  1. Can Shutter Encoder and ffmpeg resize images and videos without losing quality?
  2. Any re-encode loses quality. But Shutter encoder is a great front end for ffmpeg and gives you access to all its capabilities. If you're encoding to H.264 or H.265 you can use a low CQ value to make the re-encode almost invisible.
  3. Originally Posted by smrpix View Post
    But I'm not reencoding, I'm resizing. Or is that also reencoding?
  4. In Shutter and ffmpeg you cannot change the frame size without re-encoding. (You can change the display aspect ratio but the actual pixel count remains the same.)
    If you want to change the frame size without re-encoding, the best way is probably to use the zoom function in your video player during playback.
  5. Originally Posted by Sound Master View Post
    Resizing can't be done without first decompressing the source. Then I assume you want to compress the resized video or it will be very large. So you lose quality from resizing and then lose more quality by re-compressing.
