Okay, I've added CBC to the repository.
After some testing, I found that the only reliable way for CCExtractor not to fail was to remove its code. I added a note about where to do it in the help text:
This service was way more trouble than it's worth, so I'm just going to wash my hands of its crap and move onCode:devine dl CBC -?
Thankfully, yt-dlp seems to be a good backup in this case if this one doesn't work for you.
Results 931 to 960 of 1872
cbc use CCExtractor for subtitle.srt. make sure clean your temp folder before dl cbc
merge all video, audio and subtitles with mkvtooknixCode:ccextractor.exe -1 -out=srt -bom -latin1 "C:\Users\PATH\devine\temp\Video_1fc35ec8.mp4"
If you're referring to "Robustness", it's how robust each system is for each level and quality. For example, when you try to license keys using an unsupported security level (like using L3 when L1 is required), you might get "robustness failure" as a response.
If you mean "AES-128", it's an encryption method that is less invasive than DRM and no CDMs are needed to decrypt it. The key is often found in the manifest itself. -
A short update on CBC: It doesn't actually seem to be an issue with either CCExtractor or the N_m3u8DL-RE branch. The problem is seemingly with my Windows setup where the paths get crossed somehow. Running it on my linux setup everything works fine.
Totally my bad, and just thought I'd mention it.
Edit: Scratch that. Turns out the real issue is with CCExtractor v.0.94. If you're on windows, you need to downgrade to v0.93. Most Linux package managers only go up to v.0.93 by default, that's why it's working on there.
This turned out to be a real roller coaster for such a small service
Can anyone help me I have never used this program and I have spent hours trying to figure this out and I have no clue what I am doing wrong, but I keep getting this error...
Failed to load Widevine CDM, my.wvd does not exist or is not a file
But I put it in the path it said it wanted and the file very much does exist, so I have no idea what the issue is? -
Hi,
Try entering the following commands :
devine wvd add c:\rclone\ANDROID_4464_l3.wvd
devine cfg cdm.default ANDROID_4464_l3
You need to put the full path of where you have your wvd file (so replace c:\rclone\ANDROID_4464_l3.wvd with your own).
For the cdm.default you put the name of your wvd file without the .wvd extension.
Hope this helps. -
@stabbedbybrick do you have an example show for CBC that uses Widevine ? All the ones I've tried so far have been AES-128.
One of the few I found: https://gem.cbc.ca/reservation-dogs
@stabbedbybrick is there a way with the CBC downloader to select just a specific episode of a show and also how can you pick 5.1 it is defaulting to 2ch for me? I use to have the same issue in freevine, but there I could do --select-audio name=EC-3 and it would then get the 5.1 audio.
Unfortunately, CBC doesn't provide any bitrate info for audio so you have to select the track like @billybanana mentioned.
If you're new to Devine, I suggest reading the documentation:
Available commands and options:
Config options: https://github.com/devine-dl/devine/blob/master/CONFIG.mdCode:devine --help devine dl --help
Cookies/Credentials: https://github.com/devine-dl/devine?tab=readme-ov-file#cookies--credentials
And always check the help documentation for each service since I put general usage information in there:
Code:devine dl CBC --help
No idea. Considering mkvmerge often complains about invalid data in the audio track when muxing, I'm guessing it's related to that. And I'm not sure if there's anything we can do about it from our side.
@stabbedbybrick has ITV changed an endpoint? Keep getting failed to request MPD document
Yeah can't get through using Nord, switched to WindScribe and it works, seems ITV has banned Nord IP addresses.
How do I completely remove the music and sound effects from a movie?
By cns00 in forum EditingReplies: 1Last Post: 15th Jan 2024, 12:11 -
Which software can remove music from show but keep character dialogue?
By Mohamed61020 in forum AudioReplies: 6Last Post: 2nd Jul 2023, 21:32 -
Software for simple music videos?
By dewiclements in forum Software PlayingReplies: 3Last Post: 26th Jul 2022, 01:21 -
H.264 for archival and editing - no go?
By malling in forum Capturing and VCRReplies: 8Last Post: 19th Aug 2019, 23:51 -
Movie music too loud but dialogue too quiet fix needed
By hokkom in forum AudioReplies: 121Last Post: 4th May 2019, 08:51
