Results 1 to 12 of 12
    Jul 2004
    Chicago
    I am not sure if this is the place for this question but here goes:
    I still print on CD's using my Epson Printer. Years and years ago I had a piece of software that contained 100's of templates for CD's. Everything from sunsets, animals, cars, people, and gradients just to name a few. I can't remember the name of the program or where I got it from.
    I am using Epson Print CD software and trying to import a picture onto the CD. I will not accept any version of the picture. Not .jpg, .gif, Tiff, none of them. I keep getting an error "Not a Print CD format."
    Can anybody that still printed on CD's help with my two questions or tell me what they use to do it with?
    Thanks in advance.....
    Oct 2005
    666th portal
    i used surething cd labeler or photoshop. have always had canon cd/dvd printers can't help with epsons.
    Aug 2003
    You can try Avery Design and Print. I use it and it is free. I downloaded and installed the software. I think you can use it online also.
    IIRC use can use Mcrosoft Word.
    Oct 2018
    Town Spa Pizza, United States
    Surething.
    Jul 2008
    Old Dominion
    I still print on CD/DVD/Blu-Ray disks with my Epson XP-8500. The software is available for download.
    https://ftp.epson.com/drivers/EPCD_2.44.exe
    Jul 2004
    Chicago
    Thanks for all the responses.
    Jul 2004
    Chicago
    Can Surething print directly onto the CD or DVD? Is there any tutorials out there that show how to do it?
    I downloaded the free trial and it seems like it prints on cd labels that stick onto the cd. I may be wrong but I can see how to change it.
    Thaks in advance/......
    Oct 2018
    If you have a disc printer like my Epson 7100 yes, direct on disc.
    Jul 2004
    Chicago
    Yes, I can print directly yo my 7100 printer but can I do it using the Surething software?
  10. Member steptoe's Avatar
    I print directly onto white faced printables using a Canon CD printer
    Assuming Epsom is the same, you need to choose "direct to tray" when printing and make sure you also set "CD/DVD Printer" under printing options in Surething and NOT "standard Printer" or it will print a CD label
    Its years since I used an Epson CD printer as ink was just so damn expensive and they were designing cartridges that were harder and harder to refill plus chipped cartridges I changed to Canon
    Jul 2004
    Chicago
    Thanks a bunch. I'll give it a try and see what happens.
    Apr 2012
    Hungary
    The one I am using to print my own productions is: https://www.ronyasoft.com/products/cd-dvd-label-maker/download.html
    It has many great features, you can precisely set dimensions of labels for various types of disc surfaces, with exact measurements, design booklets. Every essential data of dimensions are programmed in it. It makes things so easy.
