Hi, Im looking for a userfriendly GUI frontend for yt-dlp. I want to downlod youtube videos or audio.
Any recommendations?
Thank you![]()
Results 1 to 12 of 12
Why do you want to use a frontend for yt-dlp ? it simple as yt-dp URL and if you want more option tou just have to read the doc : https://github.com/yt-dlp/yt-dlp/?tab=readme-ov-file#usage-and-options
^^ Unless thing have changed, TVDownloader does not natively support yt-dlp.
Having said that, it can support it by renaming the yt-dl program in the TVdownloader folder by inserting yt-dlp in to that and renaming that.
For a native yt-dlp gui one can use yt-dlp-gui. Even then you might require to put the latest version of yt-dlp in to the yt-dlp-gui folder -
yt-dlp-gui looks pretty nice, but I don't know why it doesn't save the settings on exit. And why it makes such a mess, there are 3/4 files and a folder when downloading, I want just 1 file, the video ^^
AnonymousGuest
Last edited by Anonymous84; 8th May 2024 at 18:48. Reason: Deleted as no point in helping egoistic person who can't even thank you
I've been using this one for a while now. Seems to work pretty well.
https://github.com/ErrorFlynn/ytdlp-interface -
Not sure about this.
I got the portable version straight from the software section on this site.
https://www.videohelp.com/software/yt-dlp-gui
Just one file. And settings in the version I use are saved apart from video quality.
clever FFmpeg-GUI, small FFmpeg UI, fully portable, no installation.
By ProWo in forum Video ConversionReplies: 3346Last Post: 7th Jan 2026, 12:40 -
Recommendation for Chapter Editor with GUI?
By NukeyDoo in forum EditingReplies: 2Last Post: 5th Mar 2024, 12:39 -
yt-dlp with MultiWAN
By doctorm in forum Video Streaming DownloadingReplies: 7Last Post: 19th May 2023, 18:59 -
Help with yt-dlp
By Loryanam2 in forum Video Streaming DownloadingReplies: 1Last Post: 5th Jan 2022, 12:57 -
Problems with FLAC Frontend
By carlmart in forum AudioReplies: 14Last Post: 22nd Dec 2021, 08:57
