    May 2012
    adelaide
    this is strange i have been running two bluray burners for years without a problem first in w100 then after the upgrade to 11
    My mother board gave a lot of problems crashing bluescreen then destroying windows start up
    in the service department they replaced the mother board and as i informed them of my requirement on the two burners they set windows to w10
    for some reason now i have a problem running two together
    they show waiting the disc to reach threshold
    waiting buffer to recover
    it takes far to long to burn now using two discs
    some times one shows cant finalize disc and the disc is blank
    i use imgburn
    it was suggested to try nero neither are any different
    Please someone assist me in getting back out of this problem
    Regards to all Bob
    Feb 2006
    i use imgburn
    Regards to all Bob
    the "waiting the disc to reach threshold" means your HDD or SSD is busy doing other things - https://forum.imgburn.com/topic/22995-what-does-waiting-for-threshold-mean/ try running chkdsk and do a full defrag, see if that helps.
    May 2012
    adelaide
    tried updating drivers . chkdsk , changing sata cables
    no joy any other i can try
    her is one other strange issue
    i burnt two dvd disc and it worked
    but not bluray is that a help to someone
    i have 64GB memory
    Feb 2006
    i have 64GB memory
    try uninstalling both burners, restart your computer
    and let windows reinstall both burners, see if that works.
