Hi, I found this card in my box from back in the days, I see on ebay that people are pricing that card for 200$. What's the deal with that card ? Is it working on Win 10 maybe ?
Results 1 to 11 of 11
Nothing, The software is useless, The hardware depends if you can get it recognized by modern OS under some old drivers. It could well be DV hardware locked, meaning you can't get lossless AVI, only DV.
According to the posts on the German Gleitz video forum, it should also be possible to capture uncompressed Avi with the Storm 2 using Virtual Dub.
https://gleitz.info/forum/index.php?thread/47781-frage-zu-canopus-dvstorm2-und-virtual...einstellungen/ -
No. It does NOT capture uncompressed. You MAY be able to open/use it with vdub, but it is a DV device, and every thing coming into it is either Analog converted to DV or is a straight DV --> DV transfer. If vdub has options for other codecs, it is doing an ADDITIONAL conversion.
I know. I used to own this card/unit back in the early 2000s at my production company. One of the best & most versatile of DV cards at the time. (And contrary to what Dellsam34 said, the software was decent - again, at the time).
But time and technology has long since passed this by...
Scott -
I clearly said the software is useless, not was useless. Yeah Intel Pentium was decent too.
The card captures in DV, but the quality of its A/D conversion is at the top (codec is not the only merit figure). Excellent device.
Yes. Consider that it captures in DV, so a lossless approach is more adequate for analog capturing (modern cards have lower quality A/D conversion, but it is largely compensated by the lossless approach).
If you have a XP computer it's worth a try, otherwise stick to one of the recommended workflows.
If you get to do some capture with it (and eventually with a USB recommended card in parallel), post some samples here, so we can compare and give a feedback. -
I have two caputing cards, elgato and Pinacle 710. For VCR I use JVC S9760E VCR, now I'm fixing HS-1000, a lot of trouble with it, but I think I will manage to get it work.
Blackmagic Intensity Pro corrupts my Firewire Card
By Ferggue in forum Capturing and VCRReplies: 0Last Post: 2nd Jul 2023, 22:43 -
Is Final Cut Pro really that much better than Adobe Premiere Pro?
By videoguy102 in forum EditingReplies: 5Last Post: 9th Oct 2020, 06:34 -
Questions About Using the old Canopus DVRex capture card
By audioresearch in forum Capturing and VCRReplies: 2Last Post: 21st Jun 2020, 14:27 -
Canopus ADVC 110 with 2018/2019 MacBook Pro?
By catsynth in forum Capturing and VCRReplies: 7Last Post: 4th Apr 2020, 18:47 -
Premiere Pro CS6 crashing - is Nvidia video card to blame ?
By Bansaw in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2020, 16:04
