_poneys" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E44_S3_E44_-_Une_aire_de_jeux_pour_les_poneys.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E44_S3_E44_-_Une_aire_de_jeux_pour_les_poneys" true & rd /s /q "media\tmp\IJuzjKA"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzd+YWNsPSUyZip+aG1hYz0wYWI5ZjM4Yzc3MzhmZTk5ODQwMTY3ZTA2YTg3Y2Q1OTEzZThiMzJjOTY1MTk5MjVlNzgzZGEyOTk0ZTA4NWY0/1a01ca29ce946/88eebdbf-f82c-4d08-b5a4-651eb3a9f6e4-1688128139_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819537~acl=%2f*~hmac=8df532e5485efb07de30a65a20454cfb125f9b8a7d2d340b0153192b64c22cff"  --tmp-dir "media\tmp\9FiyIVj" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E45_S3_E45_-_Rencontre_avec_les_stars" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E45_S3_E45_-_Rencontre_avec_les_stars.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E45_S3_E45_-_Rencontre_avec_les_stars" true & rd /s /q "media\tmp\9FiyIVj"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzh+YWNsPSUyZip+aG1hYz00MmQwZWU3ZmJiNDkwZDhmZmRjYjdmYjJlNGNhMzQ3ZDdkNzQzZDNkNzc1NTViZWU5NTJhZjY1MjAwMDgxMmE0/b1dde9f3f3a46/3f8eee5f-db43-4c00-830e-1b40caa9512f-1688466814_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819538~acl=%2f*~hmac=d409c8cecfe6777a78b974eebd0591eaaa49b12a91a406289620bb8b7d0d2c9f"  --tmp-dir "media\tmp\lNIhJ7w" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E46_S3_E46_-_La_manade_et_les_marais" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E46_S3_E46_-_La_manade_et_les_marais.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E46_S3_E46_-_La_manade_et_les_marais" true & rd /s /q "media\tmp\lNIhJ7w"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzh+YWNsPSUyZip+aG1hYz00MmQwZWU3ZmJiNDkwZDhmZmRjYjdmYjJlNGNhMzQ3ZDdkNzQzZDNkNzc1NTViZWU5NTJhZjY1MjAwMDgxMmE0/f70a6b9934a46/6c8f8900-c387-4cf6-aadd-4ec712c56956-1688485098_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819538~acl=%2f*~hmac=d409c8cecfe6777a78b974eebd0591eaaa49b12a91a406289620bb8b7d0d2c9f"  --tmp-dir "media\tmp\odCnhGc" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E47_S3_E47_-_Le_parcours_de_Capucine" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E47_S3_E47_-_Le_parcours_de_Capucine.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E47_S3_E47_-_Le_parcours_de_Capucine" true & rd /s /q "media\tmp\odCnhGc"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzh+YWNsPSUyZip+aG1hYz00MmQwZWU3ZmJiNDkwZDhmZmRjYjdmYjJlNGNhMzQ3ZDdkNzQzZDNkNzc1NTViZWU5NTJhZjY1MjAwMDgxMmE0/073bad8934a46/0ba6c12f-0209-41bc-86a0-f468faeea381-1688484977_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819538~acl=%2f*~hmac=d409c8cecfe6777a78b974eebd0591eaaa49b12a91a406289620bb8b7d0d2c9f"  --tmp-dir "media\tmp\nskIoPx" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E48_S3_E48_-_A_lassaut_du_galop" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E48_S3_E48_-_A_lassaut_du_galop.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E48_S3_E48_-_A_lassaut_du_galop" true & rd /s /q "media\tmp\nskIoPx"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/7bbd34f4afa46/5f8f0c5b-9b43-4c2d-8e17-b0bcc27ad182-1689233479_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\QJ9ZiXl" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E49_S3_E49_-_La_mania_chrono" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E49_S3_E49_-_La_mania_chrono.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E49_S3_E49_-_La_mania_chrono" true & rd /s /q "media\tmp\QJ9ZiXl"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/015c2725afa46/06ae9f4d-f2ac-4e6e-87ae-b450ab3fc527-1689233479_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\dboGXDx" --save-dir "media\france_tv\Au_galop_France_TV\S3_Saison_3\E50_S3_E50_-_Un_defile_extraordinaire" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E50_S3_E50_-_Un_defile_extraordinaire.mkv" "media\france_tv\Au_galop_France_TV\S3_Saison_3\E50_S3_E50_-_Un_defile_extraordinaire" true & rd /s /q "media\tmp\dboGXDx"
  24. Member
    Jan 2025
    VT 0.1.2
    Season 4 :
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/ece6c0aceae56/b367871b-99bc-4a00-b89f-2ee815d78da2-1709895283_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\ufBZUXM" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E1_S4_E1_-_Les_retrouvailles" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E1_S4_E1_-_Les_retrouvailles.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E1_S4_E1_-_Les_retrouvailles" true & rd /s /q "media\tmp\ufBZUXM"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/3bd0758ddee56/c956944c-e144-4e48-8a49-fabc1e87ef7a-1710153585_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\tsfQj0n" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E2_S4_E2_-_Un_coach_de_renom_a_Deauville" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E2_S4_E2_-_Un_coach_de_renom_a_Deauville.