Page 19 of 63
FirstFirst ... 9 17 18 19 20 21 29 ... LastLast
Results 541 to 570 of 1872
  1. devine.YAML - BUG relative/full path?
    Under Debian I have set manually "relative" PATHs to:
    directories:
       downloads: ~/Videos/
       services: ~/git/devine332TPDpy311poetry/devine/devine/services
    services:
       iP:
          cert: ~/wvd/bbciplayer.pem
    key_vaults:
     - type: SQLite
       path: ~/wvd/key_store.db
    And only the:
    does not work and throws and ERROR:
    OSError: Could not find the TLS certificate file, invalid path:
    If I enter the settings via "
    devine cfg services.iP.cert ~/wvd/bbciplayer.pem
    devine will fill in the "full path" in the settings and all works as it should.
    Is this a bug?
    If so, can somebody raise that on GitHub pls?
    Also I have made some progress in configuring from CLI
    that is easier as it accepts "relative paths" and fills in the "full path"
    But, if you do not have one created already "devine.YAML"
    then Devine will create one in the GLOBAL location
    and if you have more then one version of Devine
    then it can be confusing ....
    so I would manually create "key_vaults" and "remote_cdm":
    (as per the Install/Config guide)
    nano ~/git/devine-333-pip/.venv/lib/python3.11/site-packages/devine/devine.yaml
    or
    nano ~/git/devine332TPDpy311poetry/devine/devine.yaml
    #(indentation is "IMPORTANT")
    #key_vaults (list[dict])
    key_vaults:
     - type: SQLite
    #remote_cdm (list[dict])
    remote_cdm:
     - name: CDRM_Project_API
       device_type: ANDROID
       system_id: 4464
       security_level: 3
       host: https://cdrm-project.com/devine
       secret: CDRM-Project
       device_name: CDM
    And then finish the configuration from CLI with:
    devine cfg directories.services ~/git/devine332TPDpy311poetry/devine/devine/services
    devine cfg directories.downloads ~/Videos/
    devine cfg directories.wvds ~/wvd/
    devine cfg cdm.default CDRM_Project_API
    devine cfg dl.sub_format srt
    devine cfg dl.lang en
    devine cfg dl.downloads 4
    devine cfg dl.workers 16
    devine cfg aria2c.max_concurrent_downloads 2
    devine cfg aria2c.file_allocation prealloc
    devine cfg profiles.default default
    devine cfg credentials.ALL4 email:password
    devine cfg headers.Accept-Language "en-US,en;q=0.8"
    devine cfg headers.User-Agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/77.0.3865.75 Safari/537.36"
    #NordVPN
    devine cfg proxy_providers.nordvpn.username zxqsR7C5CyGwmGb6KSvk8qsZ
    devine cfg proxy_providers.nordvpn.password wXVHmht22hhRKUEQ32PQVjCZ
    #Check the SETTINGS
    devine env info
    devine cfg --list
    I have tried both the "key_vaults" and "remote_cdm"
    This command throws an error:
    Error: Got unexpected extra argument (SQLite)
    devine cfg key_vaults.- type SQLite
    And the below commands:
    devine cfg "key_vaults.- type" SQLite
    devine cfg 'key_vaults.- type' SQLite
    result in entry with quotes around it: '- type'
    #EDIT Friday, 12 July 2024
    - Corrected iPlayer entry .ip. to .iP.
    If I was in politics I make sure you drink plenty of beer
    and watch plenty of TV to keep you busy. | Data is the new oil.
  2. Originally Posted by iamghost View Post
    and also add devine.yaml
    profiles:
      default: default
    How did you work that out?
    https://github.com/devine-dl/devine?tab=readme-ov-file#usage
    Mentioned "Add Profiles" but the link does not work
    https://github.com/devine-dl/devine?tab=readme-ov-file#profiles-cookies--credentials
    Looking at Cookies & Credentials
    https://github.com/devine-dl/devine?tab=readme-ov-file#cookies--credentials
    only mentions profiles executed directly from CLI
    And the manual
    https://github.com/devine-dl/devine/blob/master/CONFIG.md
    does not have a "Profile" section.....unless I missed out something......
