Im using amd rx6700
on handbrake it uses VCN for encoding but does not utilize for decoding so its pretty slow
format factory is pretty much the same.
I have no issue with nvidia cuda/nvenc tho.
Im looking for a transcoder that can use amd gpu properly for both decoding and encoding process.
I mostly use it for resizing the video.
capcut utilize my system well, but it mostly do 1 video at a time - so its pretty slow as well
iDelashare VideoGo can convert between various video formats, audio formats, convert video to audio format.
It has the decoding and encoding function.
It also has the basic editing feature like trim, merge, compress, adjust video resolution, aspect ratio, video codec, audio codec, audio channel, audio bitrates etc. -
see this thread - https://forum.videohelp.com/threads/388140-Best-H265-gpu-accelerated-video-conversion-software
post #2 try using staxrip
Alternative for VOBMerge available?
By DReffects in forum Authoring (DVD)Replies: 0Last Post: 27th Sep 2022, 08:06 -
MakeMKV alternative?
By Instant Martian in forum DVD RippingReplies: 10Last Post: 26th Aug 2022, 10:05 -
Alternative for Virtualdub
By PB_71 in forum EditingReplies: 15Last Post: 6th Sep 2021, 10:43 -
convertx2dvd alternative
By phoenix1971 in forum Authoring (DVD)Replies: 2Last Post: 2nd May 2020, 04:15 -
Any Spinrite alternative?
By lingyi in forum Newbie / General discussionsReplies: 13Last Post: 27th Sep 2019, 07:26