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E2_S4_E2_-_Un_coach_de_renom_a_Deauville" true & rd /s /q "media\tmp\tsfQj0n"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/e1e4957deae56/19e24df8-1107-4f4b-b2c8-0a1567f5c6ee-1709895570_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\cWwD7i6" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E3_S4_E3_-_Un_cheval_pour_les_camarguaises" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E3_S4_E3_-_Un_cheval_pour_les_camarguaises.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E3_S4_E3_-_Un_cheval_pour_les_camarguaises" true & rd /s /q "media\tmp\cWwD7i6"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDF+YWNsPSUyZip+aG1hYz0wNDVlYjcwNDM2MTc3OTJjMzY1OGFkYTM2MDAzNjM3NjA4ZmI4NTc3MWI2ZWQ4OTI3ODVjN2FmZDhlZTdhZjA0/1234369deae56/9e471655-af4e-4313-b704-46762e513720-1709895820_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819541~acl=%2f*~hmac=c0edbac1c4d7f7d7c203be24a7aaaa7a0ef354a99bb2c15817f2087a4a4c50a4"  --tmp-dir "media\tmp\0NtOAqt" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E4_S4_E4_-_Un_champion_olympique_au_poney_club" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E4_S4_E4_-_Un_champion_olympique_au_poney_club.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E4_S4_E4_-_Un_champion_olympique_au_poney_club" true & rd /s /q "media\tmp\0NtOAqt"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDF+YWNsPSUyZip+aG1hYz0wNDVlYjcwNDM2MTc3OTJjMzY1OGFkYTM2MDAzNjM3NjA4ZmI4NTc3MWI2ZWQ4OTI3ODVjN2FmZDhlZTdhZjA0/616ed6c560f56/ff9476eb-fa35-4c69-972f-7b30408c97c5-1710254112_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819541~acl=%2f*~hmac=c0edbac1c4d7f7d7c203be24a7aaaa7a0ef354a99bb2c15817f2087a4a4c50a4"  --tmp-dir "media\tmp\PEUKQqP" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E5_S4_E5_-_Initiation_a_lequitation_comportementale" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E5_S4_E5_-_Initiation_a_lequitation_comportementale.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E5_S4_E5_-_Initiation_a_lequitation_comportementale" true & rd /s /q "media\tmp\PEUKQqP"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/bfe9341660f56/b593049a-49cd-4e4b-8fc2-400f2e73a3d5-1710254082_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\rrTcmus" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E6_S4_E6_-_La_voltige_pour_les_nuls" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E6_S4_E6_-_La_voltige_pour_les_nuls.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E6_S4_E6_-_La_voltige_pour_les_nuls" true & rd /s /q "media\tmp\rrTcmus"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/ff3e9ee74f466/b328abb9-05d6-498c-bbce-a0797a770d71-1716472259_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\UJBLKuO" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E7_S4_E7_-_Coquillages_et_irish_cob" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E7_S4_E7_-_Coquillages_et_irish_cob.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E7_S4_E7_-_Coquillages_et_irish_cob" true & rd /s /q "media\tmp\UJBLKuO"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/7f6e27f9caf56/ed80f97c-d2d2-4d6c-af4b-e134686ffc71-1710935244_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\livYt8A" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E8_S4_E8_-_A_lassaut_de_Cabourg" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E8_S4_E8_-_A_lassaut_de_Cabourg.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E8_S4_E8_-_A_lassaut_de_Cabourg" true & rd /s /q "media\tmp\livYt8A"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDN+YWNsPSUyZip+aG1hYz1jNzE2MGUxOGU1Zjc1ZTRlYzJiYjhiODViYTI1MzE3MTRjZDRhM2Y5ZGE2ZjI2NmI0OThhZGEzNWM1MTRmYjc5/5b09a95e65066/677a1540-d34e-406a-8cca-c28cba23903a-1711632225_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819543~acl=%2f*~hmac=e1e36c3755addf3e17f6b18721e6ac4aca777a3cf6bb4fe3a9bd3a2534a9a5cc"  --tmp-dir "media\tmp\jGzgWUx" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E9_S4_E9_-_La_competition_bat_son_plein" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E9_S4_E9_-_La_competition_bat_son_plein.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E9_S4_E9_-_La_competition_bat_son_plein" true & rd /s /q "media\tmp\jGzgWUx"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDN+YWNsPSUyZip+aG1hYz1jNzE2MGUxOGU1Zjc1ZTRlYzJiYjhiODViYTI1MzE3MTRjZDRhM2Y5ZGE2ZjI2NmI0OThhZGEzNWM1MTRmYjc5/552f93ae65066/9726a379-8b3f-4254-87ab-bac83e3af765-1711632549_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819543~acl=%2f*~hmac=e1e36c3755addf3e17f6b18721e6ac4aca777a3cf6bb4fe3a9bd3a2534a9a5cc"  --tmp-dir "media\tmp\8tyko4l" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E10_S4_E10_-_Un_nouveau_defi_pour_Firfol" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E10_S4_E10_-_Un_nouveau_defi_pour_Firfol.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E10_S4_E10_-_Un_nouveau_defi_pour_Firfol" true & rd /s /q "media\tmp\8tyko4l"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzZ+YWNsPSUyZip+aG1hYz1kNjMxMTk4MmQzYmFiNWNmYzM4NTI4ZmE5N2ZjMTUwZTk3ZGVjNzFiOGIyYzg5YTgwOTMzYjgzYzI2NWY4MzEx/a5fb7351ec166/e16a5fcf-51f2-446b-b4e8-79a6f3af0b05-1713169206_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819536~acl=%2f*~hmac=38dd333f91a39634c9009cbd17fe6bbad3de7bb05054af1d881f73345c653cdc"  --tmp-dir "media\tmp\Nq0jykG" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E11_S4_E11_-_Le_trec_cest_tranquille" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E11_S4_E11_-_Le_trec_cest_tranquille.