Are there any products on the market for this type of job?
I dont think so - going from Stereo WAV to Dolby AC3 seems like a very inexact science --- take 2 channels and split them into 5 ??
your pal,
Stinky -
You may want to try this http://minnetonkaaudio.com/Mx51_3.htm It may do what you want
I used Sonic Foundry Soft Encode. Its very good for encoding but doesnt seem to work with win xp.
Now I use Sonic Scenarist. Its a DVD authoring program that can take 6 (or less) wave files and encode them to a .ac3 file, but that is pretty much it.
If you can get it to work I recommend you use Soft Encode.
6 WAV files to one 5.1 AC3... need more help please..
By RogerTango in forum EditingReplies: 17Last Post: 13th Oct 2012, 09:00 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
AC3 to 6 Channel Wav
By RabidSmurf in forum AudioReplies: 13Last Post: 11th Jan 2009, 12:52 -
5.1 Wav to AC3
By markjwiggins in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 15:44 -
AC3 to WAV (MUST KEEP 6 CHANNELS)
By RushMaster in forum AudioReplies: 6Last Post: 17th Oct 2007, 05:03
