Hello, I have downloaded srt file from video streaming service but when I open it in SubtitleEdit, it shows thousands of useless and same lines. Is there a way to fix it properly?
[Attachment 78958 - Click to enlarge]
Thanks for any help
Results 1 to 12 of 12
If you open the srt with Notepad, do you see the same output? If so, I'd reckon there's something wrong with the srt and you'll have to find other means to get the subtitles. If output looks okay in Notepad, try another version of SE.
When you watch the streaming title, do you see an option to watch it with subtitles? This is just to make sure the title does have subtitles included.
Also how did you get the fake subtitles file? -
Can you upload a har file with all your network requests just for that video with the problem subtitles? Make sure you load your srt using their video player.
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
If you need the subtitles file and you don't succeed to download it, your best option is to transcribe the audio using Whisper AI.
Assuming of course that you managed to download the video. -
Just load it into Subtitle edit and select under TOOLS Fix common errors. Then untick all the error types that don't concern you, leaving remove duplicate lines.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
A possibility here:
https://downsub.com/
I think I used it once or so. See if it works with your stream since it shows a variety of download sources.
ffmpg, problem with path to srt file
By Cineman in forum SubtitleReplies: 8Last Post: 27th May 2023, 21:13 -
tsmuxer problem with srt
By diginoob in forum Video ConversionReplies: 5Last Post: 5th Sep 2022, 11:32 -
Many srt files into usf-8 srt files
By fits79 in forum SubtitleReplies: 3Last Post: 18th Aug 2022, 12:32 -
Can Livestream videos be downloaded?
By PlzHalp1424224 in forum Video Streaming DownloadingReplies: 4Last Post: 12th Nov 2020, 05:08 -
Srt to SSA Converter Problem
By jseo13579 in forum SubtitleReplies: 20Last Post: 19th Aug 2019, 07:53