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E11_S4_E11_-_Le_trec_cest_tranquille" true & rd /s /q "media\tmp\Nq0jykG"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzZ+YWNsPSUyZip+aG1hYz1kNjMxMTk4MmQzYmFiNWNmYzM4NTI4ZmE5N2ZjMTUwZTk3ZGVjNzFiOGIyYzg5YTgwOTMzYjgzYzI2NWY4MzEx/3a03c341ec166/c729b6be-8078-45b2-97de-5005566b79fe-1713169133_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819536~acl=%2f*~hmac=38dd333f91a39634c9009cbd17fe6bbad3de7bb05054af1d881f73345c653cdc"  --tmp-dir "media\tmp\1A4F6Q4" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E12_S4_E12_-_Lequitation_la_tradition_et_la_precision" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E12_S4_E12_-_Lequitation_la_tradition_et_la_precision.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E12_S4_E12_-_Lequitation_la_tradition_et_la_precision" true & rd /s /q "media\tmp\1A4F6Q4"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzZ+YWNsPSUyZip+aG1hYz1kNjMxMTk4MmQzYmFiNWNmYzM4NTI4ZmE5N2ZjMTUwZTk3ZGVjNzFiOGIyYzg5YTgwOTMzYjgzYzI2NWY4MzEx/d10f688dcf166/8e0cf7b7-d70b-4cba-8698-45ef4d5a175f-1713360884_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819536~acl=%2f*~hmac=38dd333f91a39634c9009cbd17fe6bbad3de7bb05054af1d881f73345c653cdc"  --tmp-dir "media\tmp\eDoCK0T" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E13_S4_E13_-_Des_sandales_pour_les_chevaux" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E13_S4_E13_-_Des_sandales_pour_les_chevaux.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E13_S4_E13_-_Des_sandales_pour_les_chevaux" true & rd /s /q "media\tmp\eDoCK0T"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzd+YWNsPSUyZip+aG1hYz0wYWI5ZjM4Yzc3MzhmZTk5ODQwMTY3ZTA2YTg3Y2Q1OTEzZThiMzJjOTY1MTk5MjVlNzgzZGEyOTk0ZTA4NWY0/2751f77ecf166/d43d6bb8-3d68-43b7-a067-d056bcf1eb36-1713361087_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819537~acl=%2f*~hmac=8df532e5485efb07de30a65a20454cfb125f9b8a7d2d340b0153192b64c22cff"  --tmp-dir "media\tmp\98YagIY" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E14_S4_E14_-_1_2_3_poney_" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E14_S4_E14_-_1_2_3_poney_.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E14_S4_E14_-_1_2_3_poney_" true & rd /s /q "media\tmp\98YagIY"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzd+YWNsPSUyZip+aG1hYz0wYWI5ZjM4Yzc3MzhmZTk5ODQwMTY3ZTA2YTg3Y2Q1OTEzZThiMzJjOTY1MTk5MjVlNzgzZGEyOTk0ZTA4NWY0/91d06ececf166/24254a5e-9fae-49f1-bdbd-649039317be2-1713361077_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819537~acl=%2f*~hmac=8df532e5485efb07de30a65a20454cfb125f9b8a7d2d340b0153192b64c22cff"  --tmp-dir "media\tmp\7qnq9eC" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E15_S4_E15_-_Savoir_trier_les_taureaux" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E15_S4_E15_-_Savoir_trier_les_taureaux.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E15_S4_E15_-_Savoir_trier_les_taureaux" true & rd /s /q "media\tmp\7qnq9eC"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzh+YWNsPSUyZip+aG1hYz00MmQwZWU3ZmJiNDkwZDhmZmRjYjdmYjJlNGNhMzQ3ZDdkNzQzZDNkNzc1NTViZWU5NTJhZjY1MjAwMDgxMmE0/42e6a8a0df166/e70cec7c-586e-49d5-ab33-23d4bce273ae-1713361482_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819538~acl=%2f*~hmac=d409c8cecfe6777a78b974eebd0591eaaa49b12a91a406289620bb8b7d0d2c9f"  --tmp-dir "media\tmp\vSaPDOK" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E16_S4_E16_-_Un_cours_avec_une_star_des_JO" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E16_S4_E16_-_Un_cours_avec_une_star_des_JO.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E16_S4_E16_-_Un_cours_avec_une_star_des_JO" true & rd /s /q "media\tmp\vSaPDOK"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/7ff6dd11df166/044e59ea-472a-4b9b-85fa-3174ef456614-1713361645_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\xmQ0NJb" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E17_S4_E17_-_Un_defi_pour_Celine_et_Norman" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E17_S4_E17_-_Un_defi_pour_Celine_et_Norman.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E17_S4_E17_-_Un_defi_pour_Celine_et_Norman" true & rd /s /q "media\tmp\xmQ0NJb"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/2990b461df166/c9382595-b511-4a8d-b158-168d2e0bbfbe-1713361774_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\2tlryQE" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E18_S4_E18_-_Le_trec_dans_tous_ses_etats" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E18_S4_E18_-_Le_trec_dans_tous_ses_etats.