Results 31 to 32 of 32
On the first video 1.avi black background orange text I see on screen jitter at 10 seconds.
I would suggest a better quality VCR like a JVC SVHS if available.
The cheapest option would be JVC HRS 7500 none TBC with ES10 or ES15.
Buying a TBC is difficult and expensive, most of the ones you see online are broken or have issues
A TBC can introduce tearing if you are dealing with 2nd 3rd 4th gen tapes.
It all depends on how serious you are on capturing if you are a perfectionist then a full frame TBC JVC SVHS VCR.
Second option would be weak TBC with ES10 or ES15.
Cheap option would be non TBC SVHS VCR connected to ES10 or ES15.
S-VHS JVC VCR as comb filter passthrough for non S-VHS VCR?
By Krazern in forum Capturing and VCRReplies: 22Last Post: 6th May 2024, 06:18 -
Panasonic DMR-E55 TBC, more than a simple line TBC?
By mracer in forum DVD & Blu-ray RecordersReplies: 13Last Post: 8th Dec 2023, 17:51 -
Comparison: Video8 captured via SVideo/TBC On; SVideo/TBC Off; DV
By Bwaak in forum Capturing and VCRReplies: 16Last Post: 27th Aug 2023, 13:40 -
Mono VCR + HiFi VCR As Passthrough = HiFi Audio Out?
By companda in forum RestorationReplies: 7Last Post: 16th Feb 2021, 11:18 -
A Blu-Ray player & VCR connected together, VCR input settings?
By Kzzrn in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2019, 10:15
