Page 12 of 63
FirstFirst ... 2 10 11 12 13 14 22 62 ... LastLast
Results 331 to 360 of 1872
    Nov 2006
    canada
    What am I doing wrong ?
    Made in Chelsea S27E08 ──────────────────────────
    Retrying (Retry(total=14, connect=None, read=None, redirect=None,
    status=None)) after connection broken by 'SSLError(SSLEOFError(8,
    '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of
    protocol (_ssl.c:1000)'))': /vod/stream/76541-008
    Retrying (Retry(total=13, connect=None, read=None, redirect=None,
    Retrying (Retry(total=12, connect=None, read=None, redirect=None,
    Retrying (Retry(total=11, connect=None, read=None, redirect=None,
    Retrying (Retry(total=10, connect=None, read=None, redirect=None,
    Retrying (Retry(total=9, connect=None, read=None, redirect=None,
    1 Video
    └── [H.264, SDR] | en | 1024x576 @ 1505 kb/s, 25.000 FPS
    ⠹ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • FAILED
    1 Audio
    └── [AAC] | en | 2.0 | 133 kb/s
    ⠸ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • SKIPPED
    2 Subtitles
    ├── [VTT] | en
    │ ⠸ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • SKIPPED
    └── [VTT] | en | SDH
    5 Chapters
    ├── 00:00:00.000 | Chapter 01
    ├── 00:13:52.600 | Chapter 02
    ├── 00:22:33.480 | Chapter 03
    ├── 00:33:33.480 | Chapter 04
    └── 00:46:42.240 | Credits
    ❌ Download Failed...
    An unexpected error occurred in one of the download workers.
    See the error trace above for more information.
  2. Originally Posted by mickmars View Post
    1 Video
    1 Audio
    2 Subtitles
    ├── [VTT] | en
    5 Chapters
    What was your initial download command please?
    Nov 2006
    canada
    1 Video
    1 Audio
    2 Subtitles
    ├── [VTT] | en
    5 Chapters
    devine dl --no-proxy -w s027e08 --no-folder --sub-format SRT -q 576 ALL4 made-in-chelsea
  4. Originally Posted by mickmars View Post
    1 Video
    1 Audio
    2 Subtitles
    ├── [VTT] | en
    5 Chapters
    Something in your terminal configuration is causing python requests to be unable to properly perform SSL connections to the target endpoint (in this case, the channel 4 vod provider). Do you have any HTTPS proxies set up that could interrupt this?
  5. I have been playing with the "devine cfg" and noticed that some new options are available:
    ##headers (dict)
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#headers-dict
    so I am trying:
    Please note, if you have a "NOTES" in your "devine.yaml" these maybe be deleted using the below CFG commands
    Known Issues:
    - Config changes remove all comments of the changed files, which may hold critical data. (#14)
    devine cfg headers.Accept-Language "en-US,en;q=0.8"
    devine cfg headers.User-Agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/77.0.3865.75 Safari/537.36"
    command is accepted, however the setting in the YAML file looks like this:
    (the comma after KHTML and the spaces forces the User agent to be split ... in the YAML config)
    headers:
      Accept-Language: en-US,en;q=0.8
      User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML,
    When I edit the User-Agent not to be split on second line, it always reverses back to the second line ...
    I thought a, heureka moment as brackets and "Comma" would perhaps help to create entry for the iPlayer in services
    that requires "services.iP cert $home\wvd\bbciplayer.pem" but that is more than just a KEY/VALUE ...
    services:
      iP:
        cert: C:\Users\user\wvd\bbciplayer.pem
    but I am unable to reproduce this for the iP cert config
    as the CFG command only accepts [KEY] [VALUE]
    devine cfg [OPTIONS] [KEY] [VALUE]
    ##services (dict)
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#services-dict
    devine cfg services.iP, "cert: $home\wvd\bbciplayer.pem"
    #This command works sort of as it needs editing .....
    devine cfg services.iP cert:$home\wvd\bbciplayer.pem
    Here is so far what works:
    devine env info
    devine cfg --list
    #Adding WVD to Devine
    devine wvd add $home\wvd\generic_4464_l3.wvd
    #Check the Help
    devine cfg -?
