I have been looking for some time for a way to distinguish and mark thousands of images that have text from images that don't.
The object is to delete all the images that don't have text and keep only those that have.
Doing it manually takes a very long time and wears out my fingers from using a mouse and keyboard.
These days when you hear about AI all the time, I am just wondering if there is an automatic method to do this job accurately and fast.
Thanks for any suggestions weather it is AI related or an existing application that I have missed.
AI might do that someday. But for now I suspect you have to do it manually.
Extraordinary claims require extraordinary evidence -Carl Sagan -
You might be able to do something with one of these projects.
https://www.geeksforgeeks.org/python-ocr-on-all-the-images-present-in-a-folder-simultaneously/
https://github.com/Aneapiy/OCR-Image-Sort
Even if you don't need the text extracted you can use that info to select the images. -
Is there anything consistent about the text? Is it always in the same location on the frame? Always the same color or brightness? For example, a video might have bright yellow subtitles that appear near the bottom of the screen. One can detect which frames have subtitles by looking for bright yellow in that area. You're not detecting text per se, but bright yellow stuff. You'll sometimes get a false positive (some other yellow object is there) but you can at least pre-screen the bulk of the images.
How to distinguish correct license urls
By ghostexaid_1516 in forum Video Streaming DownloadingReplies: 2Last Post: 23rd Sep 2023, 08:42 -
Rename multiple images within folders using text files
By D.LUFFY in forum ProgrammingReplies: 2Last Post: 23rd May 2023, 22:06 -
Batch method to find images that contains only text !
By zyck in forum SubtitleReplies: 7Last Post: 19th Oct 2021, 21:52 -
overlay some text with a black background/white text over one small section
By devdev in forum EditingReplies: 0Last Post: 16th Dec 2020, 12:27 -
How do we remove video parts shown as text images
By jraju in forum Newbie / General discussionsReplies: 6Last Post: 27th Jun 2020, 22:20
