Hello, i have few videos with Dolby Vision Profile 7.6
Problem is on my tv (Sony Bravia xf9005) it plays black and white only.
Also have videos with Dolby Vision Profile 8.1 and they play correctly.
So is there some way with MKVToolnix or anything else to change that profile ?
Code:Title 4K Dolby Vision HEVC Codec HEVC Dolby Profile Profile 7.6 (Bluray) Profile Main 10 Level 153 Resolution 3840x2160 Aspect Ratio 16:9 Interlaced No Framerate 23.976 Bitrate 79 mbps Video Range DolbyVision Color Primaries bt2020 Color Space bt2020nc Color Transfer smpte2084 Bit Depth 10 bit Pixel Format yuv420p10le Reference Frames 1Thank you for suggestions.Code:Title 4K Dolby Vision HEVC Codec HEVC Dolby Profile Profile 8.1 (HDR10 compatible) Profile Main 10 Level 150 Resolution 3840x2160 Aspect Ratio 16:9 Interlaced No Framerate 24 Bitrate 15 mbps Video Range DolbyVision Color Primaries bt2020 Color Space bt2020nc Color Transfer smpte2084 Bit Depth 10 bit Pixel Format yuv420p10le Reference Frames 1
You would need to convert the metadata not just changing the profile info.
dovi_tool should be able to convert the metadata.
There are guis like HDR-Multi-Tool out there, but I have never tested them.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Just thinking out loud here, have you tried whether your SONY tv does accept P7 in mp4 container? Where you may wanna try both STDL (single track dual layer) and DTDL (dual track dual layer). P7 in mkv is STDL. Remuxing to (STDL) mp4 can easily be done with cleverFFmpeg GUI.
I don't know of a all-in-one-tool that properly converts Dolby Vision P7 to P8. I know MKVToolNix certainly doesn't. There are several free DoVi scripts at your disposal, written by several DoVi knowledgable guys. Using these scripts do call for some learning on your part about several DoVi constructs.
Mkv with Dolby Vision?
By meimeiriver in forum Authoring (Blu-ray)Replies: 1Last Post: 9th Sep 2023, 05:28 -
Dolby vision profile 7 to 5?
By Maradon in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2023, 04:20 -
Converting colorspace of a Dolby Vision UHD Blu-ray
By RajaSteve in forum RestorationReplies: 0Last Post: 12th Dec 2022, 09:48 -
Dolby Vision Hybrids
By GreekUser in forum Video ConversionReplies: 4Last Post: 28th Jul 2022, 12:13 -
Dolby Vision
By JosephTocco in forum Newbie / General discussionsReplies: 15Last Post: 31st Oct 2021, 05:06
