Page 63 of 63
FirstFirst ... 13 53 61 62 63
Results 1,861 to 1,867 of 1867
  1. Hi Everyone...
    Really hoping someone can remind me of what I need to do:.... Although still downloading fine I am seeing an error... (seems I may have accidently updated some python items by mistake). my error: RequestsDependencyWarning: urllib3 (1.26.20) or chardet (5.2.0)/charset_normalizer (2.0.12) doesn't match a supported version!
    warnings.warn("urllib3 ({}) or chardet ({})/charset_normalizer ({}) doesn't match a supported "
    How would I go about correcting this please.. all i can remember is something along the lines of pip install --- but then is it ==... (all i can think is that i need to downgrade something) . for more clarity see screenshot.
    [Attachment 89458 - Click to enlarge]
  2. I'm getting this error with ALL4, ITVX, My5
                           / __ \/ ____/ |  / /  _/ | / / ____/
                          / / / / __/  | | / // //  |/ / __/
                         / /_/ / /___  | |/ // // /|  / /___
                        /_____/_____/  |___/___/_/ |_/_____/
                        v3.3.3 Copyright © 2019-2025 rlaphoenix
                          https://github.com/devine-dl/devine
         Service Config loaded
         Loaded Cdm Widevine CDM: 4464 (L3)
         Loaded 0 Vaults
      ────────────────────────────── Service: ALL4 ───────────────────────────────
         Service is not Geoblocked in your region
          + Using cached Tokens...
         Authenticated with Service
      ────────────────────────────── Series: Hunted ──────────────────────────────
         8 Seasons, 48 Episodes
      ────────────────────────────── Hunted S08E01 ───────────────────────────────
         Cached 1 Key to 0/0 Vaults
         1 Video
         └── [H.264, SDR] | en | 1920x1080 @ 6298 kb/s, 25.000 FPS
             ⠴ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • FAILED
         1 Audio
         └── [AAC] | en | 2.0 | 135 kb/s
         1 Subtitle
         └── [VTT] | en
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:00 • Downloaded
         5 Chapters
         ├── 00:00:00.000 | Chapter 01
         ├── 00:14:04.480 | Chapter 02
         ├── 00:25:24.280 | Chapter 03
         ├── 00:37:47.440 | Chapter 04
         └── 00:46:28.120 | Credits
         Widevine(AAAASnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAACoIARIQzk/GfJHBXChbM
         4/ghJH4LxoIcmJtY2g0dHYiCDEyODkyNDU5MgA=)
         └── ce4fc67c91c15c285b338fe08491f82f:440d4f908e3dd529ed0a8b4bbd1915ca*
         ❌ Download Failed...
            'charmap' codec can't decode byte 0x81 in position 121: character
         maps to <undefined>
            An unexpected error occurred in one of the download workers.
            See the error trace above for more information.
    And this error with STV
         Loaded 0 Vaults
      ─────────────────────────────── Service: STV ───────────────────────────────
      ───────────────────────────── Series: Accused ──────────────────────────────
         2 Seasons, 10 Episodes
      ───────────────────── Accused S01E01 1. Willy's Story ──────────────────────
         No Widevine PSSH was found for this track, is it DRM free?
         1 Video
         └── [H.264, SDR] | en | 1024x576 @ 1794 kb/s, 25.000 FPS
             ⠦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • FAILED
         1 Audio
         └── [AAC] | en | 127 kb/s
         1 Subtitle
         └── [VTT] | en
         5 Chapters
         ├── 00:00:00.000
         ├── 00:10:41.400
         ├── 00:20:18.000
         ├── 00:33:02.704
         └── 00:47:44.000
            'charmap' codec can't decode byte 0x81 in position 116: character
         maps to <undefined>
    Anyone know of a fix?
  3. First id check your config. I noticed it says on yours, loaded 0 vaults.
    It should say:
    Loaded 1 Vaults
    Type for config info:
    devine env info
    As for the actual error, do you have all the dependencies installed?
    The error message "'charmap' codec can't decode byte" typically occurs in Python when trying to read a file that contains characters not supported by the specified encoding. To resolve this, you can try opening the file with a different encoding, such as 'utf-8', which can handle a wider range of characters.
    I am assuming (although not an expert by a very very long way) the dependency Unidecode isn't installed. Which could mean that a few dependencies aren't.
    [tool.poetry.dependencies]
    python = ">=3.9,<4.0"
    appdirs = "^1.4.4"
    Brotli = "^1.1.0"
    click = "^8.1.7"
    construct = "^2.8.8"
    crccheck = "^1.3.0"
    jsonpickle = "^3.0.4"
    langcodes = { extras = ["data"], version = "^3.4.0" }
    lxml = "^5.2.1"
    pproxy = "^2.7.9"
    protobuf = "^4.25.3"
    pycaption = "^2.2.6"
    pycryptodomex = "^3.20.0"
    pyjwt = "^2.8.0"
    pymediainfo = "^6.1.0"
    pymp4 = "^1.4.0"
    pymysql = "^1.1.0"
    pywidevine = { extras = ["serve"], version = "^1.8.0" }
    PyYAML = "^6.0.1"
    requests = { extras = ["socks"], version = "^2.31.0" }
    rich = "^13.7.1"
    "rlaphoenix.m3u8" = "^3.4.0"
    "ruamel.yaml" = "^0.18.6"
    sortedcontainers = "^2.4.0"
    subtitle-filter = "^1.4.9"
    Unidecode = "^1.3.8"
    urllib3 = "^2.2.1"
    chardet = "^5.2.0"
    curl-cffi = "^0.7.0b4"
    Just a few things that you could look at.
