Results 1 to 13 of 13
  1. With what method or tools can this result be detected, for example?:
    "http://rtve-mediavod-lote3.rtve.es/resources/TE_SMLK20K/mp4/5/7/1623331653375.mp4?idasset=5937500",
    from this url https://www.rtve.es/play/videos/malaka/episodio-1-fenicios/5937500/
    Aug 2023
    Turkey
    first of all
    This content is only available by subscription.
  3. Here in Spain no subscription is required
  4. Not sure what you're requesting here, this is the info you need to download the video:
    MPD url:
    https://ztnr.rtve.es/ztnr/5937500.mpd
    PSSH:
    AAAAQ3Bzc2gBAAAA7e+LqXnWSs6jyCfc1R0h7QAAAAHMK0njmwsgTJzcR0+moNCfAAAADyIHNTkzNzUwMEjj3JWbBg==
    License url:
    https://3e6900a5.drm-widevine-licensing.axprod.net/AcquireLicense
    Headers:
    headers = {
        'x-axdrm-message': 'eyJhbGciO.......',
    Key:
    cc2b49e39b0b204c9cdc474fa6a0d09f:6fdf57e65aab943fff783aa19ed1826d
  5. How is this section filled out, as follows? 'eyJhbGciO......
    Headers:
    headers = {
    'x-axdrm-message': 'eyJhbGciO......',
  6. Originally Posted by Silv3r View Post
    Thank you, I didn't care about having this particular video, but rather knowing in general the method of detecting the download link so that it could help me with the rest of the files on that portal
  7. Originally Posted by ostris View Post
    I have written a script for you.
    rtse.py
    import requests
    import json
    import re
    from time import sleep
    def get_MPD_and_key(videoID):
        keyRequestURL = "https://api.rtve.es/api/token/{}".format(videoID)
        response = http_must_get(keyRequestURL).content
        licenseURL = json.loads(response)['widevineURL']
        token = json.loads(response)['token']
        mpdURL = "https://ztnr.rtve.es/ztnr/{}.mpd".format(videoID)
        headers = {'X-Axdrm-Message': token}
        mpdContent = http_must_get(mpdURL).content.decode('utf-8')
        pssh = re.search('<cenc:pssh>(.*)</cenc:pssh>', mpdContent).group(1)
        key = get_key_from_cdrm_project(headers, licenseURL, pssh, mpdURL)
        print(mpdURL)
        print(key['key'])
        print('\n')
    def get_key_from_cdrm_project(headers, licenseURL, pssh, mpdURL):
        while len(pssh) > 0:
            try:
                cdrmResp = requests.post("https://cdrm-project.com/api", headers=headers, json={"license":licenseURL,"pssh":pssh}).text
                key = (json.loads(cdrmResp)['keys'])[0]
                return key
            except:
                pssh = pssh[4 : len(pssh)]
        print('Issue getting key with cdrm-project, do manually:')
        print(mpdURL)
        print(pssh)
        print(licenseURL)
    def http_must_get(url):
        while True:
            try:
                response = requests.get(url)
                return response
            except:
                sleep(1)
    def main():
        episodesPage = http_must_get('https://www.rtve.es/play/videos/modulos/capitulos/127490/').content.decode('utf-8')
        episodeLinks = re.findall('episodio(.*)/(.*)/" title=', episodesPage)
        for i in range(len(episodeLinks)):
            get_MPD_and_key(episodeLinks[i][1])
    if __name__ == "__main__":
        main()
    Output
    https://ztnr.rtve.es/ztnr/5938596.mpd
    e5f78c9f7646f790eab443effd763b97:af3bc89b1d313e0382bf1f5ef8e2de15
    https://ztnr.rtve.es/ztnr/5945556.mpd
    3ed9dd36e45bfa186cddcc40a7b04719:a61500c665d787bae6491a82236783c9
    https://ztnr.rtve.es/ztnr/5956533.mpd
    be486b1f533aa8215831a00ffef5d3a8:cc53983b07e57d95db2b2b4b7ff89ff3
    https://ztnr.rtve.es/ztnr/5968159.mpd
    51fb2e361ec72ce14e7fe8e0d9e7d802:7c91d23ef2d73b6c17cfb0d807f12128
    https://ztnr.rtve.es/ztnr/6003241.mpd
    795fa695b7d3c2d681b5b5d48ddbe2d4:1b205e56763c9d818ebbd2e50570ab47
    https://ztnr.rtve.es/ztnr/6011735.mpd
    fea704bd7c3355cabe50edd09f2cf193:94e8867008e4b49b2bcd41e1df227dc8
    https://ztnr.rtve.es/ztnr/6028721.mpd
    ed4410d7bf39315d524cfc0b0dbe1d7f:7d4e96299c6777bff2ea2d748856ab3c
    You can read the script and figure how the site works.
  8. Unencrypted stream:
    https://www.rtve.es/drmn/embed/video/5937500
    inspect element->network tab->search "m3u"
    https://rtvehlsvodlote7.rtve.es/mediavodv2/resources/TE_SMLK20K/mp4/5/7/1623331653375.mp4/video.m3u8?hls_no_audio_only=true&hls_client_manifest_version=3&idasset=5937500
    change to
    https://rtvehlsvodlote7.rtve.es/mediavodv2/resources/TE_SMLK20K/mp4/5/7/1623331653375.mp4?idasset=5937500
  9. Originally Posted by ostris View Post
    use https://pasty.info/
  10. How could I guess this part with the ID number for any other movie or series on the portal?
    Knowing this I could modify the script for any other search. Thank you
    rtse.py
    import requests
    import json
    import re
        print(mpdURL)
        print(key['key'])
        print('\n')
            try:
                return key
            except:
        print(mpdURL)
        print(pssh)
        print(licenseURL)
        while True:
            try:
                return response
            except:
                sleep(1)
    def main():
        main()
    Output
    You can read the script and figure how the site works.[/QUOTE]
    THANK YOU I have already found out the method for this chapter but how do I find out this url if I wanted to guess the ID for the rest of the series on the rtve.es/play portal? https://www.rtve.es/play/videos/modulos/capitulos/127490
    Knowing this, I could access the information I would need for the rest of the movies and series on the portal.
  11. Originally Posted by ostris View Post
    For other dramas, to get the "capitulos" link:
    go to main page with episodes -> inspect element -> network tab -> click on "EPISODIOS"-> search/filter "capitulos"
    Modify the "capitulos" link in the script for other dramas
  12. Originally Posted by Frieren View Post
    [Attachment 78863 - Click to enlarge]
    I didn't see it anywhere that was confusing. Now I do. Many thanks for everything