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E18_S4_E18_-_Le_trec_dans_tous_ses_etats" true & rd /s /q "media\tmp\2tlryQE"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/e2afe0a55e366/448c12ae-125b-4099-9298-76c102e62c7d-1715361713_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\aBR4E9i" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E19_S4_E19_-_Spa_pour_poney" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E19_S4_E19_-_Spa_pour_poney.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E19_S4_E19_-_Spa_pour_poney" true & rd /s /q "media\tmp\aBR4E9i"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/233083d55e366/99ace01f-64d7-4aa0-88b4-320621933d78-1715361785_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\WrOTJoj" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E20_S4_E20_-_Repetition_pour_le_spectacle" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E20_S4_E20_-_Repetition_pour_le_spectacle.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E20_S4_E20_-_Repetition_pour_le_spectacle" true & rd /s /q "media\tmp\WrOTJoj"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/2fff9e1706466/e37d1342-8c27-4f0a-8f50-7525e2aa39d7-1715865985_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\OSaUnMN" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E21_S4_E21_-_Colin_Maillard_et_debourrage" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E21_S4_E21_-_Colin_Maillard_et_debourrage.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E21_S4_E21_-_Colin_Maillard_et_debourrage" true & rd /s /q "media\tmp\OSaUnMN"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDF+YWNsPSUyZip+aG1hYz0wNDVlYjcwNDM2MTc3OTJjMzY1OGFkYTM2MDAzNjM3NjA4ZmI4NTc3MWI2ZWQ4OTI3ODVjN2FmZDhlZTdhZjA0/3b024c5706466/77aa53d1-e81d-494d-b9fd-146d574c1f7a-1715865942_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819541~acl=%2f*~hmac=c0edbac1c4d7f7d7c203be24a7aaaa7a0ef354a99bb2c15817f2087a4a4c50a4"  --tmp-dir "media\tmp\ea6D3cX" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E22_S4_E22_-_Une_fan_dAu_Galop_" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E22_S4_E22_-_Une_fan_dAu_Galop_.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E22_S4_E22_-_Une_fan_dAu_Galop_" true & rd /s /q "media\tmp\ea6D3cX"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDF+YWNsPSUyZip+aG1hYz0wNDVlYjcwNDM2MTc3OTJjMzY1OGFkYTM2MDAzNjM3NjA4ZmI4NTc3MWI2ZWQ4OTI3ODVjN2FmZDhlZTdhZjA0/e99ca88906466/53f2bb54-d62d-4f62-80e1-77950fe974d5-1715866450_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819541~acl=%2f*~hmac=c0edbac1c4d7f7d7c203be24a7aaaa7a0ef354a99bb2c15817f2087a4a4c50a4"  --tmp-dir "media\tmp\lYe9xDa" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E23_S4_E23_-_Le_marais_et_les_pouliches" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E23_S4_E23_-_Le_marais_et_les_pouliches.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E23_S4_E23_-_Le_marais_et_les_pouliches" true & rd /s /q "media\tmp\lYe9xDa"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDF+YWNsPSUyZip+aG1hYz0wNDVlYjcwNDM2MTc3OTJjMzY1OGFkYTM2MDAzNjM3NjA4ZmI4NTc3MWI2ZWQ4OTI3ODVjN2FmZDhlZTdhZjA0/7cb6b99906466/c551fcc3-f92a-4bc6-bd14-b6f92a0ed823-1715866350_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819541~acl=%2f*~hmac=c0edbac1c4d7f7d7c203be24a7aaaa7a0ef354a99bb2c15817f2087a4a4c50a4"  --tmp-dir "media\tmp\70vVEzg" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E24_S4_E24_-_Le_jeu_du_ruban" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E24_S4_E24_-_Le_jeu_du_ruban.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E24_S4_E24_-_Le_jeu_du_ruban" true & rd /s /q "media\tmp\70vVEzg"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/769e3f3a78566/18224ad2-fca7-48cb-8107-dec3005a3637-1717074905_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\TXY4OT8" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E25_S4_E25_-_En_Amazone" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E25_S4_E25_-_En_Amazone.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E25_S4_E25_-_En_Amazone" true & rd /s /q "media\tmp\TXY4OT8"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/8fc3208a78566/7d13da2a-f883-4df9-9cd3-1ea009fda848-1717074950_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\JwsMxVn" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E26_S4_E26_-_Premiere_balade_pour_Kasper" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E26_S4_E26_-_Premiere_balade_pour_Kasper.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E26_S4_E26_-_Premiere_balade_pour_Kasper" true & rd /s /q "media\tmp\JwsMxVn"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/c563740b78566/1a480dbc-43eb-4331-bf6a-50339db5f470-1717075156_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\LfNBXDf" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E27_S4_E27_-_La_retraite_de_Pin_up" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E27_S4_E27_-_La_retraite_de_Pin_up.