  3. Since I am having trouble getting CTV to work correctly, I decided to try and see if I could get Pluto to work. It downloads but it comes time to multiplex the files I get the following error. I do not know what file it cannot find. I have the aria2c .exe in the main devine folder (C:\Users\[Me]\AppData\Local\devine). I am not sure if it can "see" it there or if there is another home for it.
    Service Config loaded
         Loaded Cdm Widevine CDM: 22589 (L3)
         Loaded 0 Vaults
      ────────────────────────────── Service: PLUTO ──────────────────────────────
         Service has no Geofence
      ───────────────────────────── Series: Webster ──────────────────────────────
         1 Season, 4 Episodes
      ─────────────────── Webster S06E01 The Wild, Wild Webst ────────────────────
         1 Video
         └── [H.264, SDR] | en | 1280x720 @ 2442 kb/s, 30.000 FPS
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:21 • Downloaded
         1 Subtitle
         └── [VTT] | en
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:55 • Downloaded
         Track downloads finished in 1m1s
         Multiplexing... ⠋ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ •
    ╭───────────────────── Traceback (most recent call last) ──────────────────────╮
    │ in _run_module_as_main:198                                                   │
    │ in _run_code:88                                                              │
    │ in <module>:7        │
    │ C:\Users\Brian\AppData\Local\Programs\Python\Python312\Lib\site-packages\cli │
    │ ck\core.py:1157 in __call__                                                  │
    │ ck\core.py:1078 in main                                                      │
    │ ck\core.py:1688 in invoke                                                    │
    │ ck\core.py:1657 in _process_result                                           │
    │ ck\core.py:783 in invoke                                                     │
    │ C:\Users\Brian\AppData\Local\Programs\Python\Python312\Lib\site-packages\dev │
    │ ine\commands\dl.py:697 in result                                             │
    │   694 │   │   │   │   │   ):                                                 │
    │   695 │   │   │   │   │   │   for task_id, task_tracks in multiplex_tasks:   │
    │   696 │   │   │   │   │   │   │   progress.start_task(task_id)  # TODO: Need │
    │ ❱ 697 │   │   │   │   │   │   │   muxed_path, return_code = task_tracks.mux( │
    │   698 │   │   │   │   │   │   │   │   str(title),                            │
    │   699 │   │   │   │   │   │   │   │   progress=partial(progress.update, task │
    │   700 │   │   │   │   │   │   │   │   delete=False                           │
    │ ine\core\tracks\tracks.py:413 in mux                                         │
    │   410 │   │        │
    │   411 │   │   # let potential failures go to caller, caller should handle    │
    │   412 │   │   try:                                                           │
    │ ❱ 413 │   │   │   p = subprocess.Popen([                                     │
    │   414 │   │   │   │   *cl,                                                   │
    │   415 │   │   │   │   "--output", str(output_path),                          │
    │   416 │   │   │   │   "--gui-mode"                                           │
    │ C:\Users\Brian\AppData\Local\Programs\Python\Python312\Lib\subprocess.py:102 │
    │ 6 in __init__        │
    │   1023 │   │   │   │   │   self.stderr = io.TextIOWrapper(self.stderr,       │
    │   1024 │   │   │   │   │   │   │   encoding=encoding, errors=errors)         │
    │   1025 │   │   │                                                             │
    │ ❱ 1026 │   │   │   self._execute_child(args, executable, preexec_fn, close_f │
    │   1027 │   │   │   │   │   │   │   │   pass_fds, cwd, env,                   │
    │   1028 │   │   │   │   │   │   │   │   startupinfo, creationflags, shell,    │
    │   1029 │   │   │   │   │   │   │   │   p2cread, p2cwrite,                    │
    │ C:\Users\Brian\AppData\Local\Programs\Python\Python312\Lib\subprocess.py:153 │
    │ 8 in _execute_child                                                          │
    │   1535 │   │   │                                                             │
    │   1536 │   │   │   # Start the process                                       │
    │   1537 │   │   │   try:                                                      │
    │ ❱ 1538 │   │   │   │   hp, ht, pid, tid = _winapi.CreateProcess(executable,  │
    │   1539 │   │   │   │   │   │   │   │   │   │    # no special security        │
    │   1540 │   │   │   │   │   │   │   │   │   │    None, None,                  │
    │   1541 │   │   │   │   │   │   │   │   │   │    int(not close_fds),          │
    FileNotFoundError: [WinError 2] The system cannot find the file specified
  4. Hi Chaps,
    A quick question concerning tubi... specifically the version that is now available in the uk.
