Hello
I have several vob files extracted from a dvd.i want to merge them and create a dvd with chapters.I want to use 1 vob file = 1 chapter.menus are optional.
In final output total of vob files capacity should equal final dvd merged video files capacity.(without loosing quality)
So please help me to create this dvd..
Thank you
All re-encoding results in a loss original quality.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Op never said anything about re-encoding,just use a free program that can do all that without re-encoding,do a search here for dvd authoring.
Womble Mpeg Video Wizard can change .vob to .mpg without touching the file itself, just changing the container. You can import all your vobs to the timeline, cut them if needed, then you can export them, and the export panel will offer the option to reconvert or just change the container. It is the best editor for those files.
And you can author the DVD as well from your project.
But it is not available any more officially, you need to download it from third party sites. Their website has shut down in recent years. -
DVDStyler can import .vobs and add chapters and basic menus. It doesn't reencode if the .vobs are DVD compliant.
For authoring you could also try the good and ole' DVDAuthor / DVDAuthorGUI ..... -
I would demux the material using the old MPEG Streamclip, and then author it in DVD Studio Pro or some lesser PC program.
convert HEVC video to H.264 mp4 without loosing quality
By jimclark in forum Video ConversionReplies: 8Last Post: 20th Mar 2024, 15:38 -
AVC editor without loosing quality
By tad108 in forum EditingReplies: 0Last Post: 13th Aug 2023, 08:18 -
Merging 3D MTS videos without loosing the 3D and the overall quality
By DashInc in forum EditingReplies: 16Last Post: 15th Oct 2021, 03:21 -
Creating DVD Menus Multilingual Fully Customizable
By Chris13 in forum Authoring (DVD)Replies: 6Last Post: 6th Jan 2021, 21:44 -
Cannot get AVI files to play in original quality on Apple TV
By tarnished88 in forum Video ConversionReplies: 3Last Post: 31st Aug 2019, 17:08