    ##directories (dict)
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#directories-dict
    devine cfg directories.services $home\git\stabbedbybrick-333\devine-services\services\
    ##cdm (dict)
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#cdm-dict
    devine cfg cdm.default generic_4464_l3
    devine cfg cdm.AMZN chromecdm_903_l3
    devine cfg cdm.NF nexus_6_l1
    #ADVANCE (Will need editing)
    devine cfg cdm.DSNP john_sd,chromecdm_903_l3 #NEEDS a] EXTRA LINE b] SPACE Between ": and CDM name "john_sd :chromecdm_903_l3"
    devine cfg cdm.DSNP "(jane_uhd, nexus_5_l1)" #NEEDS a] EXTRA LINE b] SPACE Between ": and CDM name "jane_uhd: nexus_5_l1"
    ##credentials (dict[str, str|list|dict])
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#credentials-dictstr-strlistdict
    devine cfg credentials.ALL4 email:password = YourEmail:PasswordSetWhenRegisteredOnALL4Website
    devine cfg credentials.DSNP email:password = YourEmail:PasswordSetWhenRegisteredOnDSNPWebsite
    ##downloader (str)
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#downloader-str
    #SET aria2 as a Downloader
    devine cfg downloader aria2c
    #OR
    ##curl_impersonate (dict)
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#curl_impersonate-dict
    #SET curl_impersonate as a Downloader
    devine cfg --unset downloader
    devine cfg downloader curl_impersonate
    ##aria2c (dict)
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#aria2c-dict
    devine cfg aria2c.max_concurrent_downloads 2
    devine cfg aria2c.file_allocation prealloc
    ##headers (dict)
    ##dl (dict)
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#dl-dict
    #Change the output subtitle format from the default (original format) to SRT:
    devine cfg dl.sub_format srt
    #Set the default primary language to download to English:
    devine cfg dl.lang en
    #Set how many tracks to download concurrently to 4 and download threads to 16:
    devine cfg dl.downloads 4
    devine cfg dl.workers 16
    ##proxy_providers (dict)
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#proxy_providers-dict
    devine cfg proxy_providers.basic de
    #OR
    devine cfg proxy_providers.nordvpn de
    #OR manually: --proxy basic:de | --proxy nordvpn:de
    ##basic (dict[str, str|list])
    devine cfg
    us:
    - "http://john%40email.tldassword123@proxy-us.domain.tld:8080"
    - "http://jane%40email.tldassword456@proxy-us.domain2.tld:8080"
    de: "https://127.0.0.1:8080"
    ##nordvpn (dict)
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#nordvpn-dict
    username: zxqsR7C5CyGwmGb6KSvk8qsZ # example of the login format
    password: wXVHmht22hhRKUEQ32PQVjCZ
    servers:
    - us: 12 # force US server #12 for US proxies
    ##services (dict)
    SHOULD LOOK LIKE THIS:
    services:
      iP:
    ##key_vaults (list[dict])
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#key_vaults-listdict
    # 3 types of Vaults are in the Core codebase: API, SQLite and MySQL
    devine cfg key_vaults.type SQLite
    devine cfg key_vaults.name Local-Vault
    devine cfg key_vaults.path $home\\wvd\key_store.db
    #OR
    devine cfg key_vaults.path c:\Users\user\wvd\key_store.db
    and it should be edited like this:
    key_vaults:
    - type: SQLite
      path: c:\Users\user\wvd\key_store.db
    ##remote_cdm (list[dict])
    # https://github.com/devine-dl/devine/blob/master/CONFIG.md#remote_cdm-listdict
    devine cfg remote_cdm.name "CDM_Project_API"
    devine cfg remote_cdm.device_type ANDROID
    devine cfg remote_cdm.system_id 4464
    devine cfg remote_cdm.security_level 3
    devine cfg remote_cdm.host "https://cdrm-project.com/devine"
    devine cfg remote_cdm.secret "CDRM-Project"
    devine cfg remote_cdm.device_name "CDM"
    remote_cdm:
    - name: CDM_Project_API
      device_type: ANDROID
      system_id: 4464
      security_level: 3
      host: https://cdrm-project.com/devine
      secret: CDRM-Project
      device_name: CDM
    devine cfg --list
    If I was in politics I make sure you drink plenty of beer
    and watch plenty of TV to keep you busy. | Data is the new oil.
    Nov 2006
    canada
    I'm slowly getting closer ,Any suggestions ,Folks, I found the video and audio files hiding in my temp folder , but they were "seperate" files , I'm not bothered about subtitles because i really dont need them
    Service: ALL4 ───────────────────────────────
    Service is Geoblocked in your region, getting a Proxy to gb
    Got Proxy from Hola
    + Using cached Tokens...