         Loaded 0 Vaults
         1 Video
         1 Audio
         1 Subtitle
         └── [VTT] | en
         5 Chapters
         maps to <undefined>
         Loaded 0 Vaults
         1 Video
         1 Audio
         1 Subtitle
         └── [VTT] | en
         5 Chapters
         ├── 00:00:00.000
         ├── 00:10:41.400
         ├── 00:20:18.000
         ├── 00:33:02.704
         └── 00:47:44.000
         maps to <undefined>
  4. Originally Posted by the-equalizer View Post
    It should say:
    Loaded 1 Vaults
    devine env info
    appdirs = "^1.4.4"
    Brotli = "^1.1.0"
    click = "^8.1.7"
    crccheck = "^1.3.0"
    lxml = "^5.2.1"
    pproxy = "^2.7.9"
    pyjwt = "^2.8.0"
    pymp4 = "^1.4.0"
    pymysql = "^1.1.0"
    PyYAML = "^6.0.1"
    rich = "^13.7.1"
    urllib3 = "^2.2.1"
    chardet = "^5.2.0"
         Loaded 0 Vaults
         1 Video
         1 Audio
         1 Subtitle
         └── [VTT] | en
         5 Chapters
         maps to <undefined>
         Loaded 0 Vaults
         1 Video
         1 Audio
         1 Subtitle
         └── [VTT] | en
         5 Chapters
         ├── 00:00:00.000
         ├── 00:10:41.400
         ├── 00:20:18.000
         ├── 00:33:02.704
         └── 00:47:44.000
         maps to <undefined>
    Cheers for the pointer regarding the dependencies.
    It was working up until a few days ago. I've figured out that I've got two versions of Python and for some reason it was using the version without the dependencies (all of a sudden) so I've copied them all over and it's working like a charm again.
    I will say that I haven't recently installed a 2nd version of Python, I've had both versions for a while
  5. Could someone please help me out with this error concerning Devine....
    devine 3.3.3 requires urllib3<3.0.0,>=2.2.1, but you have urllib3 1.26.20 which is incompatible. Does anyone know what I have to upgrade..... Please....
    I have already tried to install urllib3 2.2.1 but it seems to have made matters worse with the following error...
    ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
    google-auth 2.22.0 requires urllib3<2.0, but you have urllib3 2.2.1 which is incompatible.
    Successfully installed urllib3-2.2.1
    C:\freevine-1.1.7>pip install urllib3==2.0
    Collecting urllib3==2.0
    Downloading urllib3-2.0.0-py3-none-any.whl.metadata (6.6 kB)
    WARNING: The candidate selected for download or install is a yanked version: 'urllib3' candidate (version 2.0.0 at https://files.pythonhosted.org/packages/ca/25/fe81738a115a2f1005b19bd69b6253b7b5cd6c91...3-none-any.whl (from https://pypi.org/simple/urllib3/) (requires-python:>=3.7))
    Reason for being yanked: Truncated response bodies when streaming a large compressed body. Upgrade to at least 2.0.2 (See: https://github.com/urllib3/urllib3/issues/3009)
    Downloading urllib3-2.0.0-py3-none-any.whl (123 kB)
    Installing collected packages: urllib3
    Attempting uninstall: urllib3
    Found existing installation: urllib3 2.2.1
    Uninstalling urllib3-2.2.1:
    Successfully uninstalled urllib3-2.2.1
    devine 3.3.3 requires urllib3<3.0.0,>=2.2.1, but you have urllib3 2.0.0 which is incompatible.
    google-auth 2.22.0 requires urllib3<2.0, but you have urllib3 2.0.0 which is incompatible.
    Successfully installed urllib3-2.0.0
    I assumed it was asking for urllib3 2.2.1,... but that was wrong, I then tried 2.0.0 but that's wrong as well. Can someone please help.
  6. Look in pyproject.toml. Find urllib and change the upper bound to the value 3.1.26.20. Then try the install again..
    Edit
    You also might take the opportunity to change from poetry to uv
     uvx migrate-to-uv
    just run that in the pyproject.toml folder and then
    uv run devine
    will work
  7. Thank you ever so much for replying phased....
    I edited the file you mentioned pyproject.toml (making sure i had a backup).
    from this:Image
    [Attachment 89804 - Click to enlarge]
    to this:Image
    [Attachment 89805 - Click to enlarge]
    then tested it before doing anything else... found 2 quick downloads from i.t.v and 4.o.d and this is what the downloads showed:Image
    [Attachment 89806 - Click to enlarge]
    No error messages at all. I can't believe one small piece of text can make such a difference.
    Truly thankful for your help.
