  1. Does CleverGet have an fps setup? My friend is trying to record from Paramount+ at 29.970fps, but it comes out to 23.976fps instead.
    Mar 2021
    Israel
    I had bad experience with CleverGet about a year ago and got a refund in the end.
    You or your friend can try StreamFab they give you 3 free trials so use that wisely.
  3. Originally Posted by Subtitles View Post
    StreamFab now is mainly only a screen-recorder, it doesn't download anything anymore.
    Mar 2021
    Israel
    Really? on all modules or only Paramount+ ? I haven't used it for a while so this is bad news considering how much I paid.
  5. Originally Posted by Subtitles View Post
    I know for sure that Amazon module is re-encoding, so do Netflix module (when it works). Check the SF forum for more info. They are currently unable to overcome the DRM changes happened some months ago.
  6. Originally Posted by RacketWise View Post
    It downloads plenty. The Paramount+ module has worked fine for me.
    The later versions re-encode downloaded content from Amazon, which has led to quite the uproar on the forums.
  7. Originally Posted by Wikitime View Post
    Yeah the only module that works...
    Everything else is kaputt.