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E27_S4_E27_-_La_retraite_de_Pin_up" true & rd /s /q "media\tmp\LfNBXDf"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDN+YWNsPSUyZip+aG1hYz1jNzE2MGUxOGU1Zjc1ZTRlYzJiYjhiODViYTI1MzE3MTRjZDRhM2Y5ZGE2ZjI2NmI0OThhZGEzNWM1MTRmYjc5/581bef3b78566/11e1d616-93bc-42f8-a58e-2fe041c11b1c-1717075199_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819543~acl=%2f*~hmac=e1e36c3755addf3e17f6b18721e6ac4aca777a3cf6bb4fe3a9bd3a2534a9a5cc"  --tmp-dir "media\tmp\5l7ueX4" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E28_S4_E28_-_Les_chaises_musicales" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E28_S4_E28_-_Les_chaises_musicales.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E28_S4_E28_-_Les_chaises_musicales" true & rd /s /q "media\tmp\5l7ueX4"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDN+YWNsPSUyZip+aG1hYz1jNzE2MGUxOGU1Zjc1ZTRlYzJiYjhiODViYTI1MzE3MTRjZDRhM2Y5ZGE2ZjI2NmI0OThhZGEzNWM1MTRmYjc5/dbc7256a16da2b/d30c7145-b4eb-4cff-9cb7-82c5108d0156_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819543~acl=%2f*~hmac=e1e36c3755addf3e17f6b18721e6ac4aca777a3cf6bb4fe3a9bd3a2534a9a5cc"  --tmp-dir "media\tmp\gU2D5u7" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E29_S4_E29_-_Celine_et_Norman_le_defi" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E29_S4_E29_-_Celine_et_Norman_le_defi.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E29_S4_E29_-_Celine_et_Norman_le_defi" true & rd /s /q "media\tmp\gU2D5u7"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDR+YWNsPSUyZip+aG1hYz1kNzFlYmU3ZjQ1NTU3OTRiY2QyOTY1MmMyMzNkNDYwYjlkOGU0OWY2ZWE4NzY1MmVhODU0NjE0NGY1YmQzYjI0/a4af6fc471ad20/ba473d4e-cab6-4564-b8bc-c6c42f3a8e49_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819544~acl=%2f*~hmac=5abbcdc4da709b9cc9ff3ec0fac45a89ee8f2ce8803746b7335e141902fa34f0"  --tmp-dir "media\tmp\KJfORGX" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E30_S4_E30_-_Celine_et_Norman_le_defi" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E30_S4_E30_-_Celine_et_Norman_le_defi.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E30_S4_E30_-_Celine_et_Norman_le_defi" true & rd /s /q "media\tmp\KJfORGX"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzZ+YWNsPSUyZip+aG1hYz1kNjMxMTk4MmQzYmFiNWNmYzM4NTI4ZmE5N2ZjMTUwZTk3ZGVjNzFiOGIyYzg5YTgwOTMzYjgzYzI2NWY4MzEx/8d14e21d1c22b0/b9e58a5d-68b2-4145-bd62-1da802b355aa_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819536~acl=%2f*~hmac=38dd333f91a39634c9009cbd17fe6bbad3de7bb05054af1d881f73345c653cdc"  --tmp-dir "media\tmp\Q2KanK2" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E31_S4_E31_-_On_va_aller_dans_le_cross_" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E31_S4_E31_-_On_va_aller_dans_le_cross_.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E31_S4_E31_-_On_va_aller_dans_le_cross_" true & rd /s /q "media\tmp\Q2KanK2"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1MzZ+YWNsPSUyZip+aG1hYz1kNjMxMTk4MmQzYmFiNWNmYzM4NTI4ZmE5N2ZjMTUwZTk3ZGVjNzFiOGIyYzg5YTgwOTMzYjgzYzI2NWY4MzEx/e2cc14880df28a/ded3c67a-3d71-40ec-8049-008452588151_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819536~acl=%2f*~hmac=38dd333f91a39634c9009cbd17fe6bbad3de7bb05054af1d881f73345c653cdc"  --tmp-dir "media\tmp\zIlYRwv" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E32_S4_E32_-_La_voltige_qui_vient_du_froid" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E32_S4_E32_-_La_voltige_qui_vient_du_froid.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E32_S4_E32_-_La_voltige_qui_vient_du_froid" true & rd /s /q "media\tmp\zIlYRwv"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzd+YWNsPSUyZip+aG1hYz0wYWI5ZjM4Yzc3MzhmZTk5ODQwMTY3ZTA2YTg3Y2Q1OTEzZThiMzJjOTY1MTk5MjVlNzgzZGEyOTk0ZTA4NWY0/e7927c869a91f3/8bed6678-97ce-4093-91c9-0c2dee6171ae_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819537~acl=%2f*~hmac=8df532e5485efb07de30a65a20454cfb125f9b8a7d2d340b0153192b64c22cff"  --tmp-dir "media\tmp\8uMUuNK" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E33_S4_E33_-_Une_fete_sous_haute_tension" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E33_S4_E33_-_Une_fete_sous_haute_tension.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E33_S4_E33_-_Une_fete_sous_haute_tension" true & rd /s /q "media\tmp\8uMUuNK"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzd+YWNsPSUyZip+aG1hYz0wYWI5ZjM4Yzc3MzhmZTk5ODQwMTY3ZTA2YTg3Y2Q1OTEzZThiMzJjOTY1MTk5MjVlNzgzZGEyOTk0ZTA4NWY0/80b62eb49ce061/a8bf4f4f-4fa0-4148-9188-0d26c4cad975_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819537~acl=%2f*~hmac=8df532e5485efb07de30a65a20454cfb125f9b8a7d2d340b0153192b64c22cff"  --tmp-dir "media\tmp\T9E7Krf" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E34_S4_E34_-_Pedicure_pour_les_chevaux" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E34_S4_E34_-_Pedicure_pour_les_chevaux.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E34_S4_E34_-_Pedicure_pour_les_chevaux" true & rd /s /q "media\tmp\T9E7Krf"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzd+YWNsPSUyZip+aG1hYz0wYWI5ZjM4Yzc3MzhmZTk5ODQwMTY3ZTA2YTg3Y2Q1OTEzZThiMzJjOTY1MTk5MjVlNzgzZGEyOTk0ZTA4NWY0/276f25ba25866/4e05d526-9bde-4495-9223-6126839c14f3-1720003763_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819537~acl=%2f*~hmac=8df532e5485efb07de30a65a20454cfb125f9b8a7d2d340b0153192b64c22cff"  --tmp-dir "media\tmp\j4NWrgi" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E35_S4_E35_-_Enzo_les_chevaux_et_les_flamands_roses" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E35_S4_E35_-_Enzo_les_chevaux_et_les_flamands_roses.