Results 1 to 17 of 17
  1. 1. When I split videos by file size, I only got one file.
    2. When I split videos by keyframes, the videos are longer than they're supposed to be.
    How do I fix these problems?
    ffmpeg -i input.mp4 -fs 200M -c copy output_segment_%03d.mp4
    ffmpeg -i input.mp4 -f segment -segment_time 0 -c copy output%03d.mp4
  2. When I split videos by file size, I only got one file.
    -fs 200M
    -fs limit_size (output)
    Set the file size limit, expressed in bytes. No further chunk of bytes is written after the limit is exceeded. The size of the output file is slightly more than the requested file size.
    => that is not a split option, but an option that limits the output size.
     -segment_time 0
    segment_time time
    Set segment duration to time, the value must be a duration specification. Default value is "2". See also the segment_times option.
    Note that splitting may not be accurate, unless you force the reference stream key-frames at the given time. See the introductory notice and the examples below.
    => 0 seems like an odd choice
    Did you read https://ffmpeg.org/ffmpeg-formats.html#segment_002c-stream_005fsegment_002c-ssegment ?
    Also notice that splitting will only occur on key/idr frames (if no reencoding is done), thus independent of how you split, it's likely to be inaccurate.
    Additionally, if your content uses open-gop, you might not be able to split it at all.
    If you want to split an mp4 into 200MB chunks, using MP4Box might be better suited:
    mp4box -split-size 200000 input.mp4
    see: https://wiki.gpac.io/MP4Box/mp4box-dump-opts/#file-dumping
    Cu Selur
  3. Will splitting videos by using MP4Box be lossless? As well as remuxing mkv files to mp4? What if I used -crf 0 for splitting H.265 videos to H.264? How do I make it not cut at keyframes?
  4. Will splitting videos by using MP4Box be lossless?
    Yes, but it will also only cut on I/IDR-frames.
    That totally depends on what your content is. mvk supports way more formats (video/audio/subtitle) than mp4.
    If you want to cut mkv files you could use mkvtoolnix gui. (cut will be lossless and only on key frames)
    Assuming your input isn't raw video, you will get way !huge!r files.
    You use a tool what either completely reencodes or supports smart reencoding (only encodes at the start/end) of the cuts.
    Cu Selur
  5. You use a tool what either completely reencodes or supports smart reencoding (only encodes at the start/end) of the cuts.
    I mean when splitting videos using ffmpeg?
  6. I mean when splitting videos using ffmpeg?
    ffmpeg has no option for 'smart encoding', thus without re-encoding it can only cut on key-frames.
  7. Wait, I got something. When I split videos by keyframe, PotPlayer plays them incorrectly, but MPC-HC does. How do I fix the problem on PotPlayer?
  8. No clue about PotPlayer,...
    How did you split them? (hopefully not using '-f segment' since that is not really meant for all containers,....
    stream_segment is a variant of the muxer used to write to streaming output formats, i.e. which do not require global headers, and is recommended for outputting e.g. to MPEG transport stream segments. ssegment is a shorter alias for stream_segment.
  9. Originally Posted by Selur View Post
    So how was I supposed to split H.264/H.265 videos in mp4/mkv/mov files, then?
  10. mp4/mov -> mp4box
    mkv -> mkvtoolnix (mkvmerge if you use the command line)
    Cu Selur
    Ps.: with some scripting setting start&end points it might also be possible using ffmpeg (there might be a script for it somewhere in the forum)
  11. Originally Posted by Selur View Post
    mp4/mov -> mp4box
    Cu Selur
    Anything else? How do I make it so that the limit is strictly the file size I want?
  12. That is not possible, since:
    a. you can only cut on key frames
    b. gops will have different sizes
    So, strictly splitting into xy MB chunks while being able to still play the files is not possible.
  13. Originally Posted by Selur View Post
    I'm fine with re-encoding. How do I cut at regular frames using ffmpeg?
  14. You seek to the position you want to start and then set the number of frames (or length of the clip) you want to output. (read the Seeking page,...)
    (Probably easier to use Avidemux or similar,...)
    Cu Selur
  15. Originally Posted by Selur View Post
    Cu Selur
    And splitting them with re-encoding using ffmpeg?
  16. And splitting them with re-encoding using ffmpeg?
    1.
    2.
    answered that.
  17. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    I would also give it a try with Avidemux.
    It seems to make correctly playable cuts and lets you navigate easily from keyframe to keyframe.
