Results 1 to 10 of 10
  1. So i tried using Shaka packager but it's giving this error could anybody help?
    was following this guide https://forum.videohelp.com/threads/408557-Decryption-The-Last-Crusade
    i also tried Mp4decrypt but it shows this application cannot run in this device contact distributor.
  2. Where did you download your shaka packager binary from? Download it from here: https://github.com/shaka-project/shaka-packager/releases
  3. i downloaded from the official link https://github.com/shaka-project/shaka-packager/releases should reinstall it or maybe older version??
  4. Originally Posted by white_snake View Post
    yeah i think it got i solved i downloaded older version bro can u help me a little bit more can u write the code of it
    keys [ b3af32f237be4b24d053256eb57f4294:3617bd30da9cd5fa3 9328235fb49155a
    aa46933d36476da7c869df1b39429898:a7834a02f23b750f6 79a8b708214047b
    e16c8e7126666089b531168f98cc4406:425ee14a0e3a5c30e 040341e985389ee ]
    my input file audio C:\shaka-packager\master-03028928be-1702995022883.en.m4a
    output file location C:\shaka-packager\WhatIf01.m4a
  5. Originally Posted by koustubhh View Post
    I guess something like this should work:
    packager-win-x64.exe in=C:\shaka-packager\master-03028928be-1702995022883.en.m4a,stream=audio,output=C:\shaka-packager\WhatIf01.m4a --enable_raw_key_decryption --keys key_id=b3af32f237be4b24d053256eb57f4294:key=3617bd30da9cd5fa39328235fb49155a,key_id=aa46933d36476da7c869df1b39429898:key=a7834a02f23b750f679a8b708214047b,key_id=e16c8e7126666089b531168f98cc4406:key=425ee14a0e3a5c30e040341e985389ee
    Or just try the key pairs one at a time.
  6. Thanks but it says packaging error 8 cannot parse into media file
  7. Image
    [Attachment 78709 - Click to enlarge]
    is that mean my keys are invalid or i'm doing something wrong and stupid??
  8. Try this first:
    https://www.bento4.com/documentation/mp4info/
    mp4info --verbose master-03028928be-1702995022883.en.m4a
    and check:
    default_KID = [00 00 XX XX XX XX XX XX XX XX XX XX XX XX XX XX]
    that matches your KID:KEY
    If the KID is right, try this with MP4decrypt:
    https://www.bento4.com/documentation/mp4decrypt/
    mp4decrypt --show-progress --key KID:KEY master-03028928be-1702995022883.en.m4a master-03028928be-1702995022883-DECRYPTED.en.m4a
    More comprehensive guide on using Bento4 tools can be found here.
    If I was in politics I make sure you drink plenty of beer
    and watch plenty of TV to keep you busy. | Data is the new oil.
  9. Try this:
    shaka-packager input="WhatIf01.mp4",stream=audio,output="D:\WhatIf01.mp4" --enable_raw_key_decryption --keys label=0:key_id=b3af32f237be4b24d053256eb57f4294:key=3617bd30da9cd5fa39328235fb49155a,label=1:key_id=aa46933d36476da7c869df1b39429898:key=a7834a02f23b750f679a8b708214047b,label=2:key_id=e16c8e7126666089b531168f98cc4406:key=425ee14a0e3a5c30e040341e985389ee
  10. Originally Posted by koustubhh View Post
    Error is pretty clear to me: it's telling you that the KID of the audio stream you're trying to decrypt is 711121a59... and there's no matching KID:KEY pair for this KID. In other words, those are not the right keys for this stream.
