I've got a pretty good VHS capturing workflow: Panasonic AG-1980/Mitsubishi HS-HD2000U to DataVideo TBC-3000 to ATI All-In-Wonder. I've also picked up a Pioneer CLD-V2600 LaserDisc player, and I wanted to capture the original Star Wars trilogy (from before Lucas retconned it) to digital video. I'm not entirely satisfied with the first cut, and I wanted to ask and make certain that my techniques and settings were okay. Is the TBC necessary for LaserDisc output? Will I get better results from S-Video or the standard composite output?
At present I'm not able to buy any new equipment, but I'm also not interested in selling any of my VHS workflow. Just want to get the best results from what I've already got.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
--------Eric H. Bowen; USN Battleship Veteran (USS Missouri, BB-63, 1985-88)
16" Armor Piercing - When you care enough to send the very, VERY best! -
LD does not need a TBC, Depends on how good the comb filter of your LD player, Generally speaking LD is a composite format, S-Video will be output from the composite using a process called comb filtering, Some capture cards have good comb filter but some don't, you will have to do some tests and see for yourself which way is better capturing from S-Video or composite. There is a new process called Doomsday duplicator uses special hardware and more involved than a conventional capture.
The analog signal of a LD is time consistent (no need for a TBC, which would olnly degradate the signal path) and recorded as composite, then when capturing a Y (luma) and C (chroma) "separation" is necessary.
Where to do it, depends on the quality of the comb filter of the different devices. In my case, both the comb filters of my players (Pioneer DVL-909 DVD for instance) and my capture cards (Hauppauge USB-Live 2 for instance) are poor, so I used a JVC S-VHS VCR in passthrough mode.
But the best approach is LD-decode / Doomsday https://www.domesday86.com as dellsam34 properly pointed out.
Optimizing VHS capture with current equipment
By JoePoe in forum CapturingReplies: 20Last Post: 10th Apr 2024, 15:34 -
Recommended settings to capture vhs pal without editing
By prodarek in forum CapturingReplies: 44Last Post: 19th Feb 2024, 12:52 -
My Capture Equipment
By qwertz73 in forum CapturingReplies: 4Last Post: 25th Aug 2022, 15:56 -
How to convert VHS using old good equipment JVC VHS, ProcAmp
By eclecticmn in forum CapturingReplies: 3Last Post: 12th Jan 2022, 00:18 -
Being smart about picking the right equipment (video capture device).
By Ravenhawk in forum CapturingReplies: 5Last Post: 30th Mar 2021, 08:45
