Results 1 to 17 of 17
    May 2024
    California
    My Sony UBP-X700 BD player can play the ripped m2ts files with Dolby TrueHD with Dolby Atmos audio from usb drive properly. I use clever ffmpeg gui to remove the unwanted audio tracks. Then X700 player can no longer recognize the audio track, even though the same remuxed file can be played on PC without problem. Below is the mediainfo output for the original and remuxed m2ts file. Is there any way to fix it? Any advice will be greatly appreciated.
    Original file:
    General
    Complete name : J:\Original.m2ts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 892 MiB
    Duration : 4 min 9 s
    Overall bit rate : 30.0 Mb/s
    Maximum Overall bit rate : 48.0 Mb/s
    Frame rate : 24.000 FPS
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.1
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 4 frames
    Format settings, GOP : M=3, N=24
    Format settings, Slice count : 4 slices per frame
    Codec ID : 27
    Duration : 4 min 8 s
    Bit rate mode : Variable
    Bit rate : 26.9 Mb/s
    Maximum bit rate : 24.0 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.541
    Stream size : 797 MiB (89%)
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Menu ID : 1 (0x1)
    Format : MLP FBA AC-3 16-ch
    Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
    Commercial name : Dolby TrueHD with Dolby Atmos
    Muxing mode : Stream extension
    Codec ID : 131
    Bit rate : 640 kb/s
    Maximum bit rate : 7 104 kb/s
    Channel(s) : 8 channels
    Channel layout : L R C LFE Ls Rs Lb Rb
    Sampling rate : 48.0 kHz
    Frame rate : 31.250 FPS (1536 SPF)
    Compression mode : Lossless
    Stream size : 19.0 MiB (2%)
    Service kind : Complete Main
    Number of dynamic objects : 11
    Bed channel count : 1 channel
    Bed channel configuration : LFE
    Dialog Normalization : -31 dB
    compr : -0.28 dB
    cmixlev : -3.0 dB
    surmixlev : -3 dB
    dmixmod : Lt/Rt
    ltrtcmixlev : -3.0 dB
    ltrtsurmixlev : -3.0 dB
    lorocmixlev : -3.0 dB
    lorosurmixlev : -3.0 dB
    dialnorm_Average : -31 dB
    dialnorm_Minimum : -31 dB
    dialnorm_Maximum : -31 dB
    Audio #2
    Menu ID : 1 (0x1)
    Format : E-AC-3 JOC
    Format/Info : Enhanced AC-3 with Joint Object Coding
    Commercial name : Dolby Digital Plus with Dolby Atmos
    Format profile : Blu-ray Disc
    Codec ID : 132
    Bit rate mode : Constant
    Bit rate : 1 280 kb/s
    Compression mode : Lossy
    Stream size : 37.9 MiB (4%)
    Complexity index : 12
    Dialog Normalization : -29 dB
    compr : 0.53 dB
    cmixlev : -3.0 dB
    surmixlev : -3 dB
    dmixmod : Lt/Rt
    dialnorm_Average : -29 dB
    dialnorm_Minimum : -29 dB
    dialnorm_Maximum : -29 dB
    Muxed file:
    General
    Complete name : G:\sample_muxed.m2ts
    Format : BDAV
    File size : 802 MiB
    Overall bit rate : 27.1 Mb/s
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Codec ID : 27
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Scan type Dolby TrueHD with Dolby Atmos : Progressive
    Audio
    Menu ID : 1 (0x1)
    Format : MLP FBA 16-ch
    Codec ID : 131
    Frame rate : 1 200.000 FPS (40 SPF)
    Delay relative to video : -42 ms
    mixlevel : 80 dB
    ltrtcmixlev : 3.0 dB
    ltrtsurmixlev : 3.0 dB
    lorocmixlev : 3.0 dB
    lorosurmixlev : 3.0 dB
    Menu
    Menu ID : 1 (0x1)
    Format : AVC / MLP FBA
    List : 4113 (0x1011) (AVC) / 4352 (0x1100) (MLP FBA)
    Service name : Service01
    Service provider : FFmpeg
    Service type : digital television
    May 2024
    California
    I did some comparison between the audio tracks. I am curious why they are changed.
    Original:
    Muxed:
    May 2024
    California
    I try tsMuxeR. The m2ts file it creates can be played on X700 properly. The mediainfo output for the audio track is exactly the same as the original m2ts file.
