  1. I know you can thin dark lines that are thicker than you want with awarpsharp(depth=??).
    Is there an avisynth plugin for adding some thickness to lines that are extremely thin?
  2. For awarpsharp2, negative depth values warp in the opposite way - essentially thicken, positive values thin
  3. Along the same lines, you might be able to use a convolution matrix.
  4. Search for dilation - morphological operator - as johnmeyer suggested perhaps simple kernel operand will be sufficient.
  5. Originally Posted by poisondeathray View Post
    I didn't even know that awarpsharp and awarpsharp2 could take negative values. That's pretty interesting.
    It actually does kind of work. I think it softens the overall image a bit much in the process though. Still not too big of deal.
    Thanks!
  6. What also might be a way, is to use an inverted edemask expand it as much as you need and overlay a black image.
    (did that once on some cartoons and it worked nicely)
