Good evening,
I have another address from joyn.de with a link for live TV:
https://www.joyn.de/play/live-tv?channel_id=3
How can I record this with yt-dlp? 1 video maybe limited to 2:30 hours.
Thank you,
Heiko
You can do it with N_m3u8DL-RE (you might want/need to change the mpd url to your own though):
Code:N_m3u8DL-RE --live-pipe-mux --live-record-limit 02:30:00 --key 4be97d7f735af6a3451aca364b82a0ca:81fe64b5b28f270f0732a08e475ab003 --key 2fc02c1778f25476a35a7094175bcc91:63aabb4fe85c860c34890f14cebced8c --key ea9f78bdc5a759bbb5909dd2ffd3aa79:cdb58d31f281f08f7231382b5c993acc --key eeb352ba819055c78f132a638bd4c55b:c0dae5b99654ad93779ca040b2742caa https://e69c23808b454f1c9495140defe11e6d.mediatailor.eu-central-1.amazonaws.com/v1/dash/dc68902b999c03581090fd7c53714ca701972248/joyn_akamai_dash/3612abce/t_001/kabeleins-de-sd/cenc-default.mpd
heiko@Worf:~/Tele5$ N_m3u8DL-RE --live-pipe-mux --live-record-limit 00:03:00 --key 4be97d7f735af6a3451aca364b82a0ca:81fe64b5b28f270f0 732a08e475ab003 --key 2fc02c1778f25476a35a7094175bcc91:63aabb4fe85c860c3 4890f14cebced8c --key ea9f78bdc5a759bbb5909dd2ffd3aa79:cdb58d31f281f08f7 231382b5c993acc --key eeb352ba819055c78f132a638bd4c55b:c0dae5b99654ad937 79ca040b2742caa https://e69c23808b454f1c9495140defe11e6d.mediatailor.eu-central-1.amazonaws.com/v1/das...nc-default.mpd
Unrecognized command or argument 'https://e69c23808b454f1c9495140defe11e6d.mediatailor.eu-central-1.amazonaws.com/v1/dash/dc68902b999c03581090fd7c53714ca701972248/joyn_akamai_dash/3612abce/t_001/kabeleins-de-sd/cenc-default.mpd'. -
Good evening.
I can't find the correct mpd.
Thanks,
Heiko
[Attachment 78478 - Click to enlarge] -
no problem here the same info provided by white_snake
[Attachment 78480 - Click to enlarge] -
Try to enclose the url inside quotes, or maybe move the mpd url to an earlier position in the command.
Try to use The Stream Detector browser extension if you can't find it in the Network tab.
Thanks for confirming.
Livestreaming/Download
By Data2006 in forum Video Streaming DownloadingReplies: 31Last Post: 4th Dec 2022, 17:10 -
Any idea how to record this livestreaming format?
By Alan2154 in forum Video Streaming DownloadingReplies: 3Last Post: 13th May 2022, 05:24 -
How to record m3u from Vimeo livestreaming without interruption?
By Alan2154 in forum Video Streaming DownloadingReplies: 1Last Post: 18th Sep 2021, 20:47
