Are there any freeware(or otherwise) that removes logos and watermarks completely from videos? Especially moving or floating watermarks. Ive come across videos that had moving watermarks splattered all across, thats been wiped clean. Of course its not the same as an original source without watermarks, its way cleaner.
There are quite a few programs that (supposedly) removes watermarks and logos. But most of them will usually just blur out the unwanted imagery and leave behind an obvious blur. Not the best solution.
I asked a similar question here. And on some watermarks and logos, the 'removal' was fairly good with little or no resulting blurring in place of the watermarks and logos. However, the best results were for small watermarks and logos. For larger watermarks and logos the results were not so good, as the original imagery was effectively lost behind the watermarks and logos and could no longer be restored. I couldn't get the 'Protrainer' to work as I'm not quite sure on how to run that software.
You could try this and see how things go. But again, this is not really effective against large areas of watermarks and large logos. -
The way watermarks work is usually shadow & highlight on the edges of the source logo, applied to the original video. If you can, in a sense, re-create & reposition that source logo, you could fairly easily reverse the shadowing & highlighting to restore the original video's original contrasts. A bit of (A + B) - B' = A' (if B' ~= B, then A' ~= A).
Also, some of the motion-compensated inter-frame-pasting tools can be of benefit that greatly reduces the blur factor.
need help 3 questions remove blackbars and adverts and watermarks video
By barry25 in forum Authoring (DVD)Replies: 6Last Post: 28th Oct 2023, 11:26 -
how to remove a program in win10/11 via cmd or powershell?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2022, 17:39 -
How to add two logos over the screen
By pokoloko in forum Newbie / General discussionsReplies: 7Last Post: 10th May 2022, 19:50 -
Help Removing Watermarks, and a difference of framerates with 2 clips
By AaliyahStan in forum EditingReplies: 0Last Post: 24th Apr 2021, 09:03 -
Program to remove streaks, lines, spots from VHS?
By Master Tape in forum RestorationReplies: 10Last Post: 10th May 2020, 15:42
