The video file that I’ve imported defaults to French. This is easy enough to change in a video player, but how do I change the language in OpenShot?
"ctrl+shift+p" should open the preferences (Edit→Preferences) and there under general, see: https://www.openshot.org/static/files/user-guide/preferences.html
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Sorry, never really cared about it much, I just used a different tool to remux the file before feeding opening it with Openshot.
I suspect that others can recommend some NLE which supports inputs with multiple audio streams.users currently on my ignore list: deadrats, Stears555, marcorocchini
How to tell yt-dlp to change language of an MPD? [SOLVED 😱]
By BlueVideo10 in forum Video Streaming DownloadingReplies: 4Last Post: 11th Oct 2023, 17:42 -
RCA VCR - change language without remote?
By TrackingError in forum Newbie / General discussionsReplies: 7Last Post: 2nd Feb 2022, 11:15 -
How to change language disignation of srt file
By movienut50 in forum SubtitleReplies: 2Last Post: 21st Dec 2021, 10:32 -
How to change default of a soundtrack/language with PotPlayer
By pintree3 in forum Software PlayingReplies: 2Last Post: 23rd Feb 2020, 07:02 -
how to change language video and audio in batch with mkvtoolnix in cmd
By pawelaut in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2020, 14:20
