Hello!
Recently, I have buy 2 Formula one Motor racing VHS. I try to capture it by Virtualdup and get the following result:
I capture at 384 X 288 using DivX 3.11 alpha and MPEG Layer 3 to compress video and audio.
For tape 1, I can capture at 25 fps without framerate drop while for tape 2, the framerate drop a lot to around 15fps!!!
Then, I try to capture at 320 X 240 for tape 2 and no framerate drop at all!!! So strange!!!
Why different tape can cause different result in capturing with same setting? So confusing! Anyone know the reason?
Thanks a lot!
Results 1 to 1 of 1
Capturing From VHS Via VirtualDub Produce Strange Result
By max20d in forum Capturing and VCRReplies: 0Last Post: 8th Oct 2010, 22:55 -
Digital8- capture and compress in real time OR shrink result to MKV
By auilani in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 26th Sep 2010, 18:54 -
VHS strange horizontal lines
By rekotc in forum Capturing and VCRReplies: 15Last Post: 21st Jun 2010, 15:24 -
Very strange VHS to PC capture problem
By fredhoward in forum Capturing and VCRReplies: 45Last Post: 9th Feb 2010, 08:30 -
mpeg2enc and subtitles: strange result.
By Levina in forum ffmpegX general discussionReplies: 5Last Post: 27th Mar 2008, 16:08