    Here's where i am confused,... on the p.c. i can watch anything i want without having to log in. (i do the same using a free vpn on a nvidia shield and i can stream from the u.s. version without having to log in.
    Is the tubi service built specifically for the u.s. version, or would it work for the u.k. version as well.
    I have tried only the once with C:\Devine>devine dl --list TUBI https://tubitv.com/movies/100021406/scum (and my error is "Service requires Cookies for Authentication.")
    I'm just a little confused as to why i can play it without having to log in.
    my chrome is uptodate and has "Open Cookies" addon installed if needed.
    thanks for any advice chaps. (p.s. please do not download this for me, I am not requesting this, I am just after advice, thank you).
    I took a chance and saved the cookies from the site above,......
    then tried the following :
    [Attachment 80533 - Click to enlarge]
    But was then met with the following: (the first time i have received this message) but this is the first time for tubi for me.
    [Attachment 80534 - Click to enlarge]
    I hope this helps with the advice because i think I am almost there.
  5. Originally Posted by LastResort View Post
    if you look at the service config for tubi, its geofenced for US and CA, but you should be able to add "GB" into the list and try it
    looks like a problem with ccextractor, did you try redownloading it?
    try running ccextractor.exe from the command line, it should print out the help information
  6. Originally Posted by eday_2010 View Post
         Loaded 0 Vaults
         1 Video
         1 Subtitle
         └── [VTT] | en
    ╭───────────────────── Traceback (most recent call last) ──────────────────────╮                                                              │
    │   410 │   │        │
    │   412 │   │   try:                                                           │
    aria2c doesnt do the muxing it does the downloading, which is successful.
    https://github.com/devine-dl/devine#dependencies
    do you have the dependencies ffmpeg and mkvtoolnix installed?
  7. Originally Posted by LastResort View Post
    Hi Chaps,
    I didn't know Tubi has been made available in GB, that's pretty cool. The code was written with US i mind, but it should work for any region as long as your IP matches. The reason it requires cookies is because last I checked, authorization was required to access everything needed. This might not be case for GB yet, but it probably will at some point so you might as well add it. Or maybe the apps work differently, I don't know.
    As for your error, ccextractor is used whenever there are no subtitles added/available to check track for closed captions. And in this case, there's something wrong with your installation of it.
  8. ccextractor isn't just an .exe. There are a bunch of .dlls that need to be in the same directory as the executable.
  9. Originally Posted by achilles View Post
    Easy fix, 4 steps
    #4
    #Install BINary APPS: with IWR
    #(You have to paste/type "each" line into the Power Shell on it's own - end press ENTER)
    WinKey+x +a
    ##Download to "System32" DIRectory using "IWR"
    (Disable progress bar in IWR for Downloads to speed up):
    $ProgressPreference = 'SilentlyContinue'
    # CCExtractor "Latest":
    Invoke-WebRequest `
    https://github.com/CCExtractor/ccextractor/releases/latest/download/CCExtractor.msi `
    -OutFile $home\Downloads\CCExtractor.msi
    Start-Process $home\Downloads\CCExtractor.msi -ArgumentList '/quiet' -Wait
    I just don't get it,
    why some people insist
    on placing EXE files in project
    DIRectroy, instead of having
    them available globally across
    the whole system ....and for ALL projects
    like any other program/app ........
  10. Changed GEOFENCE = ("us", "ca","gb",) in TUBI works in uk
  11. Originally Posted by stabbedbybrick View Post
    Hi Chaps,
    Thanks Stabby,...
    I checked, there are no subs available for that particular film.
    I can confirm that the available tubi service will work with both u.s. and u.k. sites. (as long as cookies are available)... (but i'm deffo not logged in).
    Also the tubi service auto started a vpn (not sure which, so it obviously used the u.s. to get this particular movie).
