Results 1 to 13 of 13
  1. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    I have a lot of family img files (not DVD disks) that I would like to convert to mp4. I would appreciate any suggestions on software that would do that with no quality loss. Free if possible.
    I have tried searching the website, but couldn't find any posts that were current.
    I have used Format Factory for other things in the past, but lately I have seen some accusations of PUPs being loaded on installation, so am a bit leery. Don't know for sure if FF will even do it.
    Thanks...
  2. Try Leawo Prof.Media
  3. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    Thanks, but a couple of hundred bucks for a one-shot project isn't worth it.
    Appreciate the response.
    Mar 2008
    Isn't an IMG file some kind of disk image? What files are inside it?
    Can it be mounted in Windows or opened with Winzip or 7zip?
    May 2005
    PAL User
    In Win 10/11, try right-clicking and choose "Extract All..." and see what happens.
  6. There is a free curve method, first use free DVDStyler to create pictures into DVD, and then extract the VOB video in the VIDEO_TS directory of the DVD disc.
  7. Strange recommendations You can do it in i.e. DaVinci Resolve https://www.youtube.com/watch?v=eHj6Ed6fk7s and from a command line using ffmpeg, examples.
    May 2005
    PAL User
    @ranchhand, could you clarify IMG. Do you have images eg JPGs that you want to make into a video slideshow, or do you have a IMG on a disk and you want to convert it into a video file?
  9. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    @Alwyn & daveexnet and others....
    I have home movies that I made through the years and each one is burned to a DVD disk. An .img (image) file is one of those movies that was compressed for digital storage as .img.
    I created .img copies because DVD is disappearing, so I needed something current to replace physical disks.
    An image can also store data; my home computer backup system (Macrium Reflect) creates backup images of my entire OS, including all installed programs and data and I store it on an external SSD drive then disconnect it from the main system. In the event of a catastrophe or major virus infection (including ransomware) all I do is plug in the external drive, boot the computer from a bootable USB thumbdrive that has a bootable Macrium Reflect copy, and restore that image back onto my main SSD computer drive and I am back up and running in minutes like nothing ever happened.
    Images themselves can be mounted in Windows 7-11 with no problems, just 2/click on the image file, it mounts virtual, and you can run the movie or view the pictures easily. In the case of backups, I can also pull any data off the virtual mount and drop it on my desktop screen. VERY nice feature.
    I want to convert the movies to mp4 since that is the latest and greatest now. I see that .img is slowly going out of popularity.
    @noemi...thanks for the link, I am going to try it soon as I get a minute. Will post back with results....
    Thanks to everyone for responding!
  10. @ranchhand I got confused. So you have compressed movies to img storage format, not images (pictures). There are plenty of freeware programs like HandBrake, Shutter Encoder, clever FFmpeg-GUI which can convert DVD (VOB), and mpg to mp4 (h264). However, if your movies have extension mov then they are already in MPEG-4 format - then you don't need to convert them but remux to mp4.
    May 2005
    PAL User
    I'm not familiar with Macrium, but I use Acronis, which, by the sound of it, uses a similar "backup" system, where you can "open" a backup image for inspection or extraction of particular files. You say you can mount the IMG images; do that. If it's a backup of a DVD, you should be able to find the VIDEO_TS folder. Copy that entire folder onto your PC somewhere.
    From there, it is simply a matter of converting the video to MP4 using something like AVIDemux; I have written a guide for doing that here (the VOB conversion bit is at the bottom). However, I would consider leaving them in MPG format (the base codec for the VOBs on the DVD). That way, you won't have a conversion quality loss. MPEGs are generally larger than MP4s but if you are not disk-space challenged, I'd leave them as MPEGs.
  12. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    Thanks all....I cruised the internet and found a lot of software claiming to convert, but finally ended up with good old Handbrake which does the job (as naoemi said above #10). Should have stuck with it from the start. So Handbrake will work fine converting .img to .mp4 and *hopefully* I won't have to do this again for several years. I read in one webpage that Handbrake causes loss of quality in the conversion, but I don't see any, so I'm happy.
    Thanks to all for input and help!
    Oct 2007
    HandBrake can convert the IMG files to MP4. HandBrake is free.