    Authenticated with Service
    ───────────────────────── Series: Made in Chelsea ──────────────────────────
    27 Seasons, 306 Episodes
    ────────────────────────── Made in Chelsea S27E08 ──────────────────────────
    Cached 1 Key to 1/1 Vaults
    [Widevine]: I0531 02:39:54.788472 10448 demuxer.cc:94]
    Demuxer::Run() on file 'C:\Users\palmer\AppData\Local\Temp
    \devine\Video_3c927909.mp4'. I0531 02:39:54.788666 10448
    demuxer.cc:160] Initialize Demuxer for file 'C:\Users\palm
    er\AppData\Local\Temp\devine\Video_3c927909.mp4'. I0531
    02:40:10.235217 10448 single_segment_segmenter.cc:111]
    Update media header (moov) and rewrite the file to 'C:\Use
    rs\palmer\AppData\Local\Temp\devine\Video_3c927909 _decrypt
    ed.mp4'. I0531 02:40:11.995620 10448 mp4_muxer.cc:193]
    MP4 file 'C:\Users\palmer\AppData\Local\Temp\devine\Video_
    3c927909_decrypted.mp4' finalized.
    [Widevine]: I0531 02:40:23.284648 1956 demuxer.cc:94]
    \devine\Audio_3212e5ed.mp4'. I0531 02:40:23.284825 1956
    er\AppData\Local\Temp\devine\Audio_3212e5ed.mp4'. I0531
    02:40:24.962173 1956 single_segment_segmenter.cc:111]
    rs\palmer\AppData\Local\Temp\devine\Audio_3212e5ed _decrypt
    ed.mp4'. I0531 02:40:25.103258 1956 mp4_muxer.cc:193]
    MP4 file 'C:\Users\palmer\AppData\Local\Temp\devine\Audio_
    3212e5ed_decrypted.mp4' finalized.
    1 Video
    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 02:24 • Downloaded
    1 Audio
    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 02:36 • Downloaded
    2 Subtitles
    ├── [VTT] | en
    5 Chapters
    Widevine(AAAASnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAA CoIARIQ8v+ZPKwvpeKQj
    uNfqZ0oaxoIcmJtY2g0dHYiCDEwMTQzODAwMgA=)
    └── f2ff993cac2fa5e2908ee35fa99d286b:d95f42b8049802880 3c316c58492ce0b*
    Feb 2022
    Search the forum first!
    [B]I'm slowly getting closer ,
    https://buzzheavier.com/f/GO5YODFn8AA= Made in Chelsea S27E08
    Noob Starter Pack. Just download any Widevine media! Over 28,000 downloads for V6!.
    Dec 2021
    england
    Got Proxy from Hola
    1 Video
    1 Audio
    2 Subtitles
    ├── [VTT] | en
    5 Chapters
    sometime channel 4 subtitles is broken so will get error.
    to download without subtitles, just add it in cmd line
    devine dl -V -A -w s27e08 ALL4 (video url)
  9. Originally Posted by mickmars View Post
    Got Proxy from Hola
    1 Video
    1 Audio
    2 Subtitles
    ├── [VTT] | en
    5 Chapters
    You can just mux (combine) those files easily enough if you like?
    Nov 2006
    canada
    Hi All,
    thank you so much for the help and responses
    Is there a code, that i could put in, using Powershell/Terminal that can stop trying to download any subtitles of all types, on everything as default ?
  11. Code:
    @Echo off
    Echo for Programs / Movies without Subtitles
    set /p name=Please enter the Service name ie ALL4
    set name=%name%
    set /p program=Please Enter the Program Name or Entity ie  married-at-first-sight-australia
    set program=%program%
    echo The Service is set to %name%
    echo The Program or Entity is set to %program%
    pause
    devine dl -V -A %name% %program%
    pause
    Just put in notepad and save as .cmd in your devine directory you can select the service add the url
    Nov 2006
    canada
    Originally Posted by PSXman_uk View Post
    @Echo off
    set name=%name%
    pause
    pause
    thanks, quick question Will this command stop downloads for all shows on all chanels ? because that's what im looking for
  13. Originally Posted by mickmars View Post
    @Echo off
    set name=%name%
    pause
    pause
    Yes, this will prompt you for your desired channel (ALL4, BBC etc.), and then asks you for the program you want, it then parses out your responses, and puts them into that devine command at the bottom, which excludes subtitles (as it only has -A and -V, so audio and video respectively).
    Nov 2006
    canada
    When I use Devine, I open up a powershell window and paste in the devine script.
    Is there a way to make a customised powershell shortcut with the Devine commands already in there?
  15. Originally Posted by mickmars View Post
    While I get it, DOUBLE CLICK is shorter then
    WinKey+x +i ........ and then Ctrl+C | Ctrl+V
    But,
    how about creating a TXT file called WhatEverYouWant-v3.3.3.TXT
    and save the important commands in it on Desktop?