    Audio and video both downloaded fine but would not mux due to the unavailable subs. Not a problem, i can toolnix them together. (So more of a hindrance than a problem,....) just odd because other u.k. services mux fine when subs are available.
    Appreciate the replies from others as well. (the main thing is, is that it works, at 720p as well). Thumbs Up.
    uninstalled ccextractor. from an elevated cmd prompt i ran CCExtractor.msi,... the install option was C:\Program Files (x86)\CCExtractor
    installation went fine,... just the one question will devine find this location automatically. or would it be better to install to C:\Devine
    Stupid question i know,... (but it took me 10 minutes to find out how i could run an .msi with admin privileges) lol
    can confirm devine cannot see the natural installation folder for ccextractor. 2 files it cannot see, 1 swscale-4.dll and swresample-2.dll both of which are available in C:\Program Files (x86)\CCExtractor
    error image of failure:
    [Attachment 80546 - Click to enlarge]
    also renamed ccextractorwinfull.exe to ccextractor.exe (but made no difference).
  12. Originally Posted by PSXman_uk View Post
    Thumbs up PSXman....
    working with u.k. now. thank you.
  13. Originally Posted by ElCap View Post
    Both are installed which is why I am not sure what it cannot find. They were installed via winget. Is there another/better method to get it working with devine?
  14. Originally Posted by eday_2010 View Post
    MKV Tool NIx needs to be Installed and added to the Windows PATH manually ....so does (CCExtractor and VLC)
    what happens when you try this in PS - CLI:
    ffmpeg -version;
    ffprobe -version;
    mkvextract --version;
    mkvmerge --version;
    #Fin
    If the CLI throws an ERROR on MKVToolNix, its not in PATH if there is an ERRORs on all 4 commands
    then you most likely did not install FFMpeg under "Elevated/Administrator" privileged CLI ... CMD/PowerShell.
    See:
    https://forum.videohelp.com/threads/414487
    #0
    There are 2 levels of privileges when running CLI (in Windows Terminal, PS, CMD):
    #1
    # Windows PATH .........
  15. Does anyone have an example of how to setup NordVPN within the .yaml file?
    I have tried adding it as follows (using the service credentials and not the ones I login to my account):
    nordvpn:
        username:
        password:
    as well as without nordvpn:
    Am I doing it wrong?
    /Edit - Managed to get it working by doing the following:
    proxy_providers:
        nordvpn:
            username:
            password:
  16. Originally Posted by LastResort View Post
    Hi Chaps,
    Thanks Stabby,...
    You need to add the "CCextractor" to Windows PATH,
    the installer does not do it by default (even in Elevated/Admin prompt, like the VLC and MKVToolNix)....
    I have updated the Windows Guide to reflect this more clearly:
    And also the Devine Guide (including TUBI/Cookies and NEW Fast installation)
    https://forum.videohelp.com/threads/414154/page7#post2735380
    All have been confirmed to work on Windows 10 Home edition in VM ....
  17. Originally Posted by SaLTy View Post
    nordvpn:
        username:
        password:
    proxy_providers:
        nordvpn:
            username:
            password:
    Nice! Always great to see when someone posts the solution so others can benefit as well.
  18. I only use TUBI so far with Devine. I am very happy it works. I ran low on hard drive space so I haven't been downloading for at least a week now but hopefully it is still working. I am going to get a Visa Prepaid Card and buy Tubedigger so I have that in my tool box so I have additional options.
    I find Devine complex and my confidence is weak when it comes even to updating services. I get scared I will screw something up and then it will stop working. It is a wonderful program and I am very grateful for what it can do.
  19. Originally Posted by Tom Saurus View Post
    You don't need to worry about using a prepaid card with Tubedigger or anything man, just use your own - nothing illegal about it. Obviously if you don't have one, discard what I just said
  20. Originally Posted by keep_it_breezy View Post
    I was just thinking since it is a one time purchase buy a Visa Prepaid Gift Card for that. I do have a Credit Card with a $500.00 limit but I only use it for Best Buy Canada, Amazon Canada and a few others. But I better check to see if Tubedigger accepts Visa Prepaid Gift Cards as payment. I found out Disney Plus doesn't take them.
