Page 55 of 63
FirstFirst ... 5 45 53 54 55 56 57 ... LastLast
Results 1,621 to 1,650 of 1867
  1. Originally Posted by phased View Post
    Originally Posted by OnlyMeFFS1 View Post
    Does anyone know why this has started happening on ITV today, I am not using a VPN just direct connecting and I am logged in and can play the video on the website, it has usually worked up until today.
    Olivier Nanist, three doors down from you, was at home today watching 4k porn on 4 devices at once; TV, laptop, phone and desktop computer. Sorry but there was no bandwidth left for you.
    Sorry but I don't understand what you mean........If there was no bandwidth left for me, surely I wouldn't be able to watch it online.
  2. Originally Posted by OnlyMeFFS1 View Post
    I'm getting exactly the same for ITVX
  3. Well that's good to know as it means it's not just on my end...Thanks for the helpful reply.
  4. Originally Posted by OnlyMeFFS1 View Post
    It's not working for the UK Free To Air Downloader either, same type of error. They must have changed something. What am I going to do without my classic coronation street anymore?
    EDIT - good news, it is still working with UK-FTA if I search for the show. Phew!
  5. Originally Posted by peterb999 View Post
    I tried that program and it says error mp4decrypt not found.....downloaded the binaries from Bento4s website but dont know what to do with it, would rather have mkv.
  6. Are you using windows or Linux? If windows, copy the mp4decrypt.exe file to c:\windows\system32 (or put it somewhere you can add it to the PATH).
    With UK-FTA you end up with a .MKV - mp4decrypt is just used to decrypt the file then when it is merged with the audio it is muxed into a .MKV
  7. Originally Posted by peterb999 View Post
    Thank you very much, that worked, Just need it to download in 1080p now instead of 896x504.
    Nov 2006
    canada
    Yes, same here too
  9. Originally Posted by OnlyMeFFS1 View Post
    Yeah, I forgot about that. The most UK-FTA has ever been able to do is 720p. With Classic Corrie it's only in standard def so it doesn't affect me.
    The genius who created the services for Devine for us, Stabbedbybrick, somehow managed to get a full 1080p stream from somewhere.
    Just a thought, have you tried getting your program from STV instead? I'm sure that they let you download 1080p and they have a lot of the same programmes as ITVX.
  10. Yeah....I had tried STV after ITVX didn't work and they didn't have it on there... but it still downloads programs fine just like all the others do....it's just ITVX that's playing up.....I really appreciate your help on helping me with the FTA program.
  11. Originally Posted by OnlyMeFFS1 View Post
    You're welcome, glad I could help.
    Dec 2021
    england
    itv download work fine without vpn,
    [Attachment 87277 - Click to enlarge]
  13. Still stuck on "Fetching meta data" for me, and i've never used a VPN as I am in the UK.
  14. Originally Posted by ListyDoM View Post
    Originally Posted by milflover View Post
    I use Tunnel Bear! <
    This VPN is not suitable (you can check this by simply opening the page in your browser), or if devine is installed with hola.exe, then you need to select USA instead of UK, i.e. in Tunnel Bear select USA, and hola will connect via the UK proxy itself.
    Sorry for my late reply, thanks everyone for the help. It finally works I'm happy
    [Attachment 87282 - Click to enlarge]
  15. Originally Posted by mickmars View Post
    Yes, same here too
    Make sure you're using the latest version of the script (v1.0.1).
  16. Cheers mate....Deleted my install and reinstalled it from the github and everything is back to normal.
  17. Something I have noticed if you are archiving certain shows for example "Walker Texas Ranger" Roku has the episodes at 45 minutes or so in length and Pluto TV has the episodes 40 minutes in length. This leads me to the conclusion that perhaps some editing is involved to squeeze in ever more commercials. Now this is not the case with all videos on either service but it is something to think about. You are better off to go for as close to complete episode in my opinion.
    This being written downloading from ROKU is frustrating. Yesterday I had trouble with being disconnected and getting reports that it wasn't available in my area. I am using Windscribe VPN and I was using Freevine as Roku still works on there. It was happening on Devine as well.
  18. Originally Posted by stabbedbybrick View Post
    Well, that's a bit embarrassing. I'm usually really good at syncing the scripts, but I can see that you changed the ITV script 4 months ago. Apologies for not thinking of syncing with your github. Thanks very much.
  19. Hi, thank you so much for making Devine available. I found this guide for W11 https://telegra.ph/Devine-On-Win-v003-04-10 will it work for W10 as well or is there another guide somewhere?
    Also found this but again W11 https://forum.videohelp.com/threads/416617-Semi-automated-guide-to-install-stabbedbybr...fork-of-Devine
    Oct 2023
    Afghanistan
    I hadn't noticed the change of user agent before. Thanks mate, fixed my issues.
  21. Thanks stabbedbybrick for your excellent work and SaintyUK for the very helpful guide.
    Need some help to get the same results as freevine I couldn't find in the help.
    How to specify filename?
    How to output MP4 without subs?
    In freevine it was recommended to use a proxy so used windscribe is this still recommended?
    Thanks again.
  22. --no-folder is not recognised is it removed?
    Sorry for all the stupid questions.
    How to acheive this freevine command with devine please?
    freevine.py get --proxy UK --no-cache --episode URL --save-name FILENAME.mp4
    So far I have just
    devine dl itv URL
  23. Member
    Nov 2006
    canada
    Hi All
    How exactly, do I change to the latest version of the script (v1.0.1)
    Cheers
  24. Originally Posted by mickmars View Post
    Hi All
    Cheers
    git pull httpss://cdm-project.com/stabbedbybrick/devine-services.git C:\devine-services
    I think.
  25. Originally Posted by mickmars View Post
    Hi All
    Cheers
    I use GitHub desktop. It is point and click and allows you to "clone" the services. It's then a simple process of clicking one button to see if the services have been updated.
  26. Member
    Nov 2006
    canada
    Hi All
    Cheers
    Thanks , I do have Github desktop but im never quite sure how to actually use it.
    I figured it out, THANK YOU SO MUCH
  27. Member
    Nov 2006
    canada
    Hi All
    Cheers
    I think.
    I opend a terminal and entered that command but it didnt do anything, I just got this
    fatal: not a git repository (or any of the parent directories): .git
  28. Originally Posted by mickmars View Post
    You need to edit the path to point to where divine is.
    EDIT
    I've also got an extra s in there too, and you will need quotes if your path has spaces. Should be
    git pull https://cdm-project.com/stabbedbybrick/devine-services.git "C:\some folder\devine-services"
  29. Originally Posted by mickmars View Post
    Hi All
    Cheers
    Sorry about that, I missed your post saying you weren't sure how to do it. Well done on working it out though - once it's working it's great isn't it, so long as you remember to keep checking for updates which I tend to forget to do.
  30. Member
    Dec 2024
    i downloaded 3.12.10 and followed the directions but it didnt do the job for me.
    OK. I see this error with python 3.13.3
    Error: Invalid value for '--sub-format': 'SRT' is not one of 'subrip', 'substationalpha', 'substationalphav4', 'timedtextmarkuplang', 'webvtt', 'fttml', 'fvtt'.
    And a correction for me is to replace sub_format: srt with sub_format: subrip in devine.yaml.
    did that and i got an error
    [Attachment 87138 - Click to enlarge]
    Have you tried to get this show without the subtitles by just asking Devine to get -V -A -C which would just get the video, audio and chapters?
    i tried that but it still gives me the same error.
    ok i need smb to help me out bc i tried downloading sumn off of pluto it still give me the same damn annoying thing.