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E35_S4_E35_-_Enzo_les_chevaux_et_les_flamands_roses" true & rd /s /q "media\tmp\j4NWrgi"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzh+YWNsPSUyZip+aG1hYz00MmQwZWU3ZmJiNDkwZDhmZmRjYjdmYjJlNGNhMzQ3ZDdkNzQzZDNkNzc1NTViZWU5NTJhZjY1MjAwMDgxMmE0/e1b2a5ca25866/fbce8422-ec1e-4d24-bffc-6ae6db8e743c-1720003772_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819538~acl=%2f*~hmac=d409c8cecfe6777a78b974eebd0591eaaa49b12a91a406289620bb8b7d0d2c9f"  --tmp-dir "media\tmp\apSlb9p" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E36_S4_E36_-_Premier_licol_pour_les_poulains" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E36_S4_E36_-_Premier_licol_pour_les_poulains.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E36_S4_E36_-_Premier_licol_pour_les_poulains" true & rd /s /q "media\tmp\apSlb9p"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzh+YWNsPSUyZip+aG1hYz00MmQwZWU3ZmJiNDkwZDhmZmRjYjdmYjJlNGNhMzQ3ZDdkNzQzZDNkNzc1NTViZWU5NTJhZjY1MjAwMDgxMmE0/369792b63d866/a97879ce-5f60-4dc9-b9e0-a6d6469eda8d-1720531105_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819538~acl=%2f*~hmac=d409c8cecfe6777a78b974eebd0591eaaa49b12a91a406289620bb8b7d0d2c9f"  --tmp-dir "media\tmp\hDTi7Uj" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E37_S4_E37_-_Trec_mise_en_situation" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E37_S4_E37_-_Trec_mise_en_situation.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E37_S4_E37_-_Trec_mise_en_situation" true & rd /s /q "media\tmp\hDTi7Uj"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/a4fdcfe63d866/d22ebd81-15ff-4854-bf1b-63121b5aed43-1720531205_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\8Tr9KGG" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E38_S4_E38_-_Le_saut_de_cheval_a_cheval" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E38_S4_E38_-_Le_saut_de_cheval_a_cheval.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E38_S4_E38_-_Le_saut_de_cheval_a_cheval" true & rd /s /q "media\tmp\8Tr9KGG"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/74d23b073d866/8c4a5fb8-04e0-400e-aff1-90e70ef953d1-1720531165_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\nVI0EJr" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E39_S4_E39_-_Les_firfolais_a_Lamotte-Beuvron" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E39_S4_E39_-_Les_firfolais_a_Lamotte-Beuvron.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E39_S4_E39_-_Les_firfolais_a_Lamotte-Beuvron" true & rd /s /q "media\tmp\nVI0EJr"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1Mzl+YWNsPSUyZip+aG1hYz05YTc4Njg2OGQ4NDkzYjBhNTFjZWM4ZWQxOWU0ZmI3Y2E2YzVhZThkZWU5OTFjMGMxMzNlOTEyMWQzMWE4OTMw/959a045146966/52b6de23-ea80-4090-b11d-b3d1d9bc39d1-1721123671_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819539~acl=%2f*~hmac=2222478c332dfdf4b4ff1eacf8dc5a3d5b4110fcfe7789c0628dd36675f7b25a"  --tmp-dir "media\tmp\GLTzb9N" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E40_S4_E40_-_Savoir_se_maitriser_en_concours" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E40_S4_E40_-_Savoir_se_maitriser_en_concours.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E40_S4_E40_-_Savoir_se_maitriser_en_concours" true & rd /s /q "media\tmp\GLTzb9N"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/581e122146966/8a7b7230-3370-4a18-af98-c71c71a82177-1721123596_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\tma0uIf" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E41_S4_E41_-_Lamotte-Beuvron_sous_haute_tension" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E41_S4_E41_-_Lamotte-Beuvron_sous_haute_tension.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E41_S4_E41_-_Lamotte-Beuvron_sous_haute_tension" true & rd /s /q "media\tmp\tma0uIf"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/53927b8146966/638a61c3-3b6a-4164-9ea5-815c77a79407-1721123681_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\2sJ9M5P" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E42_S4_E42_-_Les_resultats" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E42_S4_E42_-_Les_resultats.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E42_S4_E42_-_Les_resultats" true & rd /s /q "media\tmp\2sJ9M5P"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDB+YWNsPSUyZip+aG1hYz01ZjY4MDc5NmI1NjM0NDE3YzlhYjVmYjU1ODA2MzI2YzNiMGNiNzUyYWVlZTU0MWE3OWFiNzJjNGE1MDVhNTNl/49f5ce6c317a96/4d80ea13-1a85-4b43-ab12-56bd0b1f7b5c_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819540~acl=%2f*~hmac=37756ae985d136b5495d31caebf7c3615c80cbf6cae9aa4f4387e0231f01c146"  --tmp-dir "media\tmp\Mf7kLsd" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E43_S4_E43_-_Les_academiciens_et_le_concours_international" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E43_S4_E43_-_Les_academiciens_et_le_concours_international.