Does anyone have the old crackle links for movies, i.e.
http://media-us-am.crackle.com/1/c/4m/c9fyb_480p_1mbps.mp4
I believe I have figured out a way to get the widevine keys for the older movies (in 720p or 1080p) which no longer appear on the website, but the links are still active, so I am wondering if someone has links like the one above they would be willing to share? Thanks
Any movie(s) or tv series, especially if you have the old links for Seinfeld or Firefly
Not tried myself, but the first thing that comes to mind is https://web.archive.org - if you are lucky...
I have a bunch of older IDs mapped to movie names, particularly for previously available TV shows and including Seinfeld, but those are mostly useful for uplynk playlists that no longer work. IDs are not what you initially asked for, but I also used Internet Archive in the past to gather Seinfeld IDs. At the time I didn't see any way to generate modern WV-protected links from that, just uplynk, so I'm not sure if mere IDs are useful for whatever method you have...?
Are you still able to get those high-bitrate m3u8 streams even for SD shows? Desperately looking to grab at least one show that way that I had neglected. -
Unfortunately, the urls are not working (the domain worked until mid-July). For example, from the corresponding image file 'https://images-us-am.crackle.com/1/9/ul/5r7wb_tnl_480x270.jpg?ts=20230623085529', I derived the correct mpd: https://widevinedashus-crackle-com.akamaized.net/1/9/ul/5r7wb_Widevine_Dash_playlist.mpd and found the keys for the video. It was playing perfectly before, but widevinedashus-crackle-com.akamaized.net is not a valid URL anymore.
The working URLS are in this format: https://prod-vod-cdn1.crackle.com/v1/dash/ab95b45b71c711ddf59f86e4e6bea571f56e1289/v2m...d3e5/index.mpd
But I do not know how to tie the older media ID from uplynk to the new URL format
How to download videos from Crackle?
By McFly2077 in forum Video Streaming DownloadingReplies: 21Last Post: 10th Apr 2024, 01:30 -
Crackle m3u8 Error 400
By fraudiay79 in forum Video Streaming DownloadingReplies: 8Last Post: 15th Jan 2024, 11:54 -
A request for help with a key request please...
By LastResort in forum Video Streaming DownloadingReplies: 7Last Post: 12th Jul 2023, 03:07 -
Crackle download missing audio
By sixpence668 in forum Video Streaming DownloadingReplies: 2Last Post: 2nd Oct 2022, 10:05 -
[francetelevisions.fr] Can play/record M3U8 links, but not "HLS_V5" links
By abolibibelot in forum Video Streaming DownloadingReplies: 5Last Post: 17th Jul 2020, 16:14
