Hi, forgive me if this isn't the right forum for this, but ultimately, I'm working towards authoring a BDXL disc with an NTSC VHS source that I ran through an AI upscaler that upscaled the resolution by x2 (so currently 1440x960).
After capturing my NTSC VHS in VirtualDub at 720x480, and applying some moderate restoration via Avisynth and an AI model that was designed for restoration, which also happened to upscale the resolution by x2, I'm up to about 76gb for my AVI. I'd like to keep it that way, I'm not interested in lowering the file size. So I'm planning on authoring to a BDXL disc.
With that said, how would the 1440x960 resolution work on a blu-ray when being played in a blu-ray player on a TV? Would I have to do any work on the resolution so that it would display correctly? Would the aspect ratio be completely messed up?
Results 1 to 9 of 9
You should be interested in reducing the filesize , because authored BD disc - playable in a BD player - has restrictions on codecs, bitrates. They can only read from optical disc and transfer into the buffer at a given rate
Read up on what is blu-ray , bitrates, and restrictions in terms of encoding, settings, VBV buffer. There are many threads covering this, and what is compliant. Otherwise it won't author correctly, won't play correctly , will stutter or won't play at all
Authored Blu-ray also has restrictions on resolutions and frame rates. If it was 23.976p, you would use a 1920x1080 frame . A 4:3 perfect AR source would be pillarboxed . 1440x1080 with 240px left and right. You might have to adjust that a bit depending on if you cropped borders or what the true AR of the image is -
1440x960 is double of 720x480 . But NTSC VHS is not "square pixel" format. The AR is most likely wrong if you keep it 1440x960 and both
pillarboxed,letterboxed in a 1920x1080 frame . ie. 1440x960 is the wrong square pixel dimensions - you have to scale width, height, or both
A "normal" 4:3 DVD or VHS does not display at 720x480 either. -
Also you want to crop the junk off around the frame and leave it clean after de-interlacing and before upscaling to 1440x1080, I would think Blu-ray accepts 4:3 AR in 1440x1080, doesn't it?
Good to know, So padding to 16:9 is a must then.
Is your footage really 23.98p? That is very unusual for a tape source, unless you knowingly applied IVTC.
Aside of everything else stated regarding the pillarboxing and AR, you can most likely compress it nicely to a lower filesize without hindering quality and maybe even make it fit on a standard BD50.
BluRay Player with BDXL Support
By Jake802 in forum DVD & Blu-ray PlayersReplies: 562Last Post: 9th Sep 2025, 07:19 -
burning 4k iso to bdxl blurays
By frankpickles in forum Newbie / General discussionsReplies: 4Last Post: 27th Feb 2024, 22:40 -
Terratec Cinergy 400 Proper Aspect Ratio for Recording and Handling
By Tek03 in forum RestorationReplies: 31Last Post: 16th Aug 2022, 14:07 -
NTSC VHS newbie summary #5: Resolution mp4 creation & upscaling
By brockway in forum Video ConversionReplies: 0Last Post: 29th Jan 2022, 10:43 -
S-VHS + HDMI upscaler + HDMI capture?
By Jupit0r in forum Capturing and VCRReplies: 2Last Post: 22nd Aug 2020, 03:00
