I've been using ssyoutube (free) to download youtube video and it's worked fine but lately having trouble with it. Are there any free converters that I can try or do I have to purchase a converter? Which converter do you recommend?
	as 2nHxWW6GkN1l916N3ayz8HQoi suggested
 yt-dlp is a powerful tool for downloading content, especially from YouTube. However, I often found myself forgetting the code line for using it. To fix this issue , I've created a batch script to simplify the process.
 This simple batch script helped me download YouTube content in the highest possible quality using yt-dlp and ffmpeg, and I'm pleased to share it with everyone.
 Tools Used (in the same folder):
 1. yt-dlp (download yt-dlp.exe from https://github.com/yt-dlp/yt-dlp/releases)
 2. ffmpeg : for muxing.
 3. Batch Script:
 How to Use the Batch Script:Code:@echo off setlocal enabledelayedexpansion set /p link="YouTube download Link: " echo 1. mp3 echo 2. video set /p choice="choose your download type (1 or 2): " if !choice!==1 ( yt-dlp -x --audio-format mp3 -o "downloads\%%(uploader)s\%%(title)s.%%(ext)s" !link! echo Download completed ) else if !choice!==2 ( yt-dlp -F !link! set /p format_code="Enter the format code: " yt-dlp -f !format_code! -o "downloads\%%(uploader)s\%%(title)s.%%(ext)s" !link! echo Download completed ) start "" "downloads" echo Press Enter to Exit... pause >nul endlocal
 1. Install the Batch:
 - Copy the above code into a new text file.
 - Save the file with the extension ".bat", for example, "download_youtube.bat".
 2. Run the Batch:
 - Run the batch by double-clicking on it or using the command "start download_youtube.bat" in the command prompt.
 3. Select Download Type:
 - Upon running, you'll be prompted to enter the YouTube video link you want to download.
 - Choose the desired download type: mp3 or video. (If you choose mp3, the best available audio quality will be downloaded.)
 - for video, you need to enter the video and audio format ID for example: 299+140 "see the following image".
 format ID
 audio
 video
 [Attachment 78489 - Click to enlarge]
 5. Check the Files:
 - After the download is complete, the "downloads" folder will open, containing the downloaded files within the batch script folder.
 done...
	Anonymous84Guest-- Last edited by Anonymous84; 8th May 2024 at 18:48. Reason: Deleted as no point in helping egoistic person who can't even thank you
  VideoProc Converter converting AVI TO MP4By red bar in forum Video ConversionReplies: 4Last Post: 9th Nov 2023, 09:18
  Youtube Transcript to SRT ConverterBy Hikmet in forum ProgrammingReplies: 5Last Post: 30th May 2022, 05:03
  Conversion to MP4 Fails with Any Video ConverterBy sancarloscylist in forum Video ConversionReplies: 9Last Post: 19th Jan 2021, 20:33
  Best free mp4 to hevc converterBy idreos in forum Video ConversionReplies: 2Last Post: 17th Sep 2020, 02:42
  Want LoiLoFit or good MTS file converterBy David Mullins in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 6th Aug 2020, 02:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
