Some reviewers were saying that KL's silent version of Hitchcock's Blackmail runs too fast. I've attached a sample of my BDRIP below. Is it running too fast? If it is, what FPS would be ideal, and how would I slow down the audio in Audacity to meet it without causing distortion?
https://mega.nz/file/9I9TVArD#QysABunIsyvUXYc_gHmbk-Eq_O5qIr0xa5BfJEb9w0M
Thanks!
Agreed. That clip runs perfectly fine. Maybe those who have commented are comparing it with another, faulty, version.
And BTW there is no need to use an external host for such a small clip. Simply load as an attachment in your post (and it will last longer than on mega) -
It's possible that it was filmed at a slower rate than 24fps. Hitchcock isn't around to ask. But the opinion of some reviewer isn't more valid than your opinion. What do you think?
The sound portions would have HAD to be 24fps, for sync reasons, but the silent original portions might have been anywhere between 16-25fps. My hunch is that the closer it got to studios converting to sound, they might have hedged their bets by standardizing closer to 24, but I could be wrong.
Perhaps work backwards - the original silent version was supposed to have a runtime of 75 minutes. Assuming the edits were correct, what fps would create such a runtime?
Batch convert audio from 23,976 fps to 25 fps with pitch correction
By darkmaster006 in forum AudioReplies: 2Last Post: 2nd Aug 2023, 20:52 -
Audio from 25 fps in 23,976 fps video always out of sync even if converted
By Huggy in forum AudioReplies: 5Last Post: 2nd May 2023, 05:05 -
QTGMC mov 29.970 (Constant fps) Ends up 58.42 FPS rather than 59.940
By VidNew23 in forum Video ConversionReplies: 9Last Post: 8th Apr 2021, 00:21 -
how can I mux 25 fps audio into 23.438 fps (1024 spf) ?
By precipizio in forum AudioReplies: 12Last Post: 16th Apr 2020, 15:06 -
IS there a ripping issue with newer Kino Lorber DVDs?
By Sephiroth666 in forum DVD RippingReplies: 2Last Post: 8th Oct 2019, 01:47