    When I use tsMuxeR to open the file created by clever ffmpeg gui, I got the "Unsupported format, Some tracks not recognized. This tracks was ignored." error message for the audio track.
  4. Which version of clever FFmpeg GUI are you using?
    I have just tried with the latest release (v3.2.6) and the muxed m2ts file can be imported into tsmuxer without any problems.
  5. Member Ennio's Avatar
    May 2005
    Netherlands
    Probably because tsMuxer detects no embedded AC3 track in the TrueHD stream of the "muxed" file. Eventhough tsMuxer is perfectly capable of muxing "TrueHD only" - to both standalone m2ts and (UHD)BD - I can imagine your SONY player refusing to play when the embedded AC3 track isn't there. Try importing the original m2ts in tsMuxer, keep native "TrueHD+AC3" and in the GUI delete all unwanted streams prior to m2ts remux. Be sure to use latest nightly build.
    May 2024
    California
    I use v3.2.6 as well. This problem is specific to the TrueHD stream. Other audio tracks don't have this problem.
    May 2024
    California
    I also suspect the Sony player doesn't recognize the TrueHD stream because of missing AC3 track, after doing more research.
    Yes, if I import the original m2ts in tsMuxer and keep native "TrueHD+AC3", then delete all unwanted streams, the resulted file can be played on the Sony player. The trick is to keep the AC3 track.
    It's interesting to see that when I select both TrueHD and AC3, clever ffmpeg GUI still separates them as separated tracks, instead of leaving them intact. On the other hand, I can't keep TrueHD stream only without AC3 core with tsMuxer. I think each tool has its own use cases.
  8. Member Ennio's Avatar
    May 2005
    Netherlands
    ...This problem is specific to the TrueHD stream. Other audio tracks don't have this problem.
    FYI there is another peculiar case: EAC3-tracks on (UHD)BD are build around a AC3-core, which can be retrieved separately by tsMuxer.
    Maybe also handy to know: should you have TrueHD and the embedded AC3-track as separate streams, these can be interleaved back into "TrueHD+AC3" with thdmerge.exe. It comes with the DGDemux package.
    May 2024
    California
    You read my mind I was about to research this topic! Thanks a lot for the suggestion. I try it out. It works nicely.
  10. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    I use MKVToolNix as it doesn't re-encode or mess with any of the tracks.
  11. Member Ennio's Avatar
    May 2005
    Netherlands
    Actually when importing TrueHD with embedded AC3, MKVToolNix behaves the same way as clever ffmpeg seems to here. Matroska container being unfit for carrying interleaved TrueHD and AC3, MTX also has to de-interleave the two and mux them as separate tracks.
    I wouldn't know if OP's player would support playback mkv with TrueHD. I can very so imagine a SONY wouldn't.
  12. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    I must admit I don't use disc players anymore - transfer onto my NAS and then via Zidoo UHD3000 media player. All works well via my AVR and discrete speakers.
    May 2024
    California
    That's correct. X700 player doesn't support mkv with TrueHD. That's why I explore the possibility of playing m2ts file with TrueHD.
  14. Member Ennio's Avatar
    May 2005
    Netherlands
    Maybe there are other container formats - supported by your X700, that is - that can carry TrueHD with AC3 interleaved, but m2ts is the only one I know of.
    May 2024
    California
    I notice the video and audio are out of sync for the m2ts file created by tsMuxeR. Video is ahead of audio, but audio is in sync with subtitle. Comparing to the original movie, audio seems to play at the correct speed. Movie length is correct. The m2ts file created by clever ffmpeg gui doesn't have this problem. In tsMuxeR, I set the fps to the same value as I get from mediainfo. But it doesn't help. Any way to fix this?
  16. Member Ennio's Avatar
    May 2005
    Netherlands
    Maybe a bug in tsMuxer. The program isn't the best demuxer.
    Several things you can try. Be sure to use latest nightly build of tsMuxer, import the proper native playlist. Keep native TrueHD+AC3, take out unwanted streams and mux to BD folder structure instead of directly to m2ts.
    Other thing is remuxing with eac3to. It supports TrueHD+AC3 and you can use UsEac3To as GUI.
    Third option is to first demux the disc with DGDemux. It can put out *.thd+ac3 stream. Import only the desired demuxed streams in tsMuxer
    May 2024
    California
    Thanks a lot for the suggestion. Mux to BD folder structure solves the problem.
