I have a video that stutters on playback. How can I fix this and make it play smoother?
Let me know if you need more information. Thanks in advance.
Here is a short clip from that video.
https://mixdrop.is/e/gn9kzwpms7x0dq
MediaInfo:
Code:General ID : 1 (0x1) Complete name : E:\SLRC.TS Format : MPEG-TS File size : 101 MiB Duration : 1 h 0 min Overall bit rate mode : Variable Overall bit rate : 232 kb/s Frame rate : 25.000 FPS Video ID : 256 (0x100) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L3.1 Format settings : 3 Ref Frames Format settings, CABAC : No Format settings, Reference frames : 3 frames Codec ID : 27 Duration : 1 h 0 min Bit rate mode : Constant Nominal bit rate : 250 kb/s Width : 320 pixels Height : 240 pixels Display aspect ratio : 4:3 Frame rate : 25.000 FPS Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.130 Color range : Limited Audio ID : 257 (0x101) Menu ID : 1 (0x1) Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Format version : Version 4 Muxing mode : ADTS Codec ID : 15-2 Duration : 1 h 0 min Bit rate mode : Variable Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Delay relative to video : -120 ms
Results 1 to 1 of 1
When I split mp4 with Allok Video Splitter video is choppy/blurry
By cool09 in forum EditingReplies: 1Last Post: 26th Feb 2024, 06:41 -
Choppy video in Google chrome
By sendspellme in forum Newbie / General discussionsReplies: 1Last Post: 30th Jul 2020, 17:34 -
Video Preview Choppy
By yahtzeefish in forum Newbie / General discussionsReplies: 6Last Post: 26th Jul 2020, 20:04 -
Choppy video playback on multiple devices
By birdus in forum Software PlayingReplies: 4Last Post: 9th Jul 2020, 15:05 -
Choppy video
By Ivalogic in forum DVD RippingReplies: 9Last Post: 14th May 2020, 14:09