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E43_S4_E43_-_Les_academiciens_et_le_concours_international" true & rd /s /q "media\tmp\Mf7kLsd"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDF+YWNsPSUyZip+aG1hYz0wNDVlYjcwNDM2MTc3OTJjMzY1OGFkYTM2MDAzNjM3NjA4ZmI4NTc3MWI2ZWQ4OTI3ODVjN2FmZDhlZTdhZjA0/f8529d29ff9c4c/973c5d97-d7c2-4dcf-a016-2a8ab3cb6ded_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819541~acl=%2f*~hmac=c0edbac1c4d7f7d7c203be24a7aaaa7a0ef354a99bb2c15817f2087a4a4c50a4"  --tmp-dir "media\tmp\uOLaOaW" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E44_S4_E44_-_Les_demons_de_Capucine" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E44_S4_E44_-_Les_demons_de_Capucine.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E44_S4_E44_-_Les_demons_de_Capucine" true & rd /s /q "media\tmp\uOLaOaW"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDF+YWNsPSUyZip+aG1hYz0wNDVlYjcwNDM2MTc3OTJjMzY1OGFkYTM2MDAzNjM3NjA4ZmI4NTc3MWI2ZWQ4OTI3ODVjN2FmZDhlZTdhZjA0/a1e05882976315/ead0ffb5-b47f-4f6c-9513-5a5231868dd4_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819541~acl=%2f*~hmac=c0edbac1c4d7f7d7c203be24a7aaaa7a0ef354a99bb2c15817f2087a4a4c50a4"  --tmp-dir "media\tmp\OFyBKjs" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E45_S4_E45_-_La_foulee_de_trop" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E45_S4_E45_-_La_foulee_de_trop.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E45_S4_E45_-_La_foulee_de_trop" true & rd /s /q "media\tmp\OFyBKjs"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/570006e3cd0a0b/2f7f92e5-78ea-4caf-8e88-0574a94e23e0_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\D0TyQfA" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E46_S4_E46_-_Des_nouvelles_de_Dali" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E46_S4_E46_-_Des_nouvelles_de_Dali.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E46_S4_E46_-_Des_nouvelles_de_Dali" true & rd /s /q "media\tmp\D0TyQfA"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDJ+YWNsPSUyZip+aG1hYz04MmYwMzM2MjEzZjdmODJkOGY4OGVjNjdmMTBlYWU1MTJjMjE3OTRjY2Q5Y2NkMGY1Y2I3YmRlZjcwYWYxNTA3/89f7b739644a91/e8c918a5-f7eb-4712-9075-d1695ab8e220_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819542~acl=%2f*~hmac=132e3f0f2ec297308cba7ccceee3d981c2247d734620477d0b520937ba565a18"  --tmp-dir "media\tmp\C5wT2H7" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E47_S4_E47_-_Un_tour_dhonneur" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E47_S4_E47_-_Un_tour_dhonneur.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E47_S4_E47_-_Un_tour_dhonneur" true & rd /s /q "media\tmp\C5wT2H7"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDN+YWNsPSUyZip+aG1hYz1jNzE2MGUxOGU1Zjc1ZTRlYzJiYjhiODViYTI1MzE3MTRjZDRhM2Y5ZGE2ZjI2NmI0OThhZGEzNWM1MTRmYjc5/21563ec3acb66/b9c431fa-0e8c-4cfc-8f48-160dc3684a4a-1723639188_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819543~acl=%2f*~hmac=e1e36c3755addf3e17f6b18721e6ac4aca777a3cf6bb4fe3a9bd3a2534a9a5cc"  --tmp-dir "media\tmp\RWpWVpl" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E48_S4_E48_-_Tradition_et_equitation" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E48_S4_E48_-_Tradition_et_equitation.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E48_S4_E48_-_Tradition_et_equitation" true & rd /s /q "media\tmp\RWpWVpl"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDN+YWNsPSUyZip+aG1hYz1jNzE2MGUxOGU1Zjc1ZTRlYzJiYjhiODViYTI1MzE3MTRjZDRhM2Y5ZGE2ZjI2NmI0OThhZGEzNWM1MTRmYjc5/d0f2c6c59aa31b/42d36fa0-f856-44e6-9f4b-3034c771f21f_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819543~acl=%2f*~hmac=e1e36c3755addf3e17f6b18721e6ac4aca777a3cf6bb4fe3a9bd3a2534a9a5cc"  --tmp-dir "media\tmp\ACCR2rU" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E49_S4_E49_-_Un_taureau_dans_larene" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E49_S4_E49_-_Un_taureau_dans_larene.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E49_S4_E49_-_Un_taureau_dans_larene" true & rd /s /q "media\tmp\ACCR2rU"
    N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3Mzg4NDA1NDR+YWNsPSUyZip+aG1hYz1kNzFlYmU3ZjQ1NTU3OTRiY2QyOTY1MmMyMzNkNDYwYjlkOGU0OWY2ZWE4NzY1MmVhODU0NjE0NGY1YmQzYjI0/17c464c3acb66/8dee969f-be99-48eb-ac6d-af50116d1a4d-1723639167_france-domtom_TA.ism/manifest.mpd?hdnea=exp=1738819544~acl=%2f*~hmac=5abbcdc4da709b9cc9ff3ec0fac45a89ee8f2ce8803746b7335e141902fa34f0"  --tmp-dir "media\tmp\OqK1tRi" --save-dir "media\france_tv\Au_galop_France_TV\S4_Saison_4\E50_S4_E50_-_Souvenirs_souvenirs" --save-name "content" -sv best -sa best -da id=audio_div -ss all -mt --check-segments-count false --no-log -M format=mkv & "terminal\mkvmerge.bat" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E50_S4_E50_-_Souvenirs_souvenirs.mkv" "media\france_tv\Au_galop_France_TV\S4_Saison_4\E50_S4_E50_-_Souvenirs_souvenirs" true & rd /s /q "media\tmp\OqK1tRi"
  25. Member
    Jan 2025
    VT 0.1.2
    Can you explain me , what's --query=3::4: means ?
