Hi. My JVC HRS3800u S-VHS deck won't respond to the Power On button. It had been in a box for over 20 years. When I plugged it in and tried to turn it on nothing happened. I checked the internal fuse and it's intact. I saw that there was a VCR tape stuck inside so I followed the directions in the service manual to get that out. As soon as I plugged it in again after that it powered up long enough to return the cartridge mechanism to its normal (empty) position, then shut down again. Clearly the power is getting through, but something is preventing it from powering up.
Any suggestions?
Thanks.
Check your voltages at the power supply, check for leaky or bulgy capacitors, clean the mode switch and go from there, Repairing VCRs requires some skills.
JVC HR-S7600AM S-VHS VS. HM-DH5U D-VHS Capturing a VHS Tape
By dellsam34 in forum Capturing and VCRReplies: 26Last Post: 25th Aug 2023, 11:18 -
JVC SR-MV45 First Time Power Up
By AndyO6322 in forum Capturing and VCRReplies: 1Last Post: 29th Nov 2022, 03:46 -
How to convert VHS using old good equipment JVC VHS, ProcAmp
By eclecticmn in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2022, 01:18 -
Solved: Ematic AT103 DVR won't power on
By jimdagys in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Oct 2020, 19:37 -
VHS/JVC Compact VHS conversion to PC desktop
By m123caren in forum Capturing and VCRReplies: 10Last Post: 6th Jan 2020, 03:56
