hello
is there any kind of software from which we can creat a vcd & which definately plays in the dvd players which support cdr, cdrw
.....................................if not ............................
why dosent it play what is the main reason
what do u need to make it play in the dvd players
i use nero 5 to creat vcds out of avi's
I would not use Nero to encode if I were you.
Use TMPGEnc to encode using PAL or NTSC VCD template and you ll get a video that can easily burnt to VCD using Nero. Nero's own encoder is flaky at best.
Cheers
Longevity of Standard DVDs and BluRay DVDs
By bmccollum in forum MediaReplies: 10Last Post: 20th Oct 2010, 18:32 -
2.0 to 5.1 for dvds?
By blacksheepdownunder in forum AudioReplies: 6Last Post: 30th Dec 2009, 10:33 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 16:03 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 01:02 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 09:02