    --query=3
    ---> (season 3)
    ::4:
    ---> = (Season 4)
    What's about to only one episode ? How i do that ?
  26. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Hello @froussard. If you type
    python widefrog.py --help
    python widefrog.py --usage
    You will find all explanations and usage examples. If you get shaka error, you need to place shaka-packager in env variables. Also, if you want to share download commands, it's best to take the ones as result from --basic parameter. That way they're as compact as possible
    Originally Posted by cartman03 View Post
    Thanks for this awesome script! Is it possible to add nbc.com? i would like to download from this list: https://www.nbc.com/shows/telemundo/a-z
    Thanks for the kind words. Unfortunately I don't add sites by request. You can learn scripting and code them yourself. There are guides on the forum
  27. Hi,
    A couple questions I think it's a great tool but i haven't been able to use it for the site i want it... so...
    Anyhow, i'd highly prefer to play the Dutch NPO live streamslocally using mpv for example (this would be the entrypoint: https://npo.nl/start/live?channel=NPO1).
    Your tool although it supports a lot of NPO already, doesn't know thus URL format. It gives me:
     [USER_ERROR] Failed to download: https://npo.nl/start/live?channel=NPO1. Reason: URL not supported. Solution: Extend the npo_nl service.
    I'm unfortunately a little too unfamiliar with python to make any sense of it.
    But i id make a script to extract the MPD stream url from any of the NPO live channels:
    #!/bin/bash
    # Step 1: Fetch the externalId for NPO1
    CHANNEL_DATA=$(curl -s "https://npo.nl/start/api/domain/guide-channels")
    EXTERNAL_ID=$(echo "$CHANNEL_DATA" | jq -r '.[] | select(.title == "NPO1") | .externalId')
    if [ -z "$EXTERNAL_ID" ]; then
      echo "Error: Could not find externalId for NPO1."
      exit 1
    fi
    # Step 2: Fetch the JWT token using the externalId as productId
    JWT_RESPONSE=$(curl -s "https://npo.nl/start/api/domain/player-token?productId=$EXTERNAL_ID")
    JWT_TOKEN=$(echo "$JWT_RESPONSE" | jq -r '.jwt')
    if [ -z "$JWT_TOKEN" ]; then
      echo "Error: Could not fetch JWT token."
      exit 1
    fi
    # Step 3: Fetch the stream URL using the JWT token
    STREAM_RESPONSE=$(curl -s -X POST "https://prod.npoplayer.nl/stream-link" \
      -H "Authorization: $JWT_TOKEN" \
      -H "Content-Type: application/json" \
      -d '{
        "profileName": "dash",
        "drmType": "widevine",
        "referrerUrl": "https://npo.nl/start/live?channel=NPO1",
        "ster": {
          "identifier": "npo-app-desktop",
          "deviceType": 4,
          "player": "web"
    STREAM_URL=$(echo "$STREAM_RESPONSE" | jq -r '.stream.streamURL')
    if [ -z "$STREAM_URL" ]; then
      echo "Error: Could not fetch stream URL."
      exit 1
    fi
    # Output the stream URL
    echo "$STREAM_URL"
    While right now that's NPO1 specific, it's very simple to tweak it for any of the NPO channels. Let me know if you want that change and i'll turn it into a command argument instead. You might be interested in that.
    Lastly, once your program can handle npo, how do i pipe it's output to either mpv or ffplay? I want to watch live tv after all, not download it and watch it later
  28. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Hello. Unfortunately, as the title of the post says, this tool is meant for downloading. If you want to restream content, you are free to write your custom scripts. I already see you got the hang of it. So I'm sure you won't have problems.
  29. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    Not really.
    I can't figure out how to dercrypt the live channels.
    What NPO does that apparently none others do is apparently a "cert" file (this one: https://widevine.npoplayer.nl/widevine_player_cert.bin). There definitely is still a licenseserser in the decryption dance but it's completely hidden away. By which i mean that you see no trace of it in the chrome devtools (netowrk tab) but you do see it pop up in wireshark. I did found that the chrome CDM probably does that and communications made from libraries in chrome aren't bound to the same logging rules apparently.
    I don't know how i can get further.
