    Aug 2023
    Bergen, Norway
    Im tryna get MC Spuds to work but this error keeps popping up but I got MV Tools which includes MVAnalyse,
    I got MVTools.dll, DePan.dll and DePanEstimate.dll and MCSpuds.avsi in Plugins64+
    [Attachment 78998 - Click to enlarge]
    Mar 2008
    Are you using mvtools2.dll ?
    mc_spuds probably needs the original mvtools, all the functions were renamed in the newer version
  3. It looks required (very) old versions of mvtools with MV* names of functions. Try to look in the versions history when MV* finctions were renamed to M*. Versions history included in the end of documentation .html file.
    It lists:
    Since v2.2 MVTools.dll is renamed to mvtools2.dll, and since v2.3 all functions are renamed from MVxxx to Mxxx (e.g. from MVAnalyse to MAnalyse), so you can continue to use old MVTools 1.x with your old scripts, and you are able to use / make new scripts with MvTools 2.x without changing the dll loading.
