I have recently install Zorin17 Core.1 to my Lenovo Think-Centre machine. I installed Firefox and DuckDuckGo for VPN tracking protection, not that these were any source of a problem. Knowing that in needed to I downloaded G-Streamer, and the Ubuntu Restricted Codecs set. and of course the DW-Helper extension, and its companion app thinking I would be able to capture videos off the web, no such luck.
When I downloaded, trying the download anywhere, to a folder, save and convert, pretty near all valid options to get playable files for VLC or Gnome-Videos. That was a total failure for me. I kept getting an error message.
'File could not be loaded, no file found. Could not create a GL context.'
But, looking with Files at the folders, there was data often in the hundreds of Mb range. Head-scratcher extraordinaire!
I did see in another forum that the 'G-Streamer Bad Plug-in' codec set would do the job, and it did!
However, a direct attempt using SUDO and 'snap' failed miserably, missing dependencies.
My rescue came in the form of a CODEC Manager in the Gnome APPS Software Installer GUI.
G-Streamer 'BAD' is installed and DW-Helper now works just fine.
Jepethiel, Australia
Results 1 to 1 of 1
CCextractor Context Menu Option?
By Themus in forum SubtitleReplies: 8Last Post: 29th Dec 2024, 00:21 -
What is the so-called 'working CDM' in the context of widevine DRM?
By adidaz in forum Video Streaming DownloadingReplies: 14Last Post: 15th Mar 2022, 05:05 -
Can we add convert sub to srt in context menu?
By mastercho in forum SubtitleReplies: 1Last Post: 11th Apr 2021, 22:42 -
Recording Desktop: Multiple Windows and Context Menus
By scarecroe in forum Video Streaming DownloadingReplies: 7Last Post: 12th Feb 2020, 08:20 -
avidemux Win 10 context menu
By ro2124 in forum Newbie / General discussionsReplies: 0Last Post: 30th May 2019, 01:56
