Results 1 to 17 of 17
    May 2024
    France
    I think i have the pssh AAAAWnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADoIARIQzn 9i+aLcIUXhUJ51ZaH3JyIkZXlKaGMzTmxkRWxrSWpvaVkyeHBj Rjh4TXpBMk56QTJNU0o5
    I think i have the headers Accept-Language: fr-FR,fr;q=0.9,en-US;q=0.8,en;q=0.7
    Origin: https://www.6play.fr
    Referer: https://www.6play.fr/
    User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/124.0.0.0 Safari/537.36
    BUt it said {"code":400,"error":true,"message":"Failed to get license: 412 "}
    the link to my video is https://www.6play.fr/top-chef-p_872/s15-e8-2-2-c_13067061 Help me pls
    Dec 2021
    england
    --key ce7f62f9a2dc2145e1509e7565a1f727:de5df46bda25df958db095ee611ba4be
    N_m3u8DL-RE -M format=mkv --key ce7f62f9a2dc2145e1509e7565a1f727:de5df46bda25df958db095ee611ba4be "https://lbcdn.6cloud.fr/resource/m6web/s/m6web/output/4/a/1/4a16dfd52c05991924a4bf9aa7d35c5e88c3024a/static/13067061_2db01202581db08e584aaee481063121_web_dash_upTo720p_720p_vbr_cae_drm_software.mpd?expiration=1715212139&scheme=https&groups%5B0%5D=m6web&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpYXQiOjE3MTUxNzYxMzgsIm5iZiI6MTcxNTE3NjEzOCwiZXhwIjoxNzE1MjEyMTM5LCJyX2hhc2giOiJlMjNlMjBiNDRhZjVkYzUwYmEyMmM2YzUyNzlkZWJjYmYxMzNiMjBhIn0.SyMberpblDkMj22h2HC4U7J9253mTnlR1TaH6AuyOyw
    " --save-name video
  3. BUt it said {"code":400,"error":true,"message":"Failed to get license: 412 "}
    delete this line from the headers
    'Content-Type': 'application/x-www-form-urlencoded',
    May 2024
    France
    thank but how did you get the license url and the video is bugged with a lot of colors help me pls
  5. Member aqzs's Avatar
    Mar 2024
    Paris
    The licence will always be the same. The part ?specConform=true is to return the response directly and not in json format.
    You can use the following script :
    from pywidevine.cdm import Cdm
    from pywidevine.device import Device
    from pywidevine.pssh import PSSH
    import requests
    TOKEN = ''
    headers = {
        'x-dt-auth-token': TOKEN,
    pssh = input("PSSH? ")
    pssh = PSSH(pssh)
    lic_url='https://lic.drmtoday.com/license-proxy-widevine/cenc/?specConform=true'
    device = Device.load(r"/Users/noham/Documents/GitHub/DRM-remover/TOOLS/WVD/xiaomi_redmi_5_plus_v5.1.0-android_701ec55d_4445_l3.wvd")
    cdm = Cdm.from_device(device)
    session_id = cdm.open()
    challenge = cdm.get_license_challenge(session_id, pssh)
    licence = requests.post(lic_url, headers = headers, data=challenge)
    licence.raise_for_status()
    cdm.parse_license(session_id, licence.content)
    for key in cdm.get_keys(session_id):
        #print(f"[{key.type}] {key.kid.hex}:{key.key.hex()}")
        if key.type=='CONTENT':
            print(f"\n--key {key.kid.hex}:{key.key.hex()}")
    cdm.close(session_id)
    N_m3u8DL-RE 'https://th2-edge-01.cdn.bedrock.tech/m6web/output/4/a/1/4a16dfd52c05991924a4bf9aa7d35c5e88c3024a/static/13067061_2db01202581db08e584aaee481063121_web_dash_upTo720p_720p_vbr_cae_drm_software.mpd?st=9pQ4URwHqEZtRg34ItEJDQ&e=1715224079' --key ce7f62f9a2dc2145e1509e7565a1f727:de5df46bda25df958db095ee611ba4be -M format=mkv
    [Attachment 78945 - Click to enlarge]
    May 2024
    France
    ok thanks but when i ouput my final video it is glitchy with a lot of color so help me pls
  7. Member aqzs's Avatar
    Mar 2024
    Paris
    which command did you use to decrypt the video ? are you sure about the key you used ?
    May 2024
    France
    [h264 @ 0000011b1fe01840] top block unavailable for requested intra mode -1
    [h264 @ 0000011b1fe01840] error while decoding MB 0 0, bytestream 20430
    this what i got
    May 2024
    France
    sorry i was using the wrong key and thaks for your help
  10. Originally Posted by aqzs View Post
    import requests
    TOKEN = ''
    headers = {
    pssh = PSSH(pssh)
    Hello aqzs,
    again your script helped me out to get some keys from m6, see this thread.
    But now i am wondering how you guys indeed KNOW that we have to add this
    ?specConform=true
    at this end of the license request.
    Because when i follow all the guides of this forum, i just make a POSIX curl copy of the request, post it in https://curlconverter.com/, and here is what i get:
    [Attachment 84743 - Click to enlarge]
    As you see, no "?specConform=true" in the request, so how did you come to that solution?
    Just for interest, thx
  11. ah, aqzs disappeared several months. I don't know how or who find that param '?specConform=true'. but you can understand it as this: if you use that param, the license server will return bytes response, when you don't add that param likes you see in browser, you will get json response, you need parse it to get decryption keys. that's the difference. infact no difference, I prefer use no param one and parse json response since it never failed.
  12. ah ok thx, and can you show me how your script looks like then?
  13. It's straight forward; in my application it looks like:
        # license is the return object from license request
        license_content = license.content
        try:
            # if content is returned as JSON object:
            match = re.search(r'"(CAIS.*?)"', license.content.decode('utf-8'))
            if match:
                license_content = match.group(1)
        except:
            pass
        cdm.parse_license(session_id, license_content)
        keys = cdm.get_keys(session_id)
    IIRC the site rte.ie uses JSON with their license requests and responses.
  14. im not skillful on programing, so i can only give simple example, it looks like this:
    licence = requests.post('https://lic.drmtoday.com/license-proxy-widevine/cenc/', headers=headers, data=challenge)
    license_b64 = licence.json()['license']
    cdm.parse_license(session_id, license_b64)
  15. Yeah, that is if the license field in the returned JSON object is named "license"...
  16. only for sites use drmtoday, yes if want to write all in one tool, Obo's method more useful.
