I have a .webm file that has VP9 video and OPUS audio. The resolution is 640x480 and the display aspect ratio is 4:3. However it is clear that the video should be displayed with a 16:9 aspect ratio as everything looks too thin. In VLC I can select to play it at 16:9 and it looks fine. I do not have access to the original source video so I can't go back and encode it properly. Is there any way to change the display aspect ratio to be 16:9 without encoding the video again? Thank you.
I had been having problems with a couple of other tools I had tried, but I used MKVToolNix and fixed the problem in seconds.
The video has to be re-encoded to 16:9 if you want all players to play it normally,it may play fine by some players but if you play it on your tv it will play at 4:3.
Might be that the file was 16:9 but flagged as 4:3.Have you tried playing the file on the tv's video player?
change Incorrect Aspect Ratio 4:3 to 16:9
By TubeBar in forum Video ConversionReplies: 8Last Post: 6th Jul 2023, 12:06 -
Change aspect ratio with MKVMerge from command line?
By Rekrul in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2021, 14:54 -
Files that won't display their correct aspect ratio on blu-ray player
By Nico Darko in forum Video ConversionReplies: 12Last Post: 6th Feb 2021, 14:22 -
Wrong display aspect ratio in portrait video
By chrisp in forum Newbie / General discussionsReplies: 9Last Post: 2nd Jan 2021, 09:46 -
Improper Display Aspect Ratio?
By GrouseHiker in forum Capturing and VCRReplies: 8Last Post: 27th Apr 2020, 18:55
