  1. Continuing on from A_N_G_E_L_A's post on Installing on android phone under Termux
    Once you have Ubuntu Linux installed
    Proot-Distro Login Ubuntu
    Installing Devine this will also work on a non rooted device I also have this on my Samsung Tablet
    The only thing you will need to have is a wvd created on another device or the same if it was previously rooted.
    If you have already installed Freevine or A_N_G_E_L_A's UK-FTA you could skip some of these steps
    as you will already have most of the binary files already installed and python.
    Python3
    apt install python3 python3-pip python3-setuptools
    #Upgrade - New Way = Secure
    python3 -m pip install --upgrade pip
    python3 -V
    pip3 -V
    #Dependencies
    #FFmpeg MKVToolNix aria2
    apt install -y ffmpeg mkvtoolnix mkvtoolnix-gui aria2
    #Shaka-packager
    curl -L https://github.com/shaka-project/shaka-packager/releases/download/v3.0.4/packager-linux-x64 -o /usr/local/bin/shaka-packager
    chmod a+rx /usr/local/bin/shaka-packager
    ffmpeg -version
    mkvmerge -V
    aria2c --version
    shaka-packager --version
    This next section did now work for me maybe my linux skills are not up to it but i got ccextractor from PSSH
    I had to also do this after copying the ccextractor from /sdcard/download to /usr/local/bin/
    apt-get install -y libmediainfo-dev
    #ccextractor
    https://packages.debian.org/sid/ccextractor
    https://github.com/CCExtractor/ccextractor/blob/master/docs/COMPILATION.MD
    apt install -y libglew-dev libglfw3-dev cmake gcc libcurl4-gnutls-dev tesseract-ocr libtesseract-dev libleptonica-dev clang libclang-dev autoconf
    ##Standard linux compilation through Autoconf scripts
    git clone https://github.com/CCExtractor/ccextractor.git
    cd ccextractor/linux
    ./autogen.sh
    ./configure --without-rust
    make -j$(nproc)
    ./ccextractor --version
    make install
    ##Using the build script
    ./build -without-rust
    #Install "Devine"
    cd ~
    mkdir devine
    cd devine
    cd ~/devine
    python3 -m venv .venv worth noting that .venv iis hidden folder once created
    source .venv/bin/activate
    pip3 install devine
    devine --version
    devine --help
    copy your wvd file to /sdcard/download then
    cd devine
    mv /sdcard/download/Adroid14L3.wvd .
    then do the following
    devine wvd --help
    devine wvd add *.wvd
    devine wvd parse xxxxxxxx_l3.wvd
    it moves the created wvd into the right directory for you
    #Upgrade "Devine"
    cd ~/devine
    pip install devine --upgrade
    #If you want to exit the ".VENV"
    deactivate
    Next this is the devine env info on the phone
    You may need to create .config in root/
    [Root Config] : /root/.config/devine/devine.yaml
    [Cookies] : /root/.local/share/devine/Cookies
    [WVDs] : /root/.local/share/devine/WVDs
    [Cache] : /root/.cache/devine
    [Logs] : /root/.cache/devine/log
    [Temp Files] : /tmp/devine
    [Downloads] : /storage/emulated/0/Movies
    I edited the devine.yaml in notepad ++ and copied it into the directory from /sdcard/download
    My devine.yaml looks like this.
    tag: NGP
    directories:
    downloads: /storage/emulated/0/Movies
    services: /root/devine/services
    cdm:
    default: androidl3
    credentials:
    ALL4: me@Outlook.comassword
    DSNP: me@Outlook.comassword
    AMZN: me@Outlook.comassword
    CTV: me@Outlook.comassword
    services:
    iP:
    cert: /root/devine/certs/bbciplayer.pem
    sub_format: srt
    [Attachment 78375 - Click to enlarge]
    Feb 2022
    Search the forum first!
    You tried a direct install?
    Termux (NOT from within a proot-distro) will install ccextractor without problem.
    pkg install ccextractor
    Noob Starter Pack. Just download any Widevine media! Over 30,000 downloads for V6!.
  3. Thanks for that I’ll try that on the next one
  4. I am stuck here. Please help.
    Python3
    python3 -V
    pip3 -V
    #Dependencies
    #Shaka-packager
    ffmpeg -version
    mkvmerge -V
    aria2c --version
    #ccextractor
    ./autogen.sh
    make -j$(nproc)
    make install
    #Install "Devine"
    cd ~
    mkdir devine
    cd devine
    cd ~/devine
    pip3 install devine
    devine --version
    devine --help
    cd devine
    devine wvd --help
    #Upgrade "Devine"
    cd ~/devine
    deactivate
    tag: NGP
    directories:
    cdm:
    default: androidl3
    credentials:
    services:
    iP:
    sub_format: srt
  5. Hello. Can someone tell me the commands to go about it starting from this point:
    "You may need to create .config in root/
    I edited the devine.yaml in notepad ++ and copied it into the directory from /sdcard/download"
    I AM STUCK AS TO HOW TO MOVE THE CONFIG FILE TO ROOT AS I DONT HAVE A ROOTED PHONE
    [Attachment 83298 - Click to enlarge]
