I have a Syba 1394B card and it has known issues working with old dv camcorders, as you need the drivers for such devices and it does not connect to the camera itself. I was told to get a Texas Instruments card for the chipset. What cards are recommended today for PCI-E and 1394B, that dont have issues being able to work and connect with old DV camcorders, and dont need drivers either? Also I heard of switching the cards driver to the Legacy driver, but I dont know why? Which card will also work under Windows 10 and 11 64 bit? I just want to make sure whatever card I'd use works under the current Windows and also doesnt have a problem connecting with DV camcorders. Any suggestions?
I'll be using OBS Studio to capture the tapes. Tapes will be both SD and HD. My other option is to use a motherboard with the 1394B port on the back and run Windows 8 on an older computer setup.
Results 1 to 30 of 38
For Firewire IEEE1394A (you don't need 1394B for DV transfer), no camcorders have or need drivers. The only driver necessary is the Windows IEEE1394 driver (either Legacy or modern).
Any suggestions?
I have put a spiel on this subject on my website here:
https://www.aaproductions.net/dvtransfer.htm
Unfortunately the Tunghey card I have is currently not available, but any of the other cheap VIA cards "should" work.
I would suggest not using OBS. DV is not "captured" (well, it shouldn't be), it is "transferred". For SD, use WinDV (if it works) or Scenalyzer. For HDV (eg 1440x1080i) use HDVSplit.
I just tried OBS and although it sees the "Microsoft VCR" ie the camcorder, I couldn't get a picture. I may be doing something wrong there but...
Once transferred, you can then convert them to MP4 as you desire.Last edited by Alwyn; 3rd Jun 2024 at 07:02.
So Firewire 400 is fine for HDV then?
https://www.amazon.ca/gp/product/B07N2WQZTS/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
So I purchased this card. Hopefully its the right one to use. -
Originally Posted by Alwyn;2733319For SD, use [url=https://www.videohelp.com/software/WinDV
And also DVDate to extract dates (subtitles) to srt. -
I occasionally use CaptureFlux for analog tapes, for me it works better than vdub, Haven't tried it for digital tapes.
Thank you so much for this! I have been tearing my hair out trying to get a TI-based Startech card to work under Windows 10 to absolutely no avail, until I booted into Ubuntu and found that all the exact same issues existed under Linux!
I've now ordered a cheap, unbranded VIA-based card from eBay. -
Be sure to let us know how it goes. Be good to know one way or the other.
Absolutely, will definitely report back next week after the VIA-based card has arrived.
Just for interest, I did manage to get one device to work with the Startech card - a Canopus ADVC-55. That device would *only* work if it was receiving a valid video input before being connected to the Firewire port. If I connected it to the computer in the absence of a valid video input, it just wouldn't work at all. That trick didn't work with an ADVC-100, or any of several different makes of DV and Digital8 camcorders I tried, none of which I could get to function at all (they showed up in Device Manager, but no software was able to capture video from them, either freezing up or giving an error). -
i use virtualdub and go fine so far. for what i see. get something like 20gb for hour and half.
my question firewire on a motherboard it be ok? i use that way -
Nope, the VIA card doesn't work either. Symptoms exactly the same as I was seeing with the TI card, except it's even worse because I can't even get the ADVC-55 to work with the VIA card.
I notice both cards use the same "asmedia" PCI-PCIe bridge chip - I'm wondering if that could be the problem?
I've found another card on eBay that seems to have a VIA chip on it, but I can't see the "asmedia" bridge chip on the board in the pictures, although they only show one side of the board so it's possible the bridge chip is on the other side of the board. The VIA chip also looks to be a smaller package than the one on the other card. I've ordered one of those, more in hope than expectation that it'll workLast edited by Drainpipe; 10th Jun 2024 at 07:28. Reason: Added more info.
Oh that's a bummer. Did you try the other driver? Either VIA 1394 OHCI or the "Legacy"?
My Tunghey card is out of stock here but the one Braxus bought in post #6 is available, and it looks identical to mine:
I have noticed the layout of some 1394 cards is quite different. Could you post the link to your card? -
Those cards look identical to the VIA-based one I cannot get to work, with the asmedia bridge chip.
Here's a link to the one I have just ordered that looks a little different, without the asmedia bridge chip:
https://www.ebay.co.uk/itm/166394036869 -
Fingers crossed! Here's another lead (which came in after you had bought that dud one):
https://forum.videohelp.com/threads/413744-What-is-the-modern-solution-for-backing-up-...es#post2727305 -
Have several of these that work well
https://www.amazon.com/gp/product/B07Q2G79QG/ -
Originally Posted by Nicholaserra
Unbelievably, this card has arrived snapped in half!
Doesn't work for me, sadly.
I got a refund for the eBay one that turned up broken, and ordered one of these LinksTek ones from Amazon US, and it doesn't work.
Exactly the same effect - devices show up in Device Manager instantly, but nothing is able to capture video from them. The exception is the Canopus ADVC-55, which will work if, and only if, it is receiving a valid video input as the Firewire cable is connected to the computer. I get exactly the same behaviour in Windows 10 and Linux booted from a USB drive, so the issue does not appear to be software related.
I've now tried three different PCIe Firewire cards, and none of them work, all showing exactly the same problems:
- A StarTech branded card with TI chip and "asmedia" bridge chip.
- An unbranded card that looks similar to the StarTech card but with VIA chip and "asmedia" bridge chip
- A much smaller card with VIA chip and no bridge chip
I can only conclude that the issue lies with the motherboard, but I don't have any other PCs with PCIe slots.
few posts about camcorders
By realspeed in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 25th Oct 2022, 03:16 -
AverMedia CE310B PCIe card - how do I get it to stop (badly)de-interlacing?
By bergqvistjl in forum Capturing and VCRReplies: 3Last Post: 30th Mar 2022, 22:17 -
Windows 10: What capture card works?
By Clogdance in forum Capturing and VCRReplies: 10Last Post: 12th Nov 2020, 08:50 -
PCIe 3 × 4 card type
By Schraga Mor in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 1st Oct 2020, 10:52 -
Capturing video with Avermedia CE3310B PCIe
By Schraga Mor in forum Newbie / General discussionsReplies: 3Last Post: 5th Sep 2020, 10:32
