Results 1 to 10 of 10
  1. Hello,
    i want an object to swing back and forth throughout the whole video.
    like I demonstrate in this video, (I used the mouse cursor): https://youtu.be/jWCjQSKXQX8
    Does anyone know how?
  2. Member Cornucopia's Avatar
    "This video isn’t ready"
    Please fix your link.
  3. You can do it with ffmpeg using the Rotate filter (oscillating) in combination with an overlay. There is an example in the filter docs if I remember rightly.
  4. Originally Posted by Secoast View Post
    Thanks for your answer.
    I use this videoeditor and it does not support ffmpeg:
    https://www.videosoftdev.com/video-editor-doc/supported-formats-and-codecs
    Do you happen to know how I can use it?
  5. I have no experience with that program, but a quick look suggests the video transitions available do not include anything resembling your example, not in the free version at least. I don't know if the pro/paid for version has anything suitable.
  6. Looks like rotation and keyframes should do the trick
    https://www.videosoftdev.com/how-to-rotate-video
  7. Originally Posted by smrpix View Post
    I donīt think it can do this.
    I want to make it like that:
    video
  8. It does appear possible, but only in the pro version. There seem to be a lot of options that require upgrading. Not particularly user friendly either IMHO.
    If you have ffmpeg on your system I can post a script that should work.
  9. Originally Posted by vid001 View Post
    video
    That page I linked to is directly from the makers of the free version of the software you say you are using.
    video
    The option to use trajectory points is disabled in the free version, or rather exporting the output is disabled. It asks you to upgrade.
