Page 49 of 63
FirstFirst ... 39 47 48 49 50 51 59 ... LastLast
Results 1,441 to 1,470 of 1867
    Dec 2024
    Originally Posted by the-equalizer View Post
    Depending on how long it is since you updated, you can use a wayback for a capture from 1st march 2025 to update.
    https://web.archive.org/web/20250301214604/https://cdm-project.com/stabbedbybrick/devine-services
    Originally Posted by evbuk1 View Post
    The CDM Project github service seems to have been down for a few days.
    Is there another host where I can get up-to-date versions of stabbedbybrick's devine services from?
    Thanks.
    when i did that i got this
    [Attachment 86240 - Click to enlarge]
  2. Originally Posted by the-equalizer View Post
    Thanks.
    Thank you for this information. Maybe stabbedbybrick is working on some new project. I remember not long ago he wrote that Devine was decaying away and he had some thoughts of exploring some other ways of doing the same things.
  3. Oh man, I recently lost my setup and came to grab stabbedbybricks devine-services again to find the site's dead. Does anyone have a recent copy of them that could share them please?
  4. Originally Posted by smernt View Post
    I've uploaded it here. I last updated it on 13th March so it's pretty new.
    https://limewire.com/d/vTAeo#tMQZegIPLe
    I think the upload only lasts a week.
  5. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    You can upload the services permanently here
    https://files.videohelp.com/
    At least until the issue is fixed
    Dec 2023
    Spain
    Here's a Wayback link for it from early March, don't think it was updated after this.
  7. Originally Posted by mkjustuk View Post
    Hey, thanks! But unfortunately, the actual files can't be viewed, "Wayback Machine has not archived that URL.".
    Dec 2024
    bro when i downloaded the services file and put it into the devine folder i get this. anybody else got this?
    [Attachment 86288 - Click to enlarge]
  9. Originally Posted by peterb999 View Post
    Thank you!
  10. Originally Posted by Tricky_Vicky View Post
    Solution
    Running this command on the created file sets the correct HLG transfer characteristics.
    mkvmerge -o output.mkv --colour-transfer-characteristics 0:18 input.mkv
    Can anyone think of better solution for "SERIES"?
    #All *.mkv files in ~/Videos/ DIR
    find ~/Videos/ -name *.mkv -exec mkvmerge --colour-transfer-characteristics 0:18 -v -o {}.mkv {} \;
    #All *.mkv files in current DIR
    find . -name *.mkv -exec mkvmerge --colour-transfer-characteristics 0:18 -v -o {}.mkv {} \;
    Saving to a different DIR? ....
    Remove the mkv.mkv? ....
    If I was in politics I make sure you drink plenty of beer
    and watch plenty of TV to keep you busy. | Data is the new oil.
  11. Originally Posted by iamkennethy_ View Post
    Hi,
    1. I know it sounds daft but you did unzip the file and put the folder onto your computer?
    2. If yes to 1, have you told devine to look at that path for the services?
    If you haven't done 2 do the following :
    1. In a command prompt, type DEVINE ENV INFO and it will tell you where it is looking for your services and where your devine.yaml file is.
    2. Open your devine.yaml file and put the services location in there in this format :
    directories:
    services: C:\rclone\services\services
    It should then find the services.
    Dec 2021
    england
    my devine.yaml, you must do same with yours
    aria2c:
      file_allocation: prealloc
    cdm:
      default: 4445.l3
    credentials:
      ALL4: 'email:password'
      CTV: 'email:password'
      TVNZ: 'email:password'
    directories:
      services: .\devine\services
      temp: .\temp
      downloads: .\downloads
      cookies: .\devine\cookies
      cache: .\devine\cache
      logs: .\devine\logs
    key_vaults:
      - type: SQLite
        path: ./key_vault.db
    dl:
      lang: en
      sub_format: srt
    headers:
      Accept-Language: "en-US,en;q=0.8"
      User-Agent: "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/77.0.3865.75 Safari/537.36"
    proxy_providers:
    profiles:
      default: default
    services:
        iP:
            cert: ./devine/certs/bbciplayer.pem
    tag: ""
    Dec 2024
    Hi,
    directories:
    [Attachment 86297 - Click to enlarge]
    did it but it still dont change anything. i did put the same yaml file into the downloads folder and idk if thats causing the problem
    Dec 2022
    Lesotho
    Solution
    In cmd you can definitely use a batch file to manipulate the files as needed.
    Dec 2023
    Spain
    What's the directory structure that is then showing under C:/owner/Appdata/Local/devine/services ?
    Specifically, what's the full directory for pluto? It should be: C:/owner/Appdata/Local/devine/services/PLUTO/config.yaml
    Dec 2024
    [Attachment 86306 - Click to enlarge]
    [Attachment 86307 - Click to enlarge]
    ok idk what im doing wrong but why do it act like it don't recognize when I literally put the file with those exact numbers in the wvd folder
  17. 2nd Army Bridgeburners. WhiskeyJack's Avatar
    Aug 2024
    Torshavn
    make sure the file is correctly titled
    8158_l3.wvd
    You may need to add the wvd via devine command first
    devine add wvd 8158_l3.wvd
    with the file 8158_l3.wvd in the folder you point to in your devine.yaml
  18. Hello, I'm not sure if this is exactly the right place for this post but I know some of the people here will have answers to some of my questions. If its in the wrong place please move it if that is necessary.
    What started as bit of a hobby project has snowballed and basically I'm trying to understand the process of obtaining UHD iplayer content. I have build a downloader which works fine for anything up to 720p which is actually fine for my personal needs but the I started investigating higher definitions and ran into some issues.