  21. Hi all,
    Devine works really well for me, thanks to everyone involved for putting in the hours getting it working.
    I have tried a TUBI movie to download but am getting the following error :
    [Attachment 80678 - Click to enlarge]
    I found a post in this thread where someone else had it but it doesn't look as though they fixed it.
    I am using TUBI UK and not behind a VPN or anything. I can view the video on a web browser, android and android TV. If I go to the address that is mentioned in the error I can get to it through a browser.
    I am using the command -
    devine dl tubi https://tubitv.com/movies/100024017/tower-heist
    and I had made the change to the config file to add GB when TUBI came out.
    Does anyone have any ideas? Many thanks in advance.
  22. Image
    [Attachment 80680 - Click to enlarge]
    Works for me in uk looks like it dropped connection
  23. Originally Posted by peterb999 View Post
    Hi all,
    Also comes up with VPN UK IP address with "content unavailable" msg ....on the website
    Residential UK IP address works to play the video.
    When trying to download on WIndows got the same error:
    ❌ Download Failed...
    An unexpected error occurred in one of the download workers.
    See the error trace above for more information.
    On Linux machine it works without any problems ....(both have the same settings) ..
  24. Thanks for the replies. Weird isn't it.
    I've tried it on another PC in my house (UK ISP) and it has worked fine. There must be something slightly different between the 2 PCs but I can't work out what.
  25. Originally Posted by peterb999 View Post
    What is also strange that other titles from TUBI UK are working fine on the Window$ machine,
    and "/movies/100024017/tower-heist" throws an error ....
  26. Image
    [Attachment 80685 - Click to enlarge]
    ran into a new error today.. didnt see anything above as stated
  27. Originally Posted by pssh View Post
    directories:
    services:
       iP:
    key_vaults:
     - type: SQLite
    And only the:
    Is this a bug?
    or
    key_vaults:
     - type: SQLite
    remote_cdm:
       system_id: 4464
       security_level: 3
       device_name: CDM
    #NordVPN
    #Check the SETTINGS
    devine env info
    devine cfg --list
    Suspect it's something to do with pyenv
  28. Hi chaps,
    Could a kind soul please tell me what the call would be to download a series from tu.bi.... I know that devine dl tubi "address" is for a single episode.... but i'm unaware of what a series call would be. (I did try billys gui, but it fails on everything by putting -w instead of dl in the call line.) (tried everything on billys gui, but that -w never goes away).
    Billy, if you get a chance what does this error mean please..
    Usage: devine dl [OPTIONS] COMMAND [ARGS]...
    Try 'devine dl -?' for help.
    Error: Invalid value for '-w' / '--wanted': Invalid token, syntax error occurred: tubi
    C:\Devine>
  29. Originally Posted by LastResort View Post
    Hi chaps,
    C:\Devine>
    if you are looking for an epsoide of series the call would be
    devine dl -w S01E01 tubi "url "
  30. thanks for the reply gruetry,
    I have no problem downloading singular episodes...
    i.e. C:\Devine>devine dl tubi https://tubitv.com/tv-shows/200005152/s01-e06-the-sixties-weekender
    I cannot fathom out how to download the 6 episodes of the second season.
    i.e. the second season starts with this: (the first episode: https://tubitv.com/tv-shows/200024188/s02-e01-camping)
    so would i do this devine dl tubi https://tubitv.com/tv-shows/200024188 (because I'm sure this is wrong, as the next episode has a totally different url).
    p.s. I'm not sure if i'm doing this right or not but I never use -w. if i use -w it always fails to download anything and throws an error.
    as seen in my previous post.
    fixed
    i did a search using the gui with just a "name" (any name that one might be after) and selecting tubi and search
    this returned a whole list of urls.... upon searching the urls i could see the normal url of the programme and not the url of each separate episode.
    I then selected download and entered the url of the series.
    and then put in the episode numbers as well. see image.Image
    [Attachment 80719 - Click to enlarge]
    (but, i did go back to v 1.02 of the gui)
    slightly sleepy now,... but it did download the complete 2nd season as needed... fantastic.
