I'd try the latest version then from github: https://github.com/nilaoda/N_m3u8DL-RE/releases/download/v0.2.1-beta/N_m3u8DL-RE_Beta_...0240828.tar.gz
				Results 31 to 46 of 46
	Nothing different. Exactly the same thing
 [Attachment 81936 - Click to enlarge]
	If "N_m3u8DL-RE" is not in the path, it will try to pick the (obviously bad) one from the path: "which N_m3u8DL-RE".
 Also: you need to give the binary executable permissions: "chmod +x N_m3u8DL-RE". Then try: "./N_m3u8DL-RE --help" and if that works, move it to /usr/local/bin (or some other place that's in your path: "echo $PATH").
 (And by now I'm able to type N_m3u8DL-RE without making mistakes ) )Last edited by Obo; 3rd Sep 2024 at 10:08.
	I have hired a developer who has experience with python web scraping but he has used N_m3u8DL-RE to download only the videos that aren't DRM protected. Can you please tell me how you decrypted the authentication keys to generate these codes? Which program did you use, etc, so I can pass it on to the programmer?
	1. I completely acknowledge the fact that you're not obligated to help and I appreciate your assistance with downloading the previous videos.
 2. No, I might have failed to communicate properly (I get that a lot). All I was asking from you is the program you used to generate the keys. How to run that program, that's for the guy I hired to figure out on his own. That's what he is being paid for.
 3. It's not really about nerve. I understand that I am not entitled to your help but you don't need to be so offended either. Anyways, thanks a lot for everything. I genuinely appreciate it all.
	And I don't expect you to help anymore, man. And that's fine, I completely understand. But just to clear my position;
 1. How am I supposed to know that the tool you used to generate the keys is developed by you? You might have shared it here before but as you know I am a newb here.
 2. Even if I knew it's your tool, a) the website clearly prohibits for me and others discussing paid services or anything of the sort and even if that was allowed, how do I know if you're even open to such an arrangement? Prior to hiring someone from upwork, I asked it here in the forum, one guy replied, and the reply was "NO CHANCE". So I think it's only reasonable for me to expect you to understand my intentions as well.
 Edit: I am still very much inclined to switch if you're open to it. I'd always prefer the guy who actually coded the tool than someone from upwork.
	I advise you to learn it yourself instead of wasting cash on programmers that aren't even competent. Read the sticky threads, you have key extractors there. --[----->+<]>.++++++++++++.---.--------.
	I have tried the best I could.
 1. I found it quite complicated as I have no knowledge about this stuff at all.
 2. For some reason, my machine is also not being of much help either. I have a mac air 2015 and a) whatever directory I try to open in the terminal, it says access denied although I have the read and write permissions for it and b) widevine (from the sticky threads) only supports windows which I don't have
	Thanks, man. I tried it again and turns out the problem is on Chrome's end.
 The manifest.json file provided by Widevine is V2 but Chrome needs V3.
 Additionally, I am trying to run N-m3u8DL_RE again on my macbook air 2015 monterey 12.7.6.
 The binary I'm trying to run is osx-x64 but it says Bad CPU type in executable although I am absolutely certain that I have run this exact same binary on this machine just 3 days back.
 [Attachment 82014 - Click to enlarge]
	Hey bro! It didn't work out with the developer I hired so I had to let him go.
 Another forum member was kind enough like you to help me with downloading the episodes from ptvflix.
 They have downloaded one but they're facing the same paywall issue that you did.
 Can you please share the proxy you used to access the content?
  Hi All, Newbie HereBy Valerie2 in forum Newbie / General discussionsReplies: 4Last Post: 4th Jul 2021, 07:45
  Newbie to BR ripBy biosdi in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2021, 03:21
  First Post, Newbie, GreetingsBy Tablerocked in forum Newbie / General discussionsReplies: 3Last Post: 13th Jan 2021, 19:07
  Newbie here with no signalBy Skuma in forum Capturing and VCRReplies: 10Last Post: 13th Dec 2020, 08:56
  Many Newbie QuestionsBy Oldtimer in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jun 2020, 07:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