    At the top you have the command to go to Devine DIR
    and Enable VENV
    and under the notes for specific services, notes how to download
    your custom commands etc...?
    Simple Ctrl+C/Ctrl+V and you set to go,
    no need to remember the syntax, look up your WhatEverYouWant.TXT
    nano $home\Desktop\DevineNotes-v3.3.3.txt
    #OR
    code $home\Desktop\DevineNotes-v3.3.3.txt
    #OR
    notepad $home\Desktop\DevineNotes-v3.3.3.txt
    #Devine #DIR
    cd $home\git\devine-333-pip\;
    .\env\Scripts\activate;
    devine -v;
    # Upgrade SERVICES
    git -C $home\git\stabbedbybrick-333\devine-services\ pull
    code notepad $home\AppData\Local\devine\devine.yaml
    devine cfg --list
    #iPlayer
    devine dl iP -?
    devine dl --list-titles iP m0013cl7
    devine dl --list -v H.265 -w s01e01 iP m0013cl7
    devine dl -q 432 -r HLG --no-folder -w s01e1 iP m0013cl7
    #ITV
    devine dl itv -?
    #ALL4
    devine dl all4 -?
    #My5
    devine dl my5 -?
    devine search my5 "fred rose"
    devine dl --list-titles my5 the-clues-that-caught-the-killer-fred-rose-west
    devine dl --list my5 the-clues-that-caught-the-killer-fred-rose-west
    devine dl --no-proxy --no-folder --sub-format SRT -q 180 my5 the-clues-that-caught-the-killer-fred-rose-west
    #CTV
    devine dl ctv -?
    #TUBI
    devine dl tubi -?
    #ROKU
    devine dl tub -?
    Then when searching for specific service or whatever
    Press Ctrl+F type what you searching for (or if it is ITV then #itv) and
    you will get straight to info on ITV ......
  16. if your devine is in its own environment all you need to do is put the cmd files in the directory and when your in powershell just type dvdl for example then it would come up with enter service and then enter url shows you the command its going to do then pauses press enter and it downloads if your using the cmd files i gave you.
  17. Image
    [Attachment 79553 - Click to enlarge]
    Any linux people tell me why the itv service fails with workers ive checked what I think are all the dependencies
  18. Originally Posted by PSXman_uk View Post
    Aria2c tries to do multiple threaded downloads via workers, it seems that sometimes services disagree with this, and that's what causes the error. The way I've found to consistently fix this is to use requests / curl_impersonate as your downloader, or turn down the number of worker using --workers (i believe).
  19. Originally Posted by keep_it_breezy View Post
    Tried lowering the workers as I didn't have that in my config had no downloader set I don't have Aria2c so set curl_impersonate as downloader also tried without it and it downloaded the subs file and that's all.
  20. Originally Posted by PSXman_uk View Post
    Well that's a start - try and figure out why now then, lol.
    Nov 2006
    canada
    Trying to download something from ITV and i keep getting
    KeyError: 'seriesType'
    However using the exact same commands on different ITV shows works absolutely fine
    any suggestions ?
  22. Originally Posted by mickmars View Post
    any suggestions ?
    URL please
  23. Member
    Nov 2006
    canada
    any suggestions ?
    URL please
    devine dl -V -A --list itv https://www.itv.com/watch/the-only-way-is-essex/1a9310/1a9310a0412
  24. That link goes to the episode for Sunday 2nd June 2024 at 9PM BST..... It's not been shown yet..
  25. Member
    Nov 2006
    canada
    I appreciate your response,I know what you mean.
    I wondered if it was that kind of quirk in the system, and yet the episode is available to watch "now"
  26. devine dl itv https://www.itv.com/watch/the-only-way-is-essex/1a9310/1a9310a0411 one from last week wont dl either you get the same error message not that I want to dl it
  27. Originally Posted by PSXman_uk View Post
    That's interesting - I wonder if because it's TOWIE and it doesn't have seasons set up such as S1, S2 etc. that that's what's causing the issue.
  28. Checking and other series work fine so I think it is indeed a TOWIE thing...
  29. Originally Posted by keep_it_breezy View Post
    Interestingly works in Freevine
    Save Name: The.Only.Way.is.Essex.S33E10.720p.ITV.WEB-DL.AAC2.0.H.264
  30. Originally Posted by mickmars View Post
    It's 8.45pm and the website says 9pm.... I'm in the uk and I can't play it at all....