    I know that the mpd for higher def content comes from a different API endpoint: https://securegate.iplayer.bbc.co.uk/mediaselector/6/select/version/2.0/vpid/{vpid}/format/json/mediaset/iptv-uhd/ and I know this is protected by SSL certs but there are a few things I'm not clear on and I thought someone here could give me some pointers for my own understanding.
    Is API andpoint accessed by using a WVN L3 key? Does this need to be generated from a 4K device? I have used Android Studio in the past to generate an L3 key can I just use this I have generated a .wvd? If this is the case how is the key used in the link above to the API endpoint. I know how to use this in the context of N_m3u8DL-RE but my understanding is this is only for accessing/downloading once the mpd is obtained from the API. Currently for 720p below I am using my own python code so I was wondering if this is done with a tool or I just need to further modify the python code/link formation?
    Apologies for the stream of questions. I am not looking to be spoon fed anything, if someone could point me in the direction of posts or other resources where I can read up on this I would appreciate it. I have looked in the thread here and forum more generally but a lot of it seems to be in relation to using others tools whereas I am interested in building my own and understanding what's going on under the hood.
    Thanks in advance
    P.S. Apologies if I mix up any terminology, I am still learning about all this.
  19. Originally Posted by wallump View Post
    Why re-invent the wheel. This thread is about Devine and it downloads UHD from the BBC just fine.
    BBC content is not encrypted.
  20. Thanks for the response.
    Why reinvent the wheel? Well that's not my intention, it's more about the process and learning. I'm not too bothered about the media itself, I just enjoy a challenge I guess..
    I understand the BBC content is not encrypted, I didn't think that was really the solution but I thought I would put it out there to knock it off the list. I guess the crux of it is how to solve the SSL access issue to BBC's API endpoint. How do other implementations resolve this issue, I don't need the practical method more the technical theory, or a nudge in the right direction.
    Thanks again
  21. @wallump do you have the cert in your devine.yaml
    services:
    iP:
    cert: C:\scripts\devine\certs\bbciplayer.pem
    like so ?
  22. Hi @PSXman_uk, I have spent some time reading and this is actually where I have now ended up
    So I need a .pem and this needs to be from a UHD compatible device I believe? I have a client_id.bin and private_.pem along with an android.wvd I generated from Android Studio but I'm not sure if that will work.
    Are mobile devices like this with sufficient resolution useable because from reading it seems that this needs to be from a UHD TV no? In which case is it possible to find these online or do I need to get one from my own TV (I do have a UHD Android TV so it might be possible to do that with a little work).
    Moving foward slowing, thanks for your reply from before!
  23. Aha I have got my hands on a smart tv firmware file which I believe can do what I need
  24. Probably easier if you just download the .pem. Maybe google "fhiizo playready-tool bbciplayer.pem"
  25. Member
    Dec 2024
    got this error when trying to download an episode off of tubi. anybody else get this or am i doing something wrong
    / __ \/ ____/ | / / _/ | / / ____/
    / / / / __/ | | / // // |/ / __/
    / /_/ / /___ | |/ // // /| / /___
    /_____/_____/ |___/___/_/ |_/_____/
    v3.3.3 Copyright © 2019-2025 rlaphoenix
    https://github.com/devine-dl/devine
    Service Config loaded
    Loaded Cdm Widevine CDM: 8158 (L3)
    Loaded 1 Vaults
    ────────────────────────────── Service: TUBI ───────────────────────────────
    Service has no Geofence
    Authenticated with Service
    ─────────────────── Series: The Steve Harvey Show (2015) ───────────────────
    1 Season, 1 Episode
    ────────── The Steve Harvey Show S03E01 Baby You Can Drive My Car ──────────
    1 Video
    └── [H.264, SDR] | en | 854x648 @ 1420 kb/s, 29.970 FPS
    ⠹ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • FAILED
    1 Audio
    └── [AAC] | en | 2.0 | 133 kb/s
    ⠹ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • SKIPPED
    1 Subtitle
    └── [SRT] | en
    4 Chapters
    ├── 00:00:00.000
    ├── 00:01:49.000 | intro_start
    ├── 00:02:19.000 | intro_end
    └── 00:21:51.000 | postlude
    ❌ Download Failed...
    An unexpected error occurred in one of the download workers.
    See the error trace above for more information.
  26. Hi @peterb999 you may be right, but I've not actually found anything online with that search term or any variation of it tbh.
    I understand I need the pem but what function does that serve when iplayer content is not widevine encryted. Does that hold the certs to authenticate to the api server correctly? That's my working hypothesis at the moment.
    I do have a prm file which I know contains the cert for an SL3000 device, it just seems like it will take some work to extract the cert. I know cdm-project.com has some resources but the site is offline for now and it seems undetermined as to when its likely to be back up from what I read.
    Any other ideas about how to get hold of a pem for bbciplayer for UHD content?
  27. I can get most of what I try to download from TUBI but some of the newer movies are not downloading such as "Babe", "Battleship" and "Babe: Pig In The City"; Devine says "Failed to get video resources". "check geography settings". Do others get it fine or have the same problem?
  28. Originally Posted by wallump View Post
    You can get it here :
    https://github.com/FhiiZo/PlayReady-Tool/blob/main/bbciplayer.pem
  29. Stuff is getting harder to find.
    Devine Services from S'brick last update Feb 2025 https://files.videohelp.com/u/312095/devine-services.zip This is original S'brick without N_m3u8dl-re options
    BBC iPlayer certificate https://files.videohelp.com/u/312095/bbciplayer.pem
  30. @peterb999 thanks for the link, I actually managed to extract my own cert and key already but useful none the less.
    @phased really appreciate a link to those resources, services especially will be useful as a reference point for my own work on this!
