  1. I have almost fixed my Spiderman. I have ude TMPEGEnc I converted it to MPEG1, but when I tried to burn it with Adaptec Platinum, it said that the Frame Rate was unacceptable (was something like 420xsomething in the 500s-700's, I think) and the Bitrate was 2500, and I need to set it at 1150 for the bitrate. I can't figure out how to set it with TMPEGEnc, and I can't find anything in the Guide... Please help.
    May 2002
    Rainy City, England
    When you converted it it in TMPGEnc you should have chosen a VCD template. If we are talking bout the same movie, it is 25fps, so you need the PAL VCD template loaded in TMPGEnc. And setting the source aspect ratio to 4:3 fixed the wrong aspect ratio in the priginal (for me!).
    Having got the mpg from TMPGEnc I would prefer to use Nero. Adaptec stuff has caused me no end of problems. IMO it is over-priced bloatware. 8)